Vanos Solenoid - anyone use Dr. Vanos to repair? - BMW M5 Forum and M6 Forums
post #1 of 4 Old 1st March 2010, 07:41 AM Thread Starter
reds2
reds2's Avatar
Anyone use Dr. Vanos to repair instead of replace? If so, how much and how did it work out? Thanks.
reds2 is offline
post #2 of 4 Old 1st March 2010, 06:53 PM
vencap
vencap's Avatar
I did order and install the new gaskets and o-rings. The existing o-rings were extremely brittle and I'm sure needed to be replaced, but I did end up ordering new solenoids and installing them on my problem bank. That fixed the issue.
Many have had luck with fixing the solenoids, and I did try that but I was not able to get them to function fully. Mine just would give me an issue from starting the car through about 2 minutes of driving, then the symptoms would disappear.
The $100 fix is a good place to start, in addition to the CPSs.
'00 TiAg ///M5
"Second place is the first loser." - A wise man
vencap is offline
post #3 of 4 Old 1st March 2010, 09:55 PM
Neil.D
Neil.D's Avatar
If you're wanting to replace the O rings + gasket, stick with OEM. It took them several years to degrade like they have.
2000 M5 Titanium silver
Neil.D is offline
post #4 of 4 Old 2nd March 2010, 04:01 AM Thread Starter
reds2
reds2's Avatar
reds2 is offline
Wanted -- Vanos solenoid stephenf E39 M5 and E52 Z8 Discussion 29 16th February 2010 11:03 PM
Need a Used VANOS Solenoid gzig5 E39 M5 and E52 Z8 Discussion 13 23rd June 2009 08:29 PM
VANOS Solenoid everycredit E39 M5 and E52 Z8 Discussion 7 15th August 2008 08:20 PM
Vanos Solenoid vs Complete Vanos Replacement SoCaLE39 E39 M5 and E52 Z8 Discussion 5 4th June 2008 09:42 PM
vanos solenoid eddie696 E39 M5 and E52 Z8 Discussion 4 14th August 2004 08:51 PM
