Did a thermostat replacement today (a lot of pics) - Page 5 - BMW M5 Forum and M6 Forums
 50Likes
post #41 of 554 Old 27th October 2009, 05:34 AM
Bimmerbear
Bimmerbear's Avatar
Originally Posted by DouglasABaker View Post
Use the correct coolant and your pump will be fine. Use the wrong coolant (i.e. not-BMW) and you'll be replacing your pump. The coolant contains special ingredients required to maintain the seals in our engines (I don't recall what, but I'm sure someone will tell us).
Wait, we have to use BMW specific coolant too? I just refilled mine with Prestone after doing this the other day.
Bimmerbear is offline
post #42 of 554 Old 27th October 2009, 07:48 AM Thread Starter
timmay77
timmay77's Avatar
I have been told by EVERYONE that using anything but BMW radiator fluid is a big time NO NO. I used the BMW fluid and distilled water.
The New Whip:
2003 Sterling Gray/Executive Caramel ///M5 (Name TBD)
~Coming soon! 5.3 LS Twin Turbo Swap. Just another LS swap, but with 2 snails.
The Storm Trooper:
2014 328i xDrive Msport Alpine White/Black Dakota (fully loaded)
~Bootmod3 stage 2~ER Downpipe~ER Charge pipe~BMS Intercooler~351M wheels
Tim ~ email: HallmanTL (at) gmail (dot) com
timmay77 is offline
post #43 of 554 Old 27th October 2009, 02:08 PM
NachtBlau
NachtBlau's Avatar
I have used the DEX Cool (I think by prestone) for years on my other BMW's. Never a problem. I even deleted the fan on my E36 and still never a problem. Just make sure the coolant is safe for "all metals." Dont get teh cheap green junk though.
NachtBlau is offline
post #44 of 554 Old 27th October 2009, 03:37 PM
DouglasABaker
DouglasABaker's Avatar
I don't recall exactly what, but there is something about BMW coolant that is different from most of the off the shelf brands. I think it has to do with silicates, but honestly, I don't recall if it is supposed to have them or not. Whatever it is, it maintains the health of your water pump.
With that in mind, it is much like oil or any other part - if you can find a comparable aftermarket product that meets the same specs/requirements, there is no reason not to use it, but I wouldn't grab a random bottle off the shelf and hope it works out.
d-
DouglasABaker is offline
post #45 of 554 Old 27th October 2009, 04:58 PM
Need4Spd
Need4Spd's Avatar
You should use BMW approved fluid. Too many variables with seals and metals for me to take the chance just to save a few dollars. If you go aftermarket, I'd seriously look into Zerex G-05. Supposedly it's factory fill for many European cars these days, only w/o the huge dealer markup. Zerex G 05. There is a Pat Bedard article on this on Car and Driver online.
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is offline
post #46 of 554 Old 27th October 2009, 06:27 PM
Bimmerbear
Bimmerbear's Avatar
So how hard would it be for me to drain ALL of the coolant and refill it with the BMW stuff? When we did the t-stat replacement, we didn't drain the block, so right now there's just an amalgamation of fluids in there - old BMW coolant, new Prestone coolant, and DI water. I really don't want to have to take it to someone; that's the whole reason I did it myself. I guess I should have researched the coolant issue beforehand.
Edit: After some research, it looks like I just have to pull the radiator plug and the plugs on both sides of the block and refill 50/50 with coolant/water. I need 6.5 quarts of coolant since we have a 13 quart capacity, right?
post #47 of 554 Old 27th October 2009, 07:38 PM
DouglasABaker
You've got the drain method down. Just remember that the radiator drain plug doesn't unscrew the whole way (1/4 turn then pull down I think) - ask me how I know... I bought 2 gallons and had plenty, so you're 13quart number sounds close...
d-
The Following User Says Thank You to DouglasABaker For This Useful Post:
Bimmerbear (27th October 2009)
post #48 of 554 Old 27th October 2009, 08:47 PM
Hdhntr23
Hdhntr23's Avatar
If youre going to drain it from the block I suggest new crush washers when you do.
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts, Projector Fogs
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline
The Following User Says Thank You to Hdhntr23 For This Useful Post:
post #49 of 554 Old 27th October 2009, 09:37 PM
DouglasABaker
No suggesting allowed - take a stand!
"You must use new crush washers when replacing the block plugs since crush washers are not reusable"
d-
post #50 of 554 Old 27th October 2009, 09:47 PM
Hdhntr23
Hdhntr23's Avatar
Yes Douglas. It is MANDITORY that if you drain from the block you get new crush washers. That would suck to get the thing drained all the way then only to realize you didnt buy 2 $.60 parts. So while youre buying the MANDITORY OEM coolant ask them for some crush washers for the block.
Hdhntr23 is offline
Instructions for Thermostat Replacement? Any With Pics? Anita E39 M5 and E52 Z8 Discussion 25 6th January 2014 04:19 AM
Thermostat Replacement - San Diego Locals Help? VetteRacer E39 M5 and E52 Z8 Discussion 0 30th June 2009 11:03 AM
Thermostat replacement?? Finesta101 E39 M5 and E52 Z8 Discussion 5 30th November 2008 07:50 PM
Few pics for you lot...... [line example pics Ringtaxi through AF for Scoopz ;) ] Stevie E60 M5 and E61 M5 Touring Discussion 12 1st August 2007 02:06 AM
Report from Geneva, a lot of pics (Updated 13th March with 911 GT3 & Turbo pics/info) Gustav E60 M5 and E61 M5 Touring Discussion 71 1st April 2006 03:36 AM
