Secondary Air System Carbon Build Up Removal Pictures - Page 24 - BMW M5 Forum and M6 Forums
 36Likes
post #231 of 327 Old 10th June 2015, 05:27 AM
Sailor24
Sailor24's Avatar
The clear tubing is vinyl. I use it because if you heat it to bend it, once cooled it holds its shape. It will melt if you put it on the header. Don't do that. The box was a left over made for a boat. It was 316 stainless done with a nasty to work with marine rod. Try something else. The threaded elbows were food grade stainless left over from an install at a restaurant. I think the fire suppression system.
You can using anything for the connection to the exhaust, I would stick to stainless but 304 will do the job. The plastic tubing must be able to bend and not kind as it gets warmer that is what is nice about vinyl it gets hard thru one heat cycle but softens again when warm, but forgets it was straight and only remembers it was curved.
Sailor24 is offline
post #232 of 327 Old 10th June 2015, 11:59 PM
The1stWright
The1stWright's Avatar
And here I thought it wasn't an issue with our beasts. I get error code 69 all the time. Is this something you guys would recommend doing or just flash the ecu and tune it out?
The1stWright is offline
post #233 of 327 Old 11th June 2015, 02:22 AM
Sailor24
Sailor24's Avatar
For a code 69 replace the t-stat or possibly the temp sender. If you are not one for testing just do both otherwise there are many posts on doing the tests and install on the board.
Sailor24 is offline
post #234 of 327 Old 11th June 2015, 04:10 AM
The1stWright
I meant that AA code sorry.
post #235 of 327 Old 11th June 2015, 04:52 AM
Sailor24
Sailor24's Avatar
Up to you. All i have shown is it can be done with other benefits. No need to be ripped off on a tune.
Sailor24 is offline
post #236 of 327 Old 11th June 2015, 10:58 PM
ngc5904
ngc5904's Avatar
I just had this done on my '02 M5, and it was either 37 or 39 hours, not counting the time the part was at the machinist.
'ngc5904'
2002 CF black M5/black lux interior
2001 525iT (wife's)
1992 Green 325iC (Sold)
1998 Yellow K1200RS
DSC: on/Sport: off (or on... )
ngc5904 is offline
post #237 of 327 Old 21st June 2015, 01:27 AM
thedocACSV8
thedocACSV8 is offline
post #238 of 327 Old 27th June 2015, 06:08 PM
2save
2save's Avatar
physic of hyper-ionization for clean up
Well here is a sample of the CLEAN UP work, (sorry not a BMW, but still clear, what we talking about) -
the technique that was used, calls "PowerCoding" and it's for entire engine, not just for the engine head.
2save is offline
post #239 of 327 Old 27th June 2015, 06:40 PM
mottati
mottati's Avatar
i'm missing how "power coding" does anything to the secondary air passages in the heads of an S62.
94 M5 Touring Madeira Schwarz, Black 10/93 production
84 728i - M88 powered
mottati is offline
post #240 of 327 Old 27th June 2015, 06:49 PM
2save
2save's Avatar
That's the point:
by the PowerCoding, there is no need to open and clean any of the modules or parts of the engine.
it's works by "normal" engine run, during the usual operation.
once it done, all is clean, and it was open (like on the pix) with an other reason, - the pix was shoted to show the result -
anyway how exact it works i guess it's to long to write all here .../ or ..?
2save is offline
Cleaning Carbon in secondary air system DanQ E39 M5 and E52 Z8 Discussion 17 9th January 2016 07:01 PM
Secondary Air System, Valve Sticking mjshira E39 M5 and E52 Z8 Discussion 17 24th October 2013 01:50 PM
Secondary Air System - Not CBU everycredit E39 M5 and E52 Z8 Discussion 27 27th February 2008 02:17 PM
Secondary Cat Removal - HP and Noise Gains Wolverine E60 M5 and E61 M5 Touring Discussion 15 27th August 2007 09:52 AM
Concern: Supersprint Headers Coupled w/ Removal of Secondary Cats KeithTa E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 21st June 2006 07:24 PM
