o2 / Oxygen Sensor Test How-To
24K views 11 replies 12 participants last post by  68FB
#1 · (Edited)
I was not able to find this thread on here so I am posting it.
Heres how you test the 4 lead Oxygen sensors that are found on our mistresses.
Tools Needed:
Vise or Vise grip
Torch
Volt Meter
Step 1
Disconnect and Remove the suspect o2 sensor using a 22mm wrench.
Step 2
Put the o2 senor in the Vise or Vise grips
Step 3
Connect the volt meter negative lead to the black wire on the o2 sensor
Connect the volt meter positive lead to the grey wire on the o2 sensor
Step 4
Set the Volt Meter to DCV 20V
Step 5
Light the torch and place the torch flame to the probe end of the o2 sensor (the perforated end) in such a way as to touch the blue flame cone tip to the probe wall.
Step 6
The volt meter should start to rise from 0 volts to approx. 1 volt within 20 seconds. This is the first test. If it passes, maintain the flame to the probe for a total of 2 minutes and make sure the voltage does not drop during that time by any significant amount. This is the second test. If it passes this test then remove the flame and the volt meter drop back to zero. This is the last test.
Step 7
If you have made this far successfully then your o2 sensor is operating correctly and does not need to be replaced unless you like wasting money. Buy a M hat, Wallet, and keychain instead and you will still have saved yourself some money.
Hope this is of use you!
Love, Peace and Chicken Grease!
Nathaniel
#4 ·
DEFINITELY DIY!!!! Never, ever, ever, ever pay a dealer to do O2 sensors, OK?
Now, you might consider a Peake reader to tell you which O2s are bad. But as a safe bet, just replace the pre-cat O2s on both sides.... Post cat O2s rarely go bad since they are not as challenged.
A
#6 ·
+1 a DIY easy project. Need a 22mm open end wrench and a 10mm socket to remove the plastic cover where the (O2 sensor connects). Be careful not to get any of the anti seize (pre applied on Bosch sensors) on the sensor itself.
Jeff
#7 ·
is it possible to clean your o2 Sensors to de-foul them? or will it damage the sensor..
something like Carb cleaner or liquid wrench or wd-40 etc..
#8 ·
The O2 sensor degenerates over time from exposure to the exhaust. They cannot be cleaned. The sensor burns away.
#9 ·
General information on the 4-wire O2 sensor:
- the two white wires are for the built-in heater
- the grey wire is earth
- the black wire is the signal
If the OP's suggestion of connecting black to negative and grey to positive will give a negative voltage readout (not that it really matters for the purposes of testing with a multimeter).
I believe this DIY is good for testing for things like circuit continuity and voltage readout range, but won't be of much use to determine if the O2's have become lazy.
#10 · (Edited)
Nor does it test the heaters, all that is really being tested is the lean reading which will be 1 on a failed O2 sensor. Common failure of the O2 is to report a leaner condition. Read that as the sensor will report more V than it should.
Not sure that this was being read until you brought it to the front page? Lol maybe you should have left it buried.
#11 ·
i should get this test done just to check ,i have emision fault ses light on the sensors after catalysts, but ive got told its because i have a SS exhaust on my car together with the SS cats which is known to create these bloody emisson ses lights that comes and go pretty often... some also say i need a tune to completely get rid of the SES light.
#12 ·
I have done this test on an old sensor and it worked well. Voltage shifted from 0.1 to 0.9 as the lean and rich parts of the propane flame were played on the sensor. But in the process, the thin metal shielding guarding the sensor glowed cherry red. That's over 800C. O2 sensors run about 500-600C so I would be worried about testing a good sensor, overheating it and turning it into a bad sensor.
Also as said above, it would confirm a sensor was stuck rich or lean or just dead, but it doesn't verify the switchover time used to identify if a sensor is lazy or not.
