Buying a 530i with a failed automatic trans and going to MT convert it. Questions... - BMW M5 Forum and M6 Forums
E39 5 series Forum Dedicated to the E39 5 series.
 1Likes
post #1 of 17 Old 7th December 2017, 01:23 PM Thread Starter
Obioban
Obioban's Avatar
Question Buying a 530i with a failed automatic trans and going to MT convert it. Questions...
So I'm buying a 2003 530i with a failed automatic trans, with the intention of swapping it.
Some questions, if you don't mind:
1) any good AT --> MT DIY guides with non broken photobucket pics out there? Ideally with a parts list, wiring changes, coding changes
2) Drive shaft-- will I need a different one?
3) Differential-- is the gearing going to be a problem? Or is it the same for both?
4) Is the 5mt from the e46 the same 5mt used in the e39? Bellhousing included? Can I use one of them without additional complications?
5) Assuming yes to (2), any reason I can't use a 6mt from a post facelift e46?
Thanks!
Obioban is offline
post #2 of 17 Old 15th December 2017, 09:44 PM
runfrodorun
runfrodorun's Avatar
I looked into doing auto->manual swaps in E31, and a quick google search confirms that the E39 is roughly the same deal: it's generally not worth it to do an auto->manual in an E39, there's just too many other non-suspect electronic parts in the car that depend on the auto transmission. You're going to spend 10k doing this. Please don't spend 10k swapping transmissions in a car that you can buy with a manual already in it for 5k. It's very involved and requires a lot of parts, and even then your dashboard is probably going to look like christmas.
You can get E39 530's and 540's for sub 5k, and 7k fetches some really nice ones with 5 inch binders of service records. Why not sell what you have and go that route? I have a 540 and I can honestly say that even with the timing guide fear, it's worth it.
runfrodorun is offline
post #3 of 17 Old 15th December 2017, 11:37 PM Thread Starter
Obioban
Obioban's Avatar
I got some pretty useful responses on bimmerforums.
https://www.bimmerforums.com/forum/s...5#post29901935
Looks like I can do the conversion for ~$400 in parts, including the trans.
I got this car for $450, and it's a nice example with a nice thick binder (including all new OE bushings and Koni yellows) other than the failed trans. Putting a new slush box in it will cost me $100, so I'm looking at an extra $300 and a couple hours to do the manual conversion. At the end, I'll have a car that's worth significantly more should I choose to sell.
Seems like an easy decision to me!
Obioban is offline
post #4 of 17 Old 16th December 2017, 12:19 AM
runfrodorun
Show your work. Where you're going to even get a high mileage used automatic transmission for an E39 for $100 is beyond me.
If I'm not mistaken, a manual swap requires at the very least the clutch/transmission assembly, the gauge cluster, and a canbus unit to spoof readings from the AT to make the ECU happy.
Hey man it's your money and your car, you can do whatever you want. Best case scenario you prove me wrong. I personally would not bother, if you want my personal opinion, I think that you're going to go into this thinking it's going to cost 400 dollars and be in for a not so nice surprise when it ends up costing way more, or even better it works, but every light on the dashboard is telling you the world is ending, even with some coding. I know E31 auto->manual swaps are a nightmare, and a quick google search makes it look like the E34 is the last 5 series that you would want to even attempt this on. I'm not sure I believe your $400 of parts figure for what it's going to take to put a manual in, so again show your work.
Again, maybe you'll prove me wrong, maybe you won't, but I don't see the point because IMO your best bet is to pick up a used working automatic transmission on ebay, install it, and flip the thing for a profit. If you really bought the car for like 450, you could probably sell it for 3k or more, and the money you make from that is enough to buy one with a manual unit in it. Your call. Dollar for dollar it makes more sense to not bother doing the swap unless it's for bragging rights.
post #5 of 17 Old 18th December 2017, 01:30 PM Thread Starter
Obioban
Obioban's Avatar
Lol, didn't mean to rile you up.
I would be getting parts here (all 3 locations are within driving distance of me), parts list with prices:
Price List | Harry's U-Pull It
There is no shortage of manual transmissions there any time I've gone (since I can use e46 5 or 6 speed manuals).
ECU I can flash for free, though you don't have to do anything on the e39
stock cluster is fine with a free flash
^neither is difficult-- just remove the autotrans from the VO, add the manual trans, reflash all modules.
trans is $100 post core return for either manual or automatic. They don't care if the core is manual or auto, as they just want it for the scrap metal
If I'm doing a manual conversion I also need
drive shaft ($20)
diff ($50) (not technically a need, but I dislike aggressive gearing)
slave cylinder ($10)
master cylinder ($13)
shifter ($10)
shift boot ($5)
Pedals: $15
clutch/pressure plate: $16
Flywheel: $18
Total: $247 for used parts
While I'm in there I'd also do rear main seal ($27), selector rod seal ($15), input shaft seal ($27), pilot bearing ($20), and throw out bearing ($55) with new parts.
