Replacing Valve Cover Gaskets - Page 19 - BMW M5 Forum and M6 Forums
 17Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average.
Old 8th March 2016, 08:42 PM
M5Quest
Originally Posted by YucA View Post
Talking about the intake "horns" in the plenum? They are velocity stacks. Changing the length of these changes the intake tract length, which in turn changes where the engine makes peak power... Leaving them off will destroy your usable torque/power range.
It is pretty much like this without getting too deep: intake tract length from valve to intake "opening". Shorten the length and peak power moves UP the RPM range. Lengthen the tract, and peak power moves down the rpm range...
Thanks! I had no clue about this stuff! Looks like the E60 M5 doesn't have any horns in the intake box... Is that why the torque peak is higher in the rev band? Probably they couldn't implement it due to lack of space?
M5Quest is offline
Old 26th April 2016, 06:22 PM
mPower<3
mPower<3's Avatar
I tackled this project, replacing oil separators and spark plugs recently. It took 2 hours to take everything apart using a cordless ratchet. Took 8 hours to clean and put everything back together.
Passenger side was not too shabby, driver side was tight. Removing the screws that hold the oil filter housing helped in creating more space
mPower<3 is offline
Old 25th June 2016, 11:03 AM
Seedster
Seedster's Avatar
Agreed on OFH, I unbolted the bracket as well which helped. Took about 5hrs for me today but I was also doing the thermostat so I kept the intake manifold off when I don't with the valve covers. I thought the driver's side would be way more frustrating than it actually was.
Thanks to those that advised on watching out for the metal washers falling into and around the spark plug - in my paranoia I removed each one with a flathead in one hand and magnet in the other.
Seeing the CPS's and TPS's (I'm still on the stockers with 80K miles) so accessible with everything removed was a bit of a tease. I'll have to pull the manifold off again soon as it was a bit oily so/wet so separators need to be replaced.
Seedster is offline
The Following 2 Users Say Thank You to Seedster For This Useful Post:
CarbonCopy (25th June 2016), stickey (15th March 2017)
Old 16th July 2017, 04:54 AM
kiznarsh
kiznarsh's Avatar
I'm in the middle of replacing mine and I noticed the hex nuts for the velocity stacks are nylocks which should be replaced, but I didn't see anyone replacing them.
Is everyone just re-using theirs, or are people seeing regular hex nuts?
'03 M5 | 987.2 Cayman | @kian.ski
kiznarsh is online now
Old 16th July 2017, 01:07 PM
curtissp321
curtissp321's Avatar
Yes they are nyloc, reused mine once as it's rare to go that far in. Cheap to replace after a few removals.
Simon
curtissp321 is offline
Old 18th July 2017, 01:26 AM
thekurgan
thekurgan's Avatar
I always replace mine, they are one-time use per TIS and do some loose with heat cycles. They are cheap.
Ilse: 2002 E39M5 / TiAg / Tubi Rumore Stg 2 / E60 shifter / PowerFlex / Intravee II / KCA-420i / Jim Blanton 40% 3.45 diff / NCS coding / StrongStrut STB / Coby Alcantara wheel, shift and e-brake / Rogue Tranny Mounts / Mk IV / RK Plenum Plates
Bruna: 2000 E36/7 Z3 / Schwartz / RE RSM / NCS coding / M3 FCABs
BMWCCA #453648
"We're surrounded. That simplifies our problem of getting to these people and killing them." — Lewis B. "Chesty" Puller
thekurgan is offline
Old 20th September 2017, 08:42 AM
EddieM5CA
EddieM5CA's Avatar
Hi, everyone. New owner about 3 months now. Any DIY on how to replace valve cover gasket. Can't find any. Thank you.
EddieM5CA is offline
Old 20th September 2017, 02:29 PM
Ibmotoren
Ibmotoren's Avatar
lmgtfy
Check out the one by sheefo2k- a few links down the list.
You'll also want to get familiar with the DIY Sticky, there's a VCG DIY there as well.
Edit: Ehh, you're in the very thread that is the sticky DIY! Post #18.
