Clutch Chirp (Not Pedal) - BMW M5 Forum and M6 Forums
E39 5 series Forum Dedicated to the E39 5 series.
post #1 of 1 Old 5th September 2018, 02:51 AM Thread Starter
marko360
My car has suddenly developed an annoyance. I noticed the other night while driving with my windows down a squeak that sounds much like a chirping sound. I initially thought it could be a belt/pulley issue, but a little further investigation revealed its actually the clutch. Whenever the clutch is engaged regardless of gear or neutral, the chirp is there. As soon as it is disengaged, it stops. I can put a slight amount of pressure on the clutch (just the weight of my foot) and it goes away.
I have searched the forums and mostly what I have found is clutch pedal squeak. The clutch, flywheel, pressure plate, throwout bearing and brass pin were replaced about 7k miles ago. The clutch slave was not replaced.
Everything seems to be working fine. I haven't had a chance to get the car on a lift and really dreading having to possibly pull the tranny again. If anyone has experienced this or can provide a little insight on the possibilities, I'd really appreciate it.
marko360 is offline
chirpety chirp chirp stevie sam E34 M5 Discussion 13 18th August 2017 12:38 PM
Aircon Question - chirp chirp! keviha E34 M5 Discussion 15 24th May 2011 01:28 AM
installed new clutch and flywheel... still have chirp when shifting :-/ Jeuprx-8 E39 M5 and E52 Z8 Discussion 8 16th November 2008 02:42 AM
2nd to 3rd chirp chirp chirp... deknight E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 6 1st November 2006 06:49 PM
2nd to 3rd chirp chirp chirp... deknight E60 M5 and E61 M5 Touring Discussion 4 31st October 2006 11:16 PM
