Brake Pad Thread, for 345mm M5 & CSi floating disks and 324mm e32 4-pot calipers - Page 7 - BMW M5 Forum and M6 Forums
 4Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average. Display Modes
post #61 of 169 Old 4th June 2008, 05:58 PM
Mmm-Five
Registered User
Mmm-Five is offline
post #62 of 169 Old 4th June 2008, 05:59 PM
mottati
mottati's Avatar
a less expensive option than the late 3.8 brakes is using 840 calipers and rotors, the calipers are 4 piston units made by brembo. The rotors are a little bigger, i want to say 324mm, but that's from memory. There was a pair of these calipers on ebay that sold for over $700! (i checked with my friend at my local dealership parts dept and found i could buy them brand new for just a bit more than that).
There are a set on ebay.co.uk right now, but the shipping would probably make them more expensive than buying new.
the later 3.8 4 piston calipers are quite expensive new.
94 M5 Touring Madeira Schwarz, Black 10/93 production
84 728i - M88 powered
mottati is offline
post #63 of 169 Old 4th June 2008, 09:46 PM
bmwm5lover
bmwm5lover's Avatar
How many pistons are my current calipers?
Looks like I might just end up buying some Zimmerman Slotted/Drilled rotors, some Hawk pads, and stainless steel brake lines with some nice brake fluid and call it done.
Might not be worth my while to got hrough all the trouble, the M5 stops well enough as it is.
What about e32 750 calipers/rotors? Will they work?
His--'00 BMW ///M5 .:Jet BLK/BLK:.Individual-Style 65 Wheels; 9.5" Square Set up;275 Tires;Spacers;Black Kidneys;Muffler Delete; 3.5" Dual Tips; Beast Power; "Dinan" Ducts; E60 SSK; BC Coils *love*
Hers--'07 BMW M5/6.:Indianapolis Red/Black:.
Toys
'91 BMW 850i J Spec-ST Tuning Kit- Lowered-Wokke Chips- Custom Exhaust- 18" MK1's-KN Filters+ M Steering Wheel- Stereo Upgrade +++
'88 BMW 635CSi
'81 MB 500 SEC Koenig
88 BMW 750iL
bmwm5lover is offline
post #64 of 169 Old 4th June 2008, 10:15 PM
bubba966
bubba966's Avatar
bubba966 is offline
post #65 of 169 Old 4th June 2008, 11:28 PM
mottati
mottati's Avatar
a 3.6 has a single piston caliper. I agree that they work pretty well for street use. My e39 has a stoptech bbk, and the e34 has much better brake feel stock than the e39 can ever hope to have.
mottati is offline
post #66 of 169 Old 5th June 2008, 02:12 AM
rapiddecline
I have a 92 3.8 and I waited untill a pair of calipers came up for sale then bought, painted and fitted them to my car. After discussions with darren from DARJAC it was recommended to put new rotors and pads into the second hand calipers. When I was looking around I only found the 850 had the larger rotos with the four pot caliper not the 840. I hope this helps
andy
rapiddecline is offline
post #67 of 169 Old 9th June 2008, 11:15 AM
Jägermeister
Jägermeister's Avatar
Exclamation
Originally Posted by GoneAgain View Post
Update on the Ferodo pads.
Picked up a full set of DS2500s for 150quid from circuit supplies.
However the fronts (FCP646H) are about 1cm shallower than original.
They fit the caliper no problem and the pistons do not overlap the bottom of the pad. But just how less effective will they be. i figure they will still be better than OEM! Will have them fitted before ring trip.
The rears (FCP578H) are spot on.
I am bringing this thread back from the dead, since I am researching brakepads for my Touring, I am not happy with the OEM pads. Also the Touring is getting Goodridge brake hoses...
How were the FCP646H pads on the Ring? Do you feel that the 1 cm missing on the pad is an issue when braking?
Not to be a party-pooper, but isn't FCP857 / FDS857 the correct part number from Ferodo?!
Have a look here:
http://www.elcome.co.uk/fmecat/fsp/C....asp?pn=FCP857
Just change the part number at the end, and you can easily compare the pads! The 578-pad is for a bunch of BMWs...
'95 M5 Touring Fjordgrau (Almost bone stock!).
'86 Chevrolet Camaro Z28 IROC-Z (MODIFIED!).
Jägermeister is offline
post #68 of 169 Old 10th June 2008, 11:27 PM
bmwm5lover
bmwm5lover's Avatar
Just to confirm.
If I was to use the 750 4 pot(piston) calipers on my 3.6 M5, do I use the 324mm rotors or the 345mm rotors?
Toys
'88 BMW 635CSi
88 BMW 750iL
post #69 of 169 Old 10th June 2008, 11:30 PM
bmwm5lover
bmwm5lover's Avatar
Just to confirm.
If I was to use the e32 750 4 pot(piston) calipers on my 3.6 M5, do I use the 324mm rotors or the 345mm rotors?
Toys
'88 BMW 635CSi
88 BMW 750iL
post #70 of 169 Old 11th June 2008, 12:36 AM
Chewbacca
Chewbacca's Avatar
Just to confirm.
Original 750 324mm rotors.
Kind regards,
Tobias
Chewbacca is offline
