Brake Pad Thread, for 345mm M5 & CSi floating disks and 324mm e32 4-pot calipers - Page 5 - BMW M5 Forum and M6 Forums
 4Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average. Display Modes
post #41 of 169 Old 11th February 2007, 04:07 PM
Johntee540
Johntee540's Avatar
I may be confused. The guy I bought them new from had a 7 series 740 he was putting them on. That was the e32. They may have come from an e31 however I havent seen an e31 that has these calipers on them.
These are stamped Brembo on the back. They are 4 pots. They bolted right on. I am also using the Porterfield Rotors and Pads. They are the Rotors from the 850. The rears are the ATE Calipers that came on the 540 / M5. I am just using the Porterfield Rotors and Pads there. I bought the kit from a guy whose car was lost in Katrina.
It included the bearings; Sensors; Rotors; Pads; Calipers; Backing Plates; Rotor hold bolts; and Brakleen! All new Parts. I got them all for $1,800 from the Roadfly classifieds.
I track the car and the car stops really well - and the heat issues have totally gone away. I am using the Stock Master Cylinder. My most amusing moment was at my last track event where a Porsche followed my waaaay deep into the corner before braking and tried to use the same brake marker I did. I braked, downshifted, apexed and rolled out - only to look in my rear view mirror to see the Porsche bail and take the escape road. Talked to him later - he said he was going waaaay too fast and couldn't slow for the turn like I did. - JT
Johntee540 is offline
post #42 of 169 Old 4th March 2007, 07:06 AM
BigKriss
I just noticed that on my e32 pads and rotors that the pads slightly go over the rotor. Maybe the ferodo pad is perfect for the e32 750 calipers.
http://www.bimmer.info/forum/showthr...537#post243537
Originally Posted by GoneAgain
Update on the Ferodo pads.
Picked up a full set of DS2500s for 150quid from circuit supplies.
However the fronts (FCP646H) are about 1cm shallower than original.
They fit the caliper no problem and the pistons do not overlap the bottom of the pad. But just how less effective will they be. i figure they will still be better than OEM! Will have them fitted before ring trip.
The rears (FCP578H) are spot on.
BigKriss is offline
post #43 of 169 Old 31st March 2008, 05:07 PM
D_T_W
D_T_W's Avatar
Pagid Blues Unavailable for 4 pot caliper
Tried CA Automotive, they said Pagid don't make them for the big brakes. That's a bit of a bugger, as that's what i wanted to put on.
So, what pads should be going in then? Ferodo DS2500?
Cheers
Mark
D_T_W is offline
post #44 of 169 Old 31st March 2008, 05:17 PM
Mmm-Five
Registered User
Cheers
Mark
Try Demon Tweeks before you give up - they might be more expensive, but you're only asking for availability after all.
I'm finding (albeit on all 4 wheels and on the 3.6) the DS2500 to be less inspiring than the DS2000. I'm sure they'd come into their own on a track, but I've done some quick country road blats and not felt they've been up to much - although this could be due to having puny brakes now
Unfortunately the DS3000 needs a 'lot' of heat for best performance and the DS2000 creates a lot of dust, but the DS2500 seems to produce a lot of dust, and take a good bit of heating up - plus they squeal.
Personally, I'd use two sets (they're quick to change on the big brakes anyway) - DS3000/2500 on track and swap out for DS2000 on road).
Mmm-Five is offline
post #45 of 169 Old 31st March 2008, 05:25 PM
D_T_W
D_T_W's Avatar
No luck with Demon Tweeks either. He did say that if i could send him the pad shape he could contact Pagid and ask, but by the time that's all done it will be too long a wait.
It's mainly for road use, with a trip to the 'ring in May, so i think i'll just have to go for the DS2500, they can't produce any more dust than the standard pads!!
Cheers
Mark
D_T_W is offline
post #46 of 169 Old 31st March 2008, 08:18 PM
legacy260
legacy260's Avatar
EBC Reds are pretty good. I have some on my car and the dust is minimal and the stopping power is much improved over standard pads. EBC have raised their game recently!
"Life's journey is not to arrive at the grave safely in a well-preserved body, but rather to skid in sideways, totally worn-out,shouting, 'Holy sh*t! What a ride!'"
E34 M5 LE 20/50 Rosso Red
legacy260 is offline
post #47 of 169 Old 31st March 2008, 09:14 PM
Phlem5
Mark, I was going to suggest mintex per ecm4's recommendation - https://www.m5board.com/vbulletin/showthread.php?t=55597
but whilst reading his post's I found that more recent threads suggest, as Richard does, ebc reds or yellow's.
If you're going to try Demon Tweeks, it might be worth asking if carbone industrie produce a pad for the 4 pot calipers - they produce a sintered metal pad for fast road and track, which sounded quite interesting in their catalogue.
Cheers.
btw, more than happy to price up any o.e. stuff you are looking for.
Phil.
Phlem5 is offline
post #48 of 169 Old 1st April 2008, 01:04 AM
M540i LE
M540i LE's Avatar
Pagid Blues have recently been made for the big brakes (about 12-18 months ago). I can't recall exact details, but there was a special order completed by a crowd somewhere near the 'Ring and an offer was made on this site.
This offer was taken up by a number of members here who now have them fitted to their cars.
Do a search for 'pagid blues' and I am sure details will emerge.
Good luck.
David B
Register of the 524 RHD 3.6 E34 M5's made - http://autos.groups.yahoo.com/group/E34M5RHD-register/
Register of the 70 540iLE's made - http://autos.groups.yahoo.com/group/BMW540iLE/
M540i LE is offline
post #49 of 169 Old 1st April 2008, 01:24 PM
D_T_W
D_T_W's Avatar
Either the guys i've spoken to are a bit useless, or not many people know that the E34 M5 came with a 4 piston caliper
CA Automotive were very helpful, but they said they didn't know anybody who made an aftermarket pad for the big brakes , however my Rogue Engineering transmission mounts will be here Thursday . I very nearly got offered a deal on the Rogue quickshift kit, but again it won't fit the 6-speed box.
Demon Tweeks were not quite as helpful, seemed to want me off the phone rather quickly, but i think that might have been down the fact is was nearly 5pm and they wanted home. I'll try them again today and see what they can suggest. They didn't list the M5 as having Ferodo pads available, so it's rather narrowing my options. Might just go for the EBC Red stuff and see what they are like.
Quick question relating to that. Is it worth skimming the discs before putting the new pads in?
Cheers.
If it's ok i'll drop you a mail near the end of the week, i'm building up a bit of a parts list at the moment, and i need to speak to the garage when i pick the car up later this week about a couple of things. Might be a bit of a long list though!
Cheers
Mark
D_T_W is offline
The Following User Says Thank You to D_T_W For This Useful Post:
erikm54life (2nd April 2008)
post #50 of 169 Old 1st April 2008, 02:16 PM
FinalEditionE34M5
FinalEditionE34M5's Avatar
I've got some Blue Pagids I bought a couple of years ago from Kons.
I'm fitting the last set (I bought multiples) to my car tonight, along with some new front discs - I'll take some pictures beforehand and hopefully there may be some part numbers on them.
Does this mean they're no longer available for the 'Big Brake' 343mm rotor-ed cars from 1995 ?
TK.
TK.
___________________
FinalEditionE34M5 is offline
