Buying a 530i with a failed automatic trans and going to MT convert it. Questions... - Page 2 - BMW M5 Forum and M6 Forums
E39 5 series Forum Dedicated to the E39 5 series.
 1Likes
post #11 of 17 Old 29th January 2018, 02:43 AM Thread Starter
Obioban
Obioban's Avatar
Originally Posted by ryanman View Post
Any updates on this brother? How'd it go?
It’s been too cold to lay on the ground in the junk yard :P
I took my car apart. Waiting for a warmer day for part collection.
Obioban is offline
post #12 of 17 Old 1st March 2018, 08:40 PM Thread Starter
Obioban
Obioban's Avatar
Obioban is offline
post #13 of 17 Old 1st March 2018, 09:31 PM
xrviz
xrviz's Avatar
xrviz is offline
post #14 of 17 Old 3rd March 2018, 01:24 PM Thread Starter
Obioban
Obioban's Avatar
Spend $151 yesterday and got cluster, shifter, shift linkages, shifter sound deadening pad, shift knob/boot, driveshaft, slave cylinder, and differential.
Got pedals from Clemster already.
We had a mid day blizzard and I got cold, so I stopped before pulling the trans— will go back next week for that.
I believe I have every other part required for the swap, now
Obioban is offline
post #15 of 17 Old 19th October 2018, 09:41 AM
Levanibola
Hello. So here am I. I have done that allready. Manual conversion is not a problem at all but when you start driving it gets bad. So I have problem aboit rev hang when I lift from the gas and press cluth rpm jumps about 200 when I do that. Also cruise control stopped working in 1 week. Everything beside that is okay.
Also about conversion. Bmw e46 trans is the same. Manual driveshaft is different also the diff is different auto driveshaft doesnot connect to it and manual driveshaft dowsnot connect to auto diff. You can change the linkage from manual 2.93 diff to automatic 3.46. I have video on my youtube channel how 3.46 drives if you want check it out. Bola Films. Center bearing is the same and guibo is same. You have to do some changes in wires underneath the steering wheel in EWS because it wont start without that. Then you will need programing work to let it know that it is manual. You have to turn off on dash that PRND light you dont have to change cluster. I think that is all. Also you wont have reverse lights but you can wire it with relay.
Levanibola is offline
post #16 of 17 Old 19th October 2018, 01:06 PM Thread Starter
Obioban
Obioban's Avatar
Obioban is offline
post #17 of 17 Old 19th October 2018, 06:59 PM
Levanibola
Great. Do you have instagram or something where I can contact you ? Or if you can answer here. Does your rpm jumps when you shift gears ?
E39 For Sale: UK Car (Scotland)- 2003 530i Sport Automatic DirtyHarry Cars For Sale or Wanted 0 12th July 2013 11:05 PM
Trans/Diff Fluid Change time. Questions nickl630 E60 M5 and E61 M5 Touring Discussion 10 8th June 2013 06:33 PM
Questions on buying an M5 JBss E39 M5 and E52 Z8 Discussion 10 2nd October 2007 05:41 PM
What questions do I ask before buying an M5? bmhusted E39 M5 and E52 Z8 Discussion 17 28th July 2006 10:51 PM
02 automatic lights questions Dallas Spikes E39 M5 and E52 Z8 Discussion 4 12th December 2001 05:14 PM