^all new part prices from husker BMW parts if you want to check them: https://www.bmwdirectparts.com
Total: $144 for new parts
Total for project, used and new parts: $391
Hopefully I have sufficiently shown my work.
Obioban is offline
post #6 of 17 Old 18th December 2017, 11:22 PM
runfrodorun
drive shaft ($20)
shifter ($10)
shift boot ($5)
Pedals: $15
Flywheel: $18
No rifling.
Well again your car your money so I wish you the best of luck. But just saying, after the number of times I've done transmission/engine swaps, history is not on your side. You always spend way more than you think you're going to when you set out to do it, and it takes more time and effort than most people think when they set out to do it.
If you could do it for that much, I would be very impressed though.
Just consider how much better you are able to do if you were to repair the car /with an auto trans/ sell it and then use that money to buy one with a manual. Chances are you will come out on top in terms of $$$ and time. I'd be shocked if this was actually the economical option at the end of the day. You also don't have to worry about any jankiness since it's a fully factory setup.
post #7 of 17 Old 19th December 2017, 02:19 PM Thread Starter
Obioban
Obioban's Avatar
No rifling.
No jankiness in my e46 M3 converted wagon daily driver-- drives/functions 100% identically to my brothers stock e46 M3 (or my M3 coupe, back when it was stock).
Obioban is offline
post #8 of 17 Old 19th December 2017, 10:04 PM
runfrodorun
Respect... still dubious that it's worth it but post back when you're done how much it ended up costing and we'll see if you could have done better selling it as a working auto and buying a manual with the money.
post #9 of 17 Old 23rd December 2017, 03:34 PM
540Jason
540Jason's Avatar
DO IT!!! The only difficult part is the pedal assembly and wrestling the clutch line under the carpet. Other than those 2 things, it's just swapping parts and getting the manual reflash right.
Did a manual swap on my 540 4years ago and when the auto went out in my '98 528, it was at least $500 cheaper to convert it to manual than source another auto.
BTW, here's a link to the auto pin-out that will allow you to trick the auto computer to let the EWS to send a start signal to the DME.
https://www.justanswer.com/bmw/3qo4p...ission-sw.html
Summer:2001 540i w/ Premium, Sport, & Winter Pkgs.
Mods(in order done):35% tint, smoked repeaters, BMW lip spoiler, PanaVise dash mount, GROM IPod/Aux adapter, Kenwood amp powering 2 Pioneer Premier 10" subs, Stoptech SS brk hoses, lighted e38 interior door handles, muffler delete w/ Magnaflow tips, Eibach rear swaybar w/ BeastPower brackets, euro sliding armrest w/ storage tray, blue tint convex side mirror glass, 18x8/9 e39 spec style 69 whls, 6 spd manual swap, M5 diff, B&G springs, M5 steering box, EBC red brk pads, EBC slotted rear rotors, StopTech slot/drill frt rotors, aFe cai, DJ Auto lenses, replica Hella G4 bi-xenon projectors, metal tipped h/l adjusters, smoked amber corners, e53 dimming compass mirror, G.A.S. Monoballs, ECS brass caliper sliders, door coin box delete, 4" MAF, N62 TB, M60 intake manifold, DUDMD Tuning Stg 2 w/ SAP & EWS deletes, lower euro dash swap.
Winter:1997 528i w/ Premium Pkg.
Mods(in order):style 13 whls w/ General Arctic Max, PanaVise dash mount, 540i sport rear swaybar, dimming mirror, EBC black brk pads & rotors, manual swap, door coin box delete.
540Jason is offline
post #10 of 17 Old 29th January 2018, 01:19 AM
ryanman
ryanman's Avatar
ryanman is offline
E39 For Sale: UK Car (Scotland)- 2003 530i Sport Automatic DirtyHarry Cars For Sale or Wanted 0 12th July 2013 11:05 PM
Trans/Diff Fluid Change time. Questions nickl630 E60 M5 and E61 M5 Touring Discussion 10 8th June 2013 06:33 PM
Questions on buying an M5 JBss E39 M5 and E52 Z8 Discussion 10 2nd October 2007 05:41 PM
What questions do I ask before buying an M5? bmhusted E39 M5 and E52 Z8 Discussion 17 28th July 2006 10:51 PM
02 automatic lights questions Dallas Spikes E39 M5 and E52 Z8 Discussion 4 12th December 2001 05:14 PM
