Did a thermostat replacement today (a lot of pics) - Page 6 - BMW M5 Forum and M6 Forums
 50Likes
post #51 of 554 Old 27th October 2009, 10:15 PM
TurboCarrera
The thermostat is a reasonable $39 at Arizona Autohaus. It is a Behr part. autohausaz.com
Steve
00 M5
TurboCarrera is offline
The Following User Says Thank You to TurboCarrera For This Useful Post:
btmlinedan (28th November 2009)
post #52 of 554 Old 27th October 2009, 11:39 PM
DouglasABaker
DouglasABaker's Avatar
Originally Posted by Hdhntr23 View Post
Yes Douglas. It is MANDITORY that if you drain from the block you get new crush washers. That would suck to get the thing drained all the way then only to realize you didnt buy 2 $.60 parts. So while youre buying the MANDITORY OEM coolant ask them for some crush washers for the block.
Much better
d-
DouglasABaker is offline
post #53 of 554 Old 28th October 2009, 02:45 AM
Bimmerbear
Bimmerbear's Avatar
Thanks Doug and Chris. I'll be sure to pick up the crush washers. How soon do you guys think I need to drain this stuff? Should it be an immediate concern?
Bimmerbear is offline
post #54 of 554 Old 28th October 2009, 03:25 PM
Hdhntr23
Hdhntr23's Avatar
Did you get a premix type? As in 50/50? Or, did you mix your own? If you mixed your own and used tap water I'd say get it out as soon as possible.
If you bought it premixed or you used distilled water I would say yes its a priority but get to it when you have a spare hour or so.
The mineral deposits from tap water will ruin your internals faster than off the shelf anti freeze. I wouldnt wait too long though if you bought off the shelf 50/50 mixed.
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts, Projector Fogs
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline
post #55 of 554 Old 28th October 2009, 04:30 PM
DouglasABaker
I'll go with: as soon as possible. The longer you leave it, the greater the risk, but I don't think any severe damage will be done in the short term. I'd say if you get it out in a week or two you'll be fine...
d-
post #56 of 554 Old 8th November 2009, 01:30 AM
2strokecoldsmoke
2strokecoldsmoke's Avatar
Thanks for the DIY!
M5 is out in the garage on jack stands right now, ready for the new t-stat install.
Except I think I only bought 4 o-rings, not six, so will see how that goes.
2strokecoldsmoke is offline
post #57 of 554 Old 8th November 2009, 01:36 AM
vantaam5
Replaced on 2 M5s today the thermostats,only the inner metal sealing ring in the housing was a PITA...
Edit:Both don't run original BMW coolant and not even TWS
vantaam5 is offline
post #58 of 554 Old 8th November 2009, 09:01 PM
drfv
drfv's Avatar
did the thermostat about a month ago. when putting housing back on I didn't seat the thermo in the housing till after i slid it in place over the water pump. This allowed me to be able to tilt the thermo at an angle to move it in proper place over the pump. once i hade wiggled it over the housing i pushed the thermo in place and now had the 3 pipes completely level to be seated. this will keep you from pinching or knocking an o-ring out of place. just a gentle push and they all popped right in to place. you will feel if they go on right or not. without doing this it looks like it will be a significant angle to push on.
never replaced the inner gasket unless it is trashed not really nec. would highly recommend bmw fluid or another HOAT for an aluminum block and no tap water use purefied. this last one failed in partial position fyi. also fill from the temp switch hole if you can all while squeezing both hoses will keep you from getting an air pocket of needing to bleed.
2001 m5 carbon black
2001 540i topaz blue metallic
drfv is offline
The Following 2 Users Say Thank You to drfv For This Useful Post:
chowdah (12th December 2017), joeywx (9th March 2011)
post #59 of 554 Old 9th November 2009, 02:43 AM
2strokecoldsmoke
Couple of things of note from my replacement:
-Yes, TIS says you don't need to disconnect the VANOS oil lines. But not worth the aggrevation, order up the replacement crush washers (2 ea of #07119963072 and 2 ea of 07119963129) for the banjo bolts and flop the oil lines out of the way, makes it much easier.
-Had to really pull and wiggle to get the housing off, the water pipes did not want to pop out.
-I replaced the inner seal, I'd agree with the previous posts that its probably not necessary, but I had already bought the damn thing. MAJOR PITA to get out.
Should replace your oil seperator drain lines while you have the t-stat housing off. Have to have the t-stat housing off to get at the drain lines, and our engines are old enough now that rubber hoses are starting to deteriate.
#11151407344 and #11151406902 along with the clamps for the bottom end, 2 each of #07129952107
I had to borrow a big socket from a friend to press the new inner seal back into the t-stat housing.
He says the M5 thermostat design is identical to the one Caterpillar has been using on their big diesel engines for the last 20 years or so.
The Following 2 Users Say Thank You to 2strokecoldsmoke For This Useful Post:
Dysfnctnl85 (29th December 2015)
post #60 of 554 Old 9th November 2009, 05:49 AM
JesperT
JesperT's Avatar
Inner thermostat gasket.
I finally replaced my thermostat based on this thread and other on this site. It all went well and my temp is now back to 85 C. Thanks to everyone for posting your experiences! It's a great help for someone like me who has not done this type of job before.
Anyone, I will strongly recommend that you don't waste time on replacing the inner seal. I have not seen any good arguments why this needs to be replaced and I have not found anybody who had problems because they didn't replace it. So if it looks fine, just leave it even if you have already bought a new one. Just my 5 cents on this issue...
Jesper
JesperT is offline
Instructions for Thermostat Replacement? Any With Pics? Anita E39 M5 and E52 Z8 Discussion 25 6th January 2014 04:19 AM
Thermostat Replacement - San Diego Locals Help? VetteRacer E39 M5 and E52 Z8 Discussion 0 30th June 2009 11:03 AM
Thermostat replacement?? Finesta101 E39 M5 and E52 Z8 Discussion 5 30th November 2008 07:50 PM
Few pics for you lot...... [line example pics Ringtaxi through AF for Scoopz ;) ] Stevie E60 M5 and E61 M5 Touring Discussion 12 1st August 2007 02:06 AM
Report from Geneva, a lot of pics (Updated 13th March with 911 GT3 & Turbo pics/info) Gustav E60 M5 and E61 M5 Touring Discussion 71 1st April 2006 03:36 AM
