Did a thermostat replacement today (a lot of pics) - Page 7 - BMW M5 Forum and M6 Forums
 50Likes
post #61 of 554 Old 9th November 2009, 05:54 AM
herrubermensch
Originally Posted by JesperT View Post
Anyone, I will strongly recommend that you don't waste time on replacing the inner seal. I have not seen any good arguments why this needs to be replaced and I have not found anybody who had problems because they didn't replace it. So if it looks fine, just leave it even if you have already bought a new one. Just my 5 cents on this issue...
Jesper
That's what I did. I have an inner seal for sale if anyone wants it!
--Peter
herrubermensch is offline
post #62 of 554 Old 9th November 2009, 07:46 PM
areyoui
areyoui is offline
post #63 of 554 Old 26th November 2009, 06:47 AM
ard
ard's Avatar
Just finished this myself.
Here is another good reference:
https://www.m5board.com/vbulletin/e39...ll-advice.html
I will add some notes:
1. I cannot imagine getting this done without removing once side of the VANOS oil lines. I removed the passenger side (US) which is one banjo and one hose clamp, and bent it up out of the way.
2. The difficulty with removal is caused by two factors:
1. there are two sliding 'joints' on each tube- one at each end. When pulling you get motion of both joints before one releases- if you could hold the tubes 'back' it would be easier- in any event, it takes fiddling. (To clarify- if each end has 1/4" of motion, it takes 1/2" overall to pop them loose. If you could ensure that only one part moves you can do it in 1/4". On disassembly you cannot control this- however on assembly, you place the tubes all the way in, so the final positioning is just that last 1/4".)
2. The end of the thermostat hits the bottom, fixed housing- If you can pry the old thermostat loose, and cant it slightly, this will give you a bit more motion to get that upper section out.
Assembly....
3. You MUST use lube. I used silicone o-ring lube for pool parts, plenty of stuff can be used. I was concerned with compatibility, but I think petrolatum (vasoline) should be good.
4. ALIGNMENT. Once you get it apart, try test fitting/inserting the tubes with o-rings into housing (out on your bench, in the light.) Get a sense of how this assembly should work: There is slight chamfer on the outer bore, and the oring- as it sits in it's groove on the tube- must contact this chamfer equally all around the circumference. Any 'tilt' to the tube (and the o-ring) relative to the housing/chamfer will cause the o-ring to push out - and get crimped or sheared off on continued insertion. If it is in equal circumferential contact as you push, it will go in and not get crimped
This is the key to the job. IMHO.
5. Grease up all o-rings. Grease up the housings on the engine and the thermostat housing. Carefully install the three tubes into the engine. FEEL for that alignment- gentle pressure- you will feel the tube 'line up' which indicates the o-ring is in circumferential contact- then gentle push. It should POP into place. Do this for all three tubes.
6. NOW that these three are into the bores, you can actually move these tubes- just a bit- upwards to get ready for the upper thermostat housing...
7. Next trick: Do not fully seat the thermostat into the upper housing- if it is loose, you can cant (tilt) it a bit to allow it's bottom part to clear the lower housing- BEFORE you need to engage all the o rings... you want to avoid trying to jam the o-rings in until it is all in perfect alignment.
So, place the upper part, loosely holding the thermostat in the housing let it tilt, then roate the upper part into the 3 tubes. Once you've gotten the upperhousing in place, you can get your fingers under and pop the thermostat up into it's final position.
8. Now take the time to align everything.... The upper housing should be pretty close to it's final 'mounting plane'- it is down, but maybe a few mm of compression left once you tighten the screws... but pretty much in it's final position vertically- take the three tubes and gently move them down to level- again feel the three tubes and their o-rings all pressing against their respective chamfers in the upper housing- gently but firmly, just ever so slight wiggle, and pop- in they go.
Bolt it up, all done.
