clutch break in - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 19 Old 30th September 2008, 04:42 PM Thread Starter
sbacchus
sbacchus's Avatar
clutch break in
just curious, for those of you that have installed a new clutch and followed BMW's break in procedure (800-1000 shifts), how long did it take you? i installed my new clutch yesterday and counted 95 shifts, but i was in traffic much more than i usually am.
sbacchus is offline
post #2 of 19 Old 30th September 2008, 06:48 PM
Edy07
Edy07's Avatar
Edy07 is offline
post #3 of 19 Old 30th September 2008, 07:04 PM
azaytsev
azaytsev's Avatar
It depends how much you drive. It took me almost 3 months to break in my new LUK clutch I put only 3K mi in a year
___________________
BMW CCA MEMBER#409490
Previous BMWs
2001 M5
1997 528i
1990 535i
1977 320i
azaytsev is offline
post #4 of 19 Old 30th September 2008, 07:05 PM
azaytsev
azaytsev's Avatar
___________________
Previous BMWs
2001 M5
1997 528i
1990 535i
1977 320i
azaytsev is offline
post #5 of 19 Old 30th September 2008, 07:59 PM
desaille
I just had a new LUK clutch and flywheel put in, other than clutch drops and burnouts, there really doesnt seem to be much for a breakin.
Its smooth as butter and pulls so nice.
Charlie
desaille is offline
post #6 of 19 Old 30th September 2008, 08:42 PM
TurboCarrera
same experience here.
Steve
00 M5
TurboCarrera is offline
post #7 of 19 Old 30th September 2008, 09:49 PM
jclyman
In Memoriam
jclyman's Avatar
From page 106 of the Owner's Manual:
The clutch will also begin to function
optimally after about 300 miles
(500 km). Engage the gears carefully
during the break-in period.
- Daniel Boorstin
jclyman is offline
post #8 of 19 Old 30th September 2008, 09:53 PM
desaille
The shop did a couple of 7K rpm clutch drops so I'm good
Its like anything, let it work in before you start to working it
Charlie
desaille is offline
post #9 of 19 Old 1st October 2008, 12:31 AM Thread Starter
sbacchus
sbacchus's Avatar
factory workshop manuals say:
Break in SAC clutches moderately to ensure correct operation.
Caution!
Fast sports driving maneuvers destroy new clutches!
Such maneuvers include:
• Driving maneuvers with high speed differentials
• Overlapping gearshifts with high speed differentials (slipping clutch)
• Very high starting speeds (e.g. when driving onto a transporter)
Comply with the following procedure when breaking in the new clutch:
- Break in friction linings with light to medium loads (observe breaking-in program)
- Normal driving with many "moderate" gearshifts
- Starting speeds on the level up to approx. 2000 rpm
- Specific breaking-in program on gentle gradients
- Starting speeds on a medium gradient up to approx. 2500 rpm (e.g. when driving onto a
transporter)
This procedure helps to create a carbon layer between lining and metal friction surface which
generates the required coefficient of friction.
Breaking-in
program:
• At approx. 30 km on roads
(specially for M5
and Z8)
• Shift through gears often Starting speed max.
2000 rpm
• Upshifts 1>2>3>4>5
• Downshifts at 2000 rpm 5>4>3>2>1
• Upshifts and downshifts at 3500-4000 rpm
• 3 to 5 times starting on gentle gradient (up
to approx.
12 %)
Starting speed max.
2500 rpm
Note:
Experience shows that approx. 800 to 1000 gearshifts are required for an optimally
broken-in lining when a car is driven "normally" (advise customer).
i'm at 145 changes today (can't believe i'm actually counting this stuff)
sbacchus is offline
The Following User Says Thank You to sbacchus For This Useful Post:
jclyman (1st October 2008)
post #10 of 19 Old 1st October 2008, 12:34 AM
desaille
I lost count at 1
Charlie
desaille is offline
New Clutch, What kind of break-in? Lite///Mup E39 M5 and E52 Z8 Discussion 2 19th August 2007 11:26 PM
break in for new clutch mubarak E39 M5 and E52 Z8 Discussion 4 27th October 2006 02:02 PM
new clutch break in? M5ROKIT E39 M5 and E52 Z8 Discussion 12 3rd June 2005 11:21 PM
What is the proper break-in for a new clutch? dmz E39 M5 and E52 Z8 Discussion 4 21st November 2004 01:24 AM
Proper way to break in the Sachs clutch? XrayMD E39 M5 and E52 Z8 Discussion 18 12th October 2002 04:55 AM
