Engine overheats when A/C is off, error codes P0491 and P0492 - BMW M5 Forum and M6 Forums
E39 5 series Forum Dedicated to the E39 5 series.
post #1 of 2 Old 8th July 2018, 03:12 AM Thread Starter
Dob3rman
Dob3rman's Avatar
Hi guys
2001 e39 540i
I replaced front bumper with an m-style one at a shop. After about 30 mins of driving, CEL light came on and the engine started overheating. I turned on the A/C and the engine temp went back to normal right away. With A/C on I also noticed that the cooling fan was spinning at a higher speed, so fan clutch is working well (but only with A/C on)
At home I ran OBD diagnostics and got these codes:
P0491 reported by 17
P0492 reported by 17
So the symptoms are:
1. When A/C is on, the engine temp is normal and the cooling fan is spinning at a higher speed
2. When A/C is off, the engine overheats and the cooling fan won’t speed up.
3. Error codes P0491 and P0492
Please help
Dob3rman is offline
post #2 of 2 Old 4th August 2018, 03:55 PM
kmalinich
kmalinich's Avatar
I've done a few swaps/replacements of aux fans and main fans of the on the S62 and M62 engines, and I don't think the mechanical fan clutch was controlled electronically in any way.. however, the aux fan (the electric one on the front of the radiator) definitely is, and is commanded on by the DME based on A/C load, radiator outlet temperature, intake air temperature, and vehicle speed.
Those OBD codes are for failure of secondary air injection, if that was working before, the pump probably came unplugged during the bumper swap. It's behind the fog light on the front passenger side of the car (LHD models).
If the mechanical cooling fan ISN'T spinning with the engine at idle, it sounds like the mechanical fan clutch may have failed.. although, I've only seen them fail to disengage, not fail to engage..but anything is possible. Could also be water pump issues, water pump not being driven properly by it's belt..
kmalinich is offline
P0491 suddenly throwing CEL on a UK car ?? adshead E39 M5 and E52 Z8 Discussion 15 21st May 2015 09:17 PM
P0491 Can't pass emmisions rxpx E39 M5 and E52 Z8 Discussion 5 10th April 2014 03:53 PM
[[HELP]] CEL light CODE P0492<----Anyone knows what it is?? nysid2007 E60 M5 and E61 M5 Touring Discussion 8 8th December 2012 02:48 PM
fault code P0491 - still safe to drive? CaptainChunk636 E39 M5 and E52 Z8 Discussion 30 7th March 2011 10:29 PM
P0492 Secondary air system. NEED FEEDBACK YamahaR1 E39 M5 and E52 Z8 Discussion 5 28th April 2009 02:40 AM
