Timing chain on S62 broke... - BMW M5 Forum and M6 Forums
post #1 of 54 Old 24th December 2009, 11:36 PM Thread Starter
Maximos
There is an opportunity to purchase an M5 with a broken timing chain at a good price. According to him, the owner was driving when the car stopped. He tried starting it again, which didn't work, and had it towed to the local German auto shop. He was quoted $3,500 for the replacement of the chain. He claims inability to fix it due to financial hardship. I should mention that NICB reports that car has a salvage title, but I haven't seen an actual history report on the vehicle.(-if anyone has a spare report, PM me for the VIN... would be much appreciated )
I have a few questions:
1. What could have caused this to happen?
2. Is this a DIY job in any way?
3. Is the $3,500 figure accurate?
4. Could this have caused major damage to the engine itself? I have located a replacement engine for $4k after receipt of the older engine. In the case that a replacement is needed, how much should the procedure cost?
I have not seen pics of the car yet, but apparently it is a one-owner car in very good condition...
Thanks for the help.
Maximos is offline
post #2 of 54 Old 24th December 2009, 11:44 PM
arotished
Is it the main timing chain? 3500 sounds about right, much needs to come of in order to change the main chain
arotished is offline
post #3 of 54 Old 24th December 2009, 11:59 PM Thread Starter
Maximos
Yes, I suppose that's why he can't afford to get it fixed. I'm guessing the valves are bent since he tried starting it after the chain broke, which might mean the cylinder heads are bad...
Maximos is offline
post #4 of 54 Old 25th December 2009, 12:00 AM
jt2ma71
jt2ma71's Avatar
If the chain broke while the vehicle was running then expect to be replacing more than just the chain. Generally when timing belts/chains snap pistons meet valves.
2003 E55 AMG - Obsidian Black/Black, Eurocharged ECU reflash, 84mm SC pulley, CM30 IC Pump, FTP Heat exchanger, Needswings Dual CAI, Custom exhaust, Forgestar F14's, Lowering links, E63 Spoiler, CF Front lip
2000 BMW M5 - Alpine White/Silverstone Extended Leather/BBS LMs 245.35.19, 285.30.19/Evolve Alpha-N/Tubi Exhaust/AA Intake/Ducts/Dinan Springs - RIP
2001 Yamaha R6 - Yamaha Blue, Yamaha GYT-R Exhaust, Factory Pro +4 Ignition Advance, Factory Pro Jet kit, 03R6 Airbox/Filter, Clear Alternates and fender eliminator, puig windscreen, Yamaha Solo seat, APE CCT
2000 Durango SLT+ - 5.9 V8, 3.92 LSD, 32x11.5 BFG All Terrains, Airaid intake, Hughes F1 Airgap, SCT Tuner, Flowmaster 50 Series, Fully rebuilt 46RE, 2" torsion lift
Glock17 9x19|Vz.58 7.62x39|Mossberg 500
jt2ma71 is offline
post #5 of 54 Old 25th December 2009, 12:03 AM Thread Starter
Maximos
From my understanding, the S62 is a non-interference engine, which means that the pistons wouldn't be damaged. Either way, replacing the chain is only $500 less than getting a different engine, not including any messed up valves, cylinder heads, etc.
Maximos is offline
post #6 of 54 Old 25th December 2009, 12:04 AM
vantaam5
The parts(like pistons and valves) are not that expensive,but the labour is quite alot(so expensive).
vantaam5 is offline
post #7 of 54 Old 25th December 2009, 12:21 AM
Neil.D
Neil.D's Avatar
Really? Non interference? That surprises me if true.
2000 M5 Titanium silver
Neil.D is offline
post #8 of 54 Old 25th December 2009, 12:25 AM Thread Starter
Maximos
I'm not 100% sure, but I read it on this forum. Like I said, I've located a replacement and am just trying to weigh my options to see if repairing this car will be worth it in the end.
Maximos is offline
post #9 of 54 Old 25th December 2009, 12:32 AM
gsfent
gsfent's Avatar
How well do you know the car and how much do you know about the replacement motor? How much to install the motor? Doing a clutch while you are in there? Mileage? Other worn parts, like suspension?
And then, once it is together, if there is anything else wrong, your nickel. Of course, you may be able to part out some of the blown motor. So, fair amount of risk depending on what you know; if the risk is not too great, or the price justifies the risk, then go for it.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #10 of 54 Old 25th December 2009, 12:45 AM Thread Starter
Maximos
According to the owner, the car just had a new clutch, radiator, and fuel pump installed. I've had quotes from $1,500 (mediocre shop) to $2k (high end shop) for the replacement. The replacement has a 3 month warranty on it. If the car does indeed have a salvage title, and since its obviously in need of major engine repair or more like replacement, I think I'd get it real cheap, but then I have to consider if the car is actually worth repairing due to the supposed salvage title...
Maximos is offline
Possible timing problem -- Timing Chain skipped? stephenf E39 M5 and E52 Z8 Discussion 95 25th May 2011 03:54 PM
Timing Chain Guides doolie E28 M5 Discussion 0 27th September 2006 05:52 PM
Timing chain Ajax5678 E34 M5 Discussion 5 19th April 2006 11:06 AM
WTB S62 lower timing chain cover burtsplash Parts / Other For Sale or Wanted 1 16th April 2006 11:58 PM
Broke timing belt et1bill E34 M5 Discussion 4 3rd December 2002 10:44 PM
