Secondary Air System Carbon Build Up Removal Pictures - Page 32 - BMW M5 Forum and M6 Forums
 36Likes
post #311 of 327 Old 4th November 2017, 11:59 AM
Sailor24
Sailor24's Avatar
Originally Posted by mgdmb View Post
I'm sure I've mentioned this at least once to someone before, but just code the AA out and call it a day...
I know we see things different but that is because of the climates we live in. In Calli it might be fine to code it out but up here in the great, not so cold as it was you are 10X better to do the by pass and have the engine heat up quicker. I was 9 min to temp before I by passed my SAP now I am 7 min. It is only 2 min but out of 7 min that is huge since 90% of the engine wear happens between start and warm. Conceivably that is 20% less wear. Where the car warms up in 7 min even if the SAP is not functioning then the SAP is moot, but in colder climates I think it is a big bonus but hard to know we have tons of 250K KM cars running up here the ones that fail all seem to have the SAP code.
Sailor24 is offline
post #312 of 327 Old 4th November 2017, 01:13 PM
CarbonCopy
CarbonCopy's Avatar
How does the bypass warm the engine up faster since you're bypassing the engine? Also this is false reasoning since an intact system steals heat from the heads to direct to the cats - that is the whole purpose of this engineering chicanery which is to get warmer air to the cats on start up to help start up emissions only. Am I missing something?
Sent from my HTC6545LVW using Tapatalk
CarbonCopy is offline
post #313 of 327 Old 4th November 2017, 03:26 PM
Ibmotoren
Ibmotoren's Avatar
Now for reference some guys will want to see Sailors bypass method and ensuing discussion. In this thread, starting here:
https://www.m5board.com/vbulletin/e39...ml#post5885002
2001 ///M5 ...Anthracite / Black Complete-Heritage
Ibmotoren is offline
post #314 of 327 Old 5th November 2017, 03:08 AM
Sailor24
Sailor24's Avatar
The air to the cats makes the cats react which creates heat. It has nothing to do with the air going thru the heads except you maybe right and that might cool it but likely the warmer air will react better in the cats returning heat to the engine faster. Once the cats are warm then that heat backs up to the engine instead of sucking heat from the heads and engine. You seem to have it backwards. Besides there is no arguing with the time difference on warmup and those tests were in the fall not even the winter.
Sailor24 is offline
post #315 of 327 Old 5th November 2017, 12:23 PM
CarbonCopy
CarbonCopy's Avatar
The only energy source in the cats is the chemical reaction aided by platinum to burn off unburnt hydrocarbons. Any exothermic reaction is not going to heat the exhaust and back up to the engine and heat the engine when the engine is the primary heat source many factors of ten greater. It's like saying the sun heats the planet Mercury and that Mercury somehow feeds back on the sun making the sun hotter. Again if you cool the heads by the air pump turning on you are cooling the engine and have a vector into the exhaust to draw heat from the engine in addition to the exhaust manifold. With the bypass the heads are clogged but the air pump is cooling the exhaust (now more than stock) allowing the manifold to stay slightly cooler longer. The only way I can explain your engine heating up faster is somehow the O2 sensors are now reading differently and changing engine parameters - or, your measurements were erroneous.
post #316 of 327 Old 5th November 2017, 03:04 PM
gsfent
gsfent's Avatar
Wouldn't adding water injection clean that mess up?
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #317 of 327 Old 5th November 2017, 06:47 PM
Sailor24
Sailor24's Avatar
Air pump stays on for only two minutes. The extra air going to the cats reacts with the very rich exhaust from start up. That makes heat. Since metal conducts heat it will travel, but none the less the heat from the engine is not robbed to heat the cats.
Your analogy is not even close to the same. The engine and cats are one and if heat is created in the cat it is the same as it being created in the engine.
Sailor24 is offline
post #318 of 327 Old 6th November 2017, 03:14 AM
herrubermensch
Easy answer: Block off your secondary air ports. They do nothing good from a performance point of view.
--Peter
herrubermensch is offline
post #319 of 327 Old 6th November 2017, 04:14 AM
tmaxx445
--Peter
What is the cleanest method to plug the ports? I know you can remove the air valve off the injection rail and block off with a OE blank plate from an N52 or similar but does anyone make actual blanks for the heads?
tmaxx445 is offline
post #320 of 327 Old 6th November 2017, 04:38 AM
herrubermensch
Yes! We do. $100/pair. Install with red loctite and appropriate sized socket.
--Peter
Cleaning Carbon in secondary air system DanQ E39 M5 and E52 Z8 Discussion 17 9th January 2016 07:01 PM
Secondary Air System, Valve Sticking mjshira E39 M5 and E52 Z8 Discussion 17 24th October 2013 01:50 PM
Secondary Air System - Not CBU everycredit E39 M5 and E52 Z8 Discussion 27 27th February 2008 02:17 PM
Secondary Cat Removal - HP and Noise Gains Wolverine E60 M5 and E61 M5 Touring Discussion 15 27th August 2007 09:52 AM
Concern: Supersprint Headers Coupled w/ Removal of Secondary Cats KeithTa E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 21st June 2006 07:24 PM
