Did a thermostat replacement today (a lot of pics) - Page 4 - BMW M5 Forum and M6 Forums
 50Likes
post #31 of 554 Old 7th October 2009, 12:21 AM Thread Starter
timmay77
timmay77's Avatar
Originally Posted by DouglasABaker View Post
I told Chris that there were 6 o-rings, so don't let him give you any trouble about it He said they weren't leaking, so lets just hope it stays that way!!!
d-
Chris told me. I just didn't see it. If it leaks it's my fault and I will change it out, again.....
The New Whip:
2003 Sterling Gray/Executive Caramel ///M5 (Name TBD)
~Coming soon! 5.3 LS Twin Turbo Swap. Just another LS swap, but with 2 snails.
The Storm Trooper:
2014 328i xDrive Msport Alpine White/Black Dakota (fully loaded)
~Bootmod3 stage 2~ER Downpipe~ER Charge pipe~BMS Intercooler~351M wheels
Tim ~ email: HallmanTL (at) gmail (dot) com
timmay77 is offline
post #32 of 554 Old 7th October 2009, 02:10 AM
CSBM5
CSBM5's Avatar
Hey Chuck,
It connects to the oil intercooler, not the block. Part #10 with o-rings #11
d-
Ah, of course! Thanks.
Chuck
Current stable:
CSBM5 is offline
post #33 of 554 Old 7th October 2009, 02:41 AM
T-TRIM 540i
There is a bunch of difference between the thermostats between the M5 and my 540i . Great pictorial....
T-TRIM 540i is offline
post #34 of 554 Old 13th October 2009, 08:27 PM
Surge709
Surge709's Avatar
Sorry for the stupid question but why not do the water pump as well when you're already there for preventative maintenance (or do ours not fail)?
Formally 2003 M5
355/345 brembos, 18" BBS RG-Rs (with 245 front, 275 rear PSSs), UUC Ultimate SSK, Evolve CAI, AA duct kit, Intrave, OE Bluetooth, Eurodash, Euro center console, Euro Clears, Zionville radiator with 2 stage fan,
GC coilovers (430/380), Eibach sways, V1, Laser Intercept, Turner stud kit, Uniden CB, Uniden 996T scanner, 5000K xenon fogs, 5000K OE DDEs, 5000k Angel Eyes, illuminated door sills, Clearbra, Evolve Headers, SS racing Cats, SS X-pipe, Evolve Alpha N, Leatherique!
Surge709 is offline
post #35 of 554 Old 13th October 2009, 08:45 PM
Hdhntr23
Hdhntr23's Avatar
2 or 3 reasons for me at least...
1. most importantly it wasnt cost effective for me to do it right now.
2. Im under the impression that they arent connected or in the same housing vs. most standard setups (I may get corrected on this one sorry if its wrong)
3. Tim has done enough for me I didnt want to have him worry about that right now anyway.
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts, Projector Fogs
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline
post #36 of 554 Old 14th October 2009, 12:07 AM
DouglasABaker
DouglasABaker's Avatar
Because it requires significantly greater dis-assembly to get to it. The t-stat can be changed by disconnecting a couple tubes and removing a couple bolts. Changing the water pump requires a much greater dis-assembly of the front of the engine.
d-
DouglasABaker is offline
post #37 of 554 Old 14th October 2009, 01:44 PM
Surge709
Surge709's Avatar
Do our water pumps fail often or it's not an issue?
The reason I ask is that my friend's just blew up on his e46 M3 and he is worried about engine damage from the possible overheat.
Formally 2003 M5
Surge709 is offline
post #38 of 554 Old 14th October 2009, 02:48 PM
CSBM5
CSBM5's Avatar
In all the years I've had the E39 M5 (and been on the board here), I can't really recall any water pump failure issues ever being discussed...of any significance anyway. Apparently, the M5 pump design is much more robust than the 540i/E46/E36, etc, where you need to proactively replace by ~60k. That being said, the E39 M5 is now old enough that some people are really getting up there in miles. I wonder if tranck has ever done his water pump?
Current stable:
CSBM5 is offline
post #39 of 554 Old 14th October 2009, 04:02 PM
DouglasABaker
Use the correct coolant and your pump will be fine. Use the wrong coolant (i.e. not-BMW) and you'll be replacing your pump. The coolant contains special ingredients required to maintain the seals in our engines (I don't recall what, but I'm sure someone will tell us).
post #40 of 554 Old 26th October 2009, 04:26 PM
Need4Spd
Need4Spd's Avatar
The thermostat resides in the upper portion of the water pump. However, as others noted, there aren't a lot of posts about water pump failures on this board, so either nobody bothers to report them, or they're not quite the issue they are on other BMWs. Still, when I had my t'stat changed recently (at over 105k miles), I went and did the pump, too. My car is my daily driver and I just didn't want to get stuck somewhere with a cooling problem. On tear-down found that the pulleys/tensioners were well-worn, too. The coolant reservoir looked like it was on its last legs, and so I changed that out. Also changed most if not all of the rubber parts that had to come out at the same time (hoses, belt).
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is offline
Instructions for Thermostat Replacement? Any With Pics? Anita E39 M5 and E52 Z8 Discussion 25 6th January 2014 04:19 AM
Thermostat Replacement - San Diego Locals Help? VetteRacer E39 M5 and E52 Z8 Discussion 0 30th June 2009 11:03 AM
Thermostat replacement?? Finesta101 E39 M5 and E52 Z8 Discussion 5 30th November 2008 07:50 PM
Few pics for you lot...... [line example pics Ringtaxi through AF for Scoopz ;) ] Stevie E60 M5 and E61 M5 Touring Discussion 12 1st August 2007 02:06 AM
Report from Geneva, a lot of pics (Updated 13th March with 911 GT3 & Turbo pics/info) Gustav E60 M5 and E61 M5 Touring Discussion 71 1st April 2006 03:36 AM
