M5 brake issues - BMW M5 Forum and M6 Forums
E39 5 series Forum Dedicated to the E39 5 series.
post #1 of 5 Old 8th January 2019, 08:39 PM Thread Starter
Hui
Registered User
Question M5 brake issues
I've owned my 2000 M5 for ten years and have just passed 98,000 miles. I've had a few issues in the past (de-carbon the heads,etc) but have run into an issue with the brakes which my mechanic cannot seem to solve. I initially thought I needed new pads, as the pedal travel became excessive. Nope. Pads were fine. My mechanic replaced the master cylinder and bled the system several times. Pedal regained firmness...for three or four uses, then sagged again. Also, the traction control turns itself off after a mile or so of driving (not that I use it much!). The mechanic thinks it may have something to do with an ABS pump(?). Any suggestions?
Hui is offline
post #2 of 5 Old 24th April 2019, 02:12 AM
mr_g_bock
I have been fighting this issue for over six months now, still not resolved.
This seems to be a common problem for quite a few people. I just got DIS v44 and v57 software that might help flush/purge the ABS/DSC unit, maybe... I can't work on my car right now as I have another car up on the lift. I may be a few more weeks.
Good Luck!
mr_g_bock is online now
post #3 of 5 Old 10th May 2019, 02:00 AM
fsubzero
Check your brake lines. I had brake issues with a 330xi and replaced so many things, except the brake lines. Replace the brake lines, fixed. My main issue was vibration and rotor warping. Simple thing like replacing the brake lines took care if it. I know not pedal sagging issue but thought would be good to throw this suggesuout for consideration.
fsubzero is online now
post #4 of 5 Old 14th May 2019, 11:50 PM
jks540i
jks540i's Avatar
If you aren't losing fluid you either have air in the system or a bad seal (like in the master). It can happen that master cylinder is replaced with a defective unit.
jks540i is offline
post #5 of 5 Old 16th June 2019, 03:40 AM
Maguiver
Maguiver's Avatar
I have had this happen before.
Maguiver is offline
E39 For Sale: e39 M5 Brake Calipers, Brake lines, And Brake Pads gbmwpower Parts / Other For Sale or Wanted 3 11th September 2016 11:39 PM
Brake Issues after Carwash Nabio E39 M5 and E52 Z8 Discussion 13 30th October 2010 10:32 PM
Brake Light (remaining on) issues... (PLEASE HELP fellas) Kevin The Clean 1 E39 M5 and E52 Z8 Discussion 9 20th August 2010 11:35 AM
Opening Up Brake Ducts with Dinan CAI and related issues herrubermensch E39 M5 and E52 Z8 Discussion 8 25th October 2008 03:18 AM
More Brake System Issues Richard in NC E39 M5 and E52 Z8 Discussion 0 26th January 2004 11:21 PM
