ABS module rebuilt, DSC light still on - BMW M5 Forum and M6 Forums
E39 5 series Forum Dedicated to the E39 5 series.
post #1 of 3 Old 13th March 2018, 10:45 PM Thread Starter
StefV
2002 e39 M5.
The DSC light went on a little while back. Shop confirmed it was the ABS module, by swapping with a known good one.
Sent my module for repair to BBA Reman, reinstalled it, DSC light still on.
Should the light have gone off as soon as I put in the rebuilt module? Or is there anything else I need to do first, e.g. reset stuff?
StefV is offline
post #2 of 3 Old 15th March 2018, 06:00 AM
TheAngryBear
Were you only having the DSC light? Normally a faulty ABS module would give the trifecta (ABS, brake, DSC).
If it only your DSC then you should have your codes read again. Likely a steering angle sensor or yaw sensor fault.
This is also assuming you have validated the alternator output (should be 13.5-13.8 at idle and 14.2 at 2k), fuses, and grounds. For a simple way to check alternator output, use the “hidden menu” test 9.
TheAngryBear is offline
post #3 of 3 Old 19th April 2018, 05:53 PM
bimmerzeit
Once the rebuilt module is installed yes the lights go off right away. So it might be a steering angle sensor or speed sensor, do you have a scan tool to check the code?
https://youtu.be/Sb2QWHz5cIc
bimmerzeit is offline
E60 Want to Buy: ABS-DSC Module epiphanyray Parts / Other For Sale or Wanted 1 5th November 2018 08:59 PM
E39 Want to buy: E39 ABS Module- working/tested or new/rebuilt lockeed Parts / Other For Sale or Wanted 4 31st January 2018 04:45 AM
ABS Light. Dealer says DSC hydraulic unit and DSC ECU bya8 E60 M5 and E61 M5 Touring Discussion 34 13th December 2016 09:35 AM
ABS/DSC Module koolmofo E39 M5 and E52 Z8 Discussion 5 15th November 2013 04:32 AM
Rebuilt ABS module - fixed ABS and BRAKE lights - but DSC light still on. Codes inside absolutegtr E39 M5 and E52 Z8 Discussion 18 19th January 2013 07:12 PM
