Speedometer Lag - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By nosferau666
LinkBack Thread Tools Rate Thread
Old 10th July 2008, 04:39 AM Thread Starter
Jboud8880
Speedometer Lag
I pull up to a stop light just before entering the highway. I looked to my right and in the next lane was one of the road sloths (Camry). Just for fun I turned off the DSC and let it rip (sport mode always on).
The engine roared, tires spun and the camry pulled to the side of the road (must have gotten scared)...
Anyway, once tracion was established I turned onto the highway must have been pulling around 100 mph however when I looked down my speedometer was reading 45 mph.
Has anyone seen this before?
Jboud8880 is offline
Old 11th July 2008, 06:56 AM
PedM5
PedM5's Avatar
happened to me a couple of times, no explanation, doesn't happen every time but it's happend a few times. My gas gauge has a lag too, it won't register new gas till I turn the car on and off a few times
PedM5 is offline
Old 14th May 2019, 06:54 PM
707M5er
bump..... had this issue too the other day on hard acceleration ... noticing tach and speedo are laggy..... defective cluster? speed sensor? ABS unit? though mine was recently replaced.... any insight would be great! btw... no check lights on of any sort
707M5er is offline
Old 15th May 2019, 12:10 AM
jks540i
jks540i's Avatar
Not uncommon to see a latency in speedo and tach readings and the speedo usually reads 4-5 mph faster than you are going in a German car once this latency is overcome (manufacturers don't want to get blamed for speeding tickets). In your case it was probably worse due to spinning tires. Also not uncommon for sending units to stick or have bad spots in older cars. Mine doesn't register small changes, I usually brim the tank which also reduces potential for condensation inside.
jks540i is offline
Old 15th May 2019, 02:08 AM
nosferau666
nosferau666's Avatar
I have the same issue too. Only on hard acceleration from a dig. For example I'm at 100 mph, but the speedo shows 40... it normalizes when I stop accelerating. Really makes me mad and I have no idea what could cause that.
nosferau666 is offline
Old 15th May 2019, 10:04 PM
Redbird41
My speedo does the opposite. It will stick on a speed while the car slows down. I have to drive with a phone app to check my speed.
Redbird41 is offline
Old 15th May 2019, 11:49 PM
Tarnjot
Tarnjot is offline
Old 16th May 2019, 01:48 PM
nosferau666
Originally Posted by Tarnjot View Post
it did that to me yesterday. Im thinking its got to do with the speed sensor?
I was thinking the same but I don't get any codes. Shouldn't a defective speed sensor throw a code?
Old 16th May 2019, 08:05 PM
Ferris
Has anyone checked what Inpa reported, I think the cluster and DME both output it.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
Old 16th May 2019, 08:31 PM
Tarnjot
Hmm, good point. This only happens on M5's? I wonder if anyone with a 540 has it. If so does it only happen on ones with LSD?
Tarnjot is offline
Rate This Thread
Calculating Speedometer Error? MRichmond E60 M5 and E61 M5 Touring Discussion 3 10th July 2007 12:56 PM
Test drove the 335i bi-turbo today max berger E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 75 21st December 2006 12:43 PM
Speedometer Accuracy cam5wannabe E60 M5 and E61 M5 Touring Discussion 46 11th June 2006 11:29 PM
speedometer reading l8apex32 E39 M5 and E52 Z8 Discussion 1 18th November 2003 01:32 AM
Need a speedometer.....quick Steven E34 M5 Discussion 1 3rd January 2003 08:23 PM
