Did a thermostat replacement today (a lot of pics) - Page 3 - BMW M5 Forum and M6 Forums
 50Likes
post #21 of 554 Old 6th October 2009, 09:50 PM
DouglasABaker
DouglasABaker's Avatar
Originally Posted by timmay77 View Post
Yes, what a PIA to get out, and back in....
Told you to leave that one in there, didn't I?
Originally Posted by m3bim View Post
NOTE: any DIY'ers, make sure to install the thermo with the correct orientation. Otherwise, OVERHEAT!
While it might create some additional turbulence, I'm hard pressed to believe it will lead to an overheat situation. In any case, "correct position" means that the solid sides of the spring housing do not block the two lines that enter the t-stat area at 9 and 11:30 in the pictures shown.
Originally Posted by razahyde View Post
just an fyi, you dont have to remove the oil lines from the vanos, you can simply unbolt the bracket from the pump.
True, but it makes your life a lot easier to take them off. Then again, TIS says not to, so why bother?
DouglasABaker is offline
post #22 of 554 Old 6th October 2009, 09:55 PM
DouglasABaker
Here you can see 3 of the 4 O rings that should be replaced. The other is a tube that goes inbetween them, it has 2 Orings on it, one on each end.
Great job on the writeup guys - glad you got it all taken care of
One slight correction: That is actually 2 of the 6 (six) o-rings that should be replaced. Each of the tubes shown is also removable and has an o-ring on the other end as well. In total there are 3 removable tubes, each with 2 o-rings.
If the t-stat housing has not been removed before, it is very likely that the pipes will be "frozen" and will seem like they are part of the housing (or block), but they are not. If you can manage not to move them at all during dis/re-assembly, then you can probably avoid replacing them. This, however, is very difficult, so I would err on the side of replacing all 6 of them while I had it apart.
d-
The Following 2 Users Say Thank You to DouglasABaker For This Useful Post:
CSBM5 (6th October 2009), Vector57 (27th October 2009)
post #23 of 554 Old 6th October 2009, 10:02 PM
Hdhntr23
Hdhntr23's Avatar
200+ miles so far and no leaks!
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan) Euro "Safety kit" Fire Extinguisher and First Aid box (Thanks Slimmbones)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills (Thanks Havasusteve03Beast), ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels, Stainless vented custom Fog-Light frames, Hamann style sideskirts w/ CFiber Inserts, Projector Fogs
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan), Stoptech slotted rotors with StopTech Street Performance Brake Pads (Thanks Zeckhausen Racing Timmay77 and Lunker325)
Hdhntr23 is offline
post #24 of 554 Old 6th October 2009, 10:15 PM Thread Starter
timmay77
timmay77's Avatar
d-
Oops, didn't know that. They must have been frozen pretty damn good, I pulled like hell to get them out......
The New Whip:
2003 Sterling Gray/Executive Caramel ///M5 (Name TBD)
~Coming soon! 5.3 LS Twin Turbo Swap. Just another LS swap, but with 2 snails.
The Storm Trooper:
2014 328i xDrive Msport Alpine White/Black Dakota (fully loaded)
~Bootmod3 stage 2~ER Downpipe~ER Charge pipe~BMS Intercooler~351M wheels
Tim ~ email: HallmanTL (at) gmail (dot) com
timmay77 is offline
post #25 of 554 Old 6th October 2009, 10:32 PM
DouglasABaker
I had the same problem with mine. I actually had 1 get stuck in the t-stat housing and the other got left behind in the head. Not a lot of room to wiggle things around in there...
d-
post #26 of 554 Old 6th October 2009, 10:44 PM
Wildstar
Wildstar's Avatar
FYI, cooling the heads first is not particularly new. Ford/Yamaha did it on the SHO V-8s starting in 1996 model year. It was bit unusual then, but not new. I've had several "regular" T-stats fail in the open mode, but that is probably less common that failing closed. Having it designed to fail open is a good idea. Which probably means mine will fail closed... ;-)
I'm over 30, I can't trust myself!
2002 M5 LeMans Blue
2000 Z3 Roadster Topaz Blue
1990 Taurus SHO Oxford White
Wildstar is offline
post #27 of 554 Old 6th October 2009, 10:45 PM Thread Starter
timmay77
timmay77's Avatar
d-
I wish that would have happened to me, I would have known to change them then. I guess it just didn't click in my head that they came off the housing. I even head realoem pulled up looking at the parts. Duh......
Thanks for pointing that out Doug, now that we have a Tstat change with pics, more people won't make the same mistake I did. Luckily it isn't leaking. Sorry Chris!!
The New Whip:
The Storm Trooper:
timmay77 is offline
post #28 of 554 Old 6th October 2009, 11:14 PM
DouglasABaker
I told Chris that there were 6 o-rings, so don't let him give you any trouble about it He said they weren't leaking, so lets just hope it stays that way!!!
d-
post #29 of 554 Old 6th October 2009, 11:58 PM
CSBM5
CSBM5's Avatar
Doug,
Where do I find that small "third" tube on the parts diagrams? I looked at this link on realoem, but I only see the two main ones.
Thanks,
Chuck
Current stable:
CSBM5 is offline
post #30 of 554 Old 7th October 2009, 12:05 AM
DouglasABaker
The Following User Says Thank You to DouglasABaker For This Useful Post:
J Irwan (8th May 2010)
Instructions for Thermostat Replacement? Any With Pics? Anita E39 M5 and E52 Z8 Discussion 25 6th January 2014 04:19 AM
Thermostat Replacement - San Diego Locals Help? VetteRacer E39 M5 and E52 Z8 Discussion 0 30th June 2009 11:03 AM
Thermostat replacement?? Finesta101 E39 M5 and E52 Z8 Discussion 5 30th November 2008 07:50 PM
Few pics for you lot...... [line example pics Ringtaxi through AF for Scoopz ;) ] Stevie E60 M5 and E61 M5 Touring Discussion 12 1st August 2007 02:06 AM
Report from Geneva, a lot of pics (Updated 13th March with 911 GT3 & Turbo pics/info) Gustav E60 M5 and E61 M5 Touring Discussion 71 1st April 2006 03:36 AM