2001 ///M5 ...Anthracite / Black Complete-Heritage
Ibmotoren is online now
Old 20th September 2017, 02:36 PM
EddieM5CA
EddieM5CA's Avatar
Originally Posted by Ibmotoren View Post
lmgtfy
Thank you. Will do.
Old 21st March 2018, 04:01 PM
grandmos
Originally Posted by CWY_M5 View Post
Okay, you asked for it, here's the Valve Cover Gasket DIY step by step:
Start – this is how the engine looks like:
  • Remove cabin air filter boxes
    • Remove cover
    • Remove clip and hood switch connector (driver side only)
    • Unclip boot to cabin filter housing
    • Remove cabin filter housing
    • Turn boot upwards (fragile fingers), then remove
  • Remove air intake boots, or entire air filter housing cover w/ MAF
    • Disconnect MAF connectors
    • Pay attention to cables tied to the intake boot (elbow)
    • Loosen hose clamp, and remove boot
Here’s how it should look like now
  • Remove 11 bolts on the plenum cover – DON’T DROP THEM. (size 10)
    • installation: torque to 5nm, inside first, then outside. Then to 10nm, inside first, then outside
  • Remove all the horns (size 8, 2 per horn)
    • Cylinder 1 and 5 are unique, all others are identical. Note their orientation, mark them before removing if you want to be safe
  • Loosen two screws that hold the oil separator to the plenum housing
  • remove (carefully) the oil separator from plenum housing
  • loosen hose clamp to the base of the oil separators, remove them (I cleaned mine with carb cleaner, they were filthy)
  • loosen hose clamp to the base of the plenum housing
Close up pictures, all 4 hose clamps shown
  • Remove screws (LOTS of them) that hold the plenum housing size 10
    • 16 on the driver side, 17 on the passenger side
  • Wiggle the plenum housing, patiently and slowly, it should detach
  • You should remove the intake gaskets at this point. Use a small flathead screw driver to remove hose clamp from the center of the engine
Picture shows passenger side with intake gaskets removed, right side still on. That’s what you see AFTER removing the plenum housing
Everything here on is similar on both sides
  • Remove ignition coil cover – 2x 10mm nuts
  • Remove all the ignition coils, 2 per coil 10mm nuts
  • Remove all ground wires (3x), and the nuts holding the ignition coil wires (2x)
Here’s where you are now:
  • Remove a whole bunch of valve cover gasket nuts (DON”T DROP THEM like I did) (10mm, tightening torque 7.5 ft-lb)
    • Driver side, remove the battery terminal nut (19mm?). Disconnect Battery in your trunk first.
    • Passenger side, remove the oil cap
  • Now the fun begin, pull, wiggle, grab from the front of the valve cover (where vent hose goes), and pull, wiggle, swear, pull some more, wiggle, and HOPE it comes off soon.
  • When it’s off, you’ll have to carefully pull things off, without scratching too much. Driver side is harder than passenger side – less room
Here’s what you should see on the passenger side when you remove
Valve Cover on the floor
  • Clean the grooves on the cover with metal wire brush
  • Clean the head joint surfaces with carb cleaner, ensure CLEAN
  • Apply silicon at 6 places
    • Where Vano housing joins the Head toward the front (2x)
    • Each of the 2 corners by the half round toward the back (4x)
Everything is now in reverse order.
See post #14 from M5Joe, that’s what got me thru with this DIY.
Cheers
(Above Drive/Passenger side is based on US LHD model)
Great DYI. Thanks.
grandmos is offline
Rate This Thread
Evap Purge Valve (Peake Code E8) Fixit Ben L E39 M5 and E52 Z8 Discussion 22 27th June 2015 07:04 PM
Where do the valve cover gaskets leak? derck_mullin E39 M5 and E52 Z8 Discussion 32 25th January 2014 08:44 PM
[WTB] 3.8 throttles and valve cover M_US_E30 Parts / Other For Sale or Wanted 0 5th August 2006 03:35 PM
oil leak stever E39 M5 and E52 Z8 Discussion 3 8th August 2001 03:07 PM
Valve cover gasket replaced brutus E39 M5 and E52 Z8 Discussion 0 2nd March 2001 04:23 AM
