Oil Cooler Installation - Page 28 - BMW M5 Forum and M6 Forums
 17Likes
post #271 of 276 Old 14th September 2017, 02:55 AM
Duck
Originally Posted by Duck View Post
Wish I could remember. I believe I got around 9 ft of hose.
Found my receipt. It was 9 ft. I probably had a little left over and lines have plenty of slack so that I can take off the front bumper without much issue. The oil cooler stays mounted to the bumper.
Duck is offline
The Following User Says Thank You to Duck For This Useful Post:
Gouki (21st October 2017)
post #272 of 276 Old 24th April 2018, 11:14 PM
Sasho
Sasho's Avatar
Guys... Anyone runing the gulf oil filter housing + cooler with stock airboxes? Im thinking of moving the filters under the fender and having the oil cooler...
"Horsepower sells cars, torque wins races." E. Ferrari
Sasho is offline
post #273 of 276 Old 21st February 2019, 07:13 AM
boris1
I just ran across this thread and I am just curious, for the people concerned about high oil temperatures, how high does it get on your oil temperature gauge on the cluster. With street driving mine generally stays right between the 210 mark and the dot to the left of it, and in traffic and/or track it right on 210. I've never seen the needle get any higher. How accurate is this gauge?
boris1 is offline
post #274 of 276 Old 21st February 2019, 09:23 AM
Duck
Search how to reach the secret menu on the instrument cluster and check oil temp from there. I can tell you my temp gauge is not accurate before or definitely even worse after I changed my oil temp sensor.
Duck is offline
post #275 of 276 Old 22nd February 2019, 12:32 AM
Seedster
Seedster's Avatar
If you're at 210F (or even close) on the track, you're not sending it hard enough I run an RK oil cooler, heat exchanger delete, CSF rad, 90/10 distilled/coolant + water wetter...and will be 260-270F on the track all day. The gauge is pretty accurate when compared to the secret menu number. I think it's safe to say you're good.
Seedster is offline
post #276 of 276 Old 3rd March 2019, 05:06 PM
alexE39M5s62
alexE39M5s62 is offline
oil cooler for B8 schlumpf-nu ALPINABoard.com | BMW Alpina Discussion 35 17th October 2015 08:20 PM
Oil Cooler Konfused Pete E34 M5 Discussion 5 8th September 2009 11:34 PM
Need an oil cooler for my M5 Rallistas E39 M5 and E52 Z8 Discussion 2 27th September 2007 06:39 AM
Oil line to oil cooler broke! what a mess! vespam5 E34 M5 Discussion 3 13th April 2006 08:40 AM
B6 2,8 oil cooler? carmel ALPINABoard.com | BMW Alpina Discussion 10 25th May 2001 02:24 PM