A
ard is offline
The Following 5 Users Say Thank You to ard For This Useful Post:
a_ok2me (24th March 2014), Mike S. (27th November 2009), MPowrd (30th January 2013), sor118 (16th May 2014), wojtekpia (10th December 2009)
post #64 of 554 Old 10th December 2009, 07:33 PM
wojtekpia
Parts List
I'm planning to take on this job soon and I'm looking for a definitive parts list. Here's what I've got so far:
08 Thermostat 79CEL 1 11537835558
07 Gasket ring 1 11531312287 x 1
09 O-ring 31X2,5MM 4 11531406249 x 4
11 O-ring 18,3X3,6MM 2 11531407002 x 1
Am I missing any O-rings? Lower temp sensor? I realize that some don't suggest changing the gasket ring, but that's another conversation.
Thanks!
wojtekpia is offline
post #65 of 554 Old 10th December 2009, 07:37 PM
lothar
Hi Ard,
I noticed you are in the same area as me (I'm out in Cameron Park) and just did a thermostat install. I picked up a used M5 a few weeks ago and after driving it for a bit realized the temperature is probably running too cool. There are no faults in the computer, but with this cold weather we're having, the coolant temp is close to the first dot which after reading on the board for a bit doesn't sound normal. I'd assume you are seeing closer to the the middle of the range with the new thermostat even with the 30 degree weather around here? It sounds like some people are able to get this done quickly and some people are doing it over and over again with leaks. Do you recommend the DYI or should I consider taking it down to Valley Motorwerks? Car is an 03 with about 46K on it if that makes any difference.
Assembly....
A
lothar is offline
post #66 of 554 Old 10th December 2009, 07:46 PM
vantaam5
I replaced now three thermostats without removing the Vanos oil line,so it is possible
Just opended the clamps that hold the pressure containers in place and the it is quite easy...
vantaam5 is offline
post #67 of 554 Old 10th December 2009, 07:52 PM
gsfent
gsfent's Avatar
Thanks!
If that is the o-ring for the pipe going into the heat exchanger, you need 2, one for each end. I didn't do the end on the Tstat housing because it stayed firmly in place upon removing the Tstat housing.
Based on my experience, I would buy a couple extra of each o-ring, they are cheap enough and you don't want to have to make an extra trip to the dealer if you rip (or lose) one.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #68 of 554 Old 11th December 2009, 12:00 AM
DouglasABaker
DouglasABaker's Avatar
Originally Posted by lothar View Post
Hi Ard,
The gauge is not reliable. Use the information available in the dashboard computer.
d-
DouglasABaker is offline
post #69 of 554 Old 11th December 2009, 12:12 AM
ard
ard's Avatar
Hi Ard,
Indeed, same area. I'll look out for you.
So you had this issue, DID the thermostat, and it remains??? Please clarify.
In any event, the first dot is too cool- assumung the guage is working. As suggested above, unlock the OBC display and read coolant temp directly.
I cannot recommend DIY or not... all depends on the skills of the 'Y'. Valley has a good rep. I did not find the job to be hard at all.
A
ard is offline
post #70 of 554 Old 11th December 2009, 08:55 AM
lothar
A
Nope, just noticed the issue. I'm on the fence about whether to try the DIY or not, some of the stories in this thread and the other one were scaring me
I wanted to make sure that the cold weather wasn't causing the issue, though if you're not seeing it with the new thermostat that's not very likely. I'll try the secret menu and see what the temp is, but unless I wind the motor up, it stays pretty much locked on the first dot. With some acceleration runs it will move a bit to the right but nowhere near the middle.
lothar is offline
Instructions for Thermostat Replacement? Any With Pics? Anita E39 M5 and E52 Z8 Discussion 25 6th January 2014 04:19 AM
Thermostat Replacement - San Diego Locals Help? VetteRacer E39 M5 and E52 Z8 Discussion 0 30th June 2009 11:03 AM
Thermostat replacement?? Finesta101 E39 M5 and E52 Z8 Discussion 5 30th November 2008 07:50 PM
Few pics for you lot...... [line example pics Ringtaxi through AF for Scoopz ;) ] Stevie E60 M5 and E61 M5 Touring Discussion 12 1st August 2007 02:06 AM
Report from Geneva, a lot of pics (Updated 13th March with 911 GT3 & Turbo pics/info) Gustav E60 M5 and E61 M5 Touring Discussion 71 1st April 2006 03:36 AM
