Brake Pad Thread, for 345mm M5 & CSi floating disks and 324mm e32 4-pot calipers - Page 2 - BMW M5 Forum and M6 Forums
 4Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average. Display Modes
post #11 of 169 Old 13th November 2006, 06:58 PM
GoneAgain
GoneAgain's Avatar
Originally Posted by Sebring NL
If they are recommended by the E34 Testing Center at the Nürburgring Meuspath, I'll take their judgement any day..
I need those pads...Need the rotors first though....Kidney, anyone?
Still need the calipers don't you??
GoneAgain is offline
post #12 of 169 Old 13th November 2006, 07:11 PM
Sebring NL
Sebring NL's Avatar
Yes..Can't hardly sleep about it!
Sebring NL is offline
post #13 of 169 Old 13th November 2006, 07:25 PM
Chewbacca
Chewbacca's Avatar
Originally Posted by Stevie
Pagid RS42 (made to special order by batch, PM member Konstantin for availability)
Ferodo DS 2500: FDS 856 (rear FDS 857)
EBC RedStuff: DP 3886C (rear DP3871C)
Anyone know of others?
As Terry already said: FDS856/857 are for the single pot calipers (156.50 x 69.60 x 18.50 mm for 840i/850i and old Maserati ).
I found FCP1298 to be the correct shape, but they seem too big ?! (119.80 x 54.60 x 18.00 mm) - but those pads are also listed for the 850?!
Kind regards,
Tobias
Chewbacca is offline
post #14 of 169 Old 13th November 2006, 07:31 PM
GoneAgain
GoneAgain's Avatar
I have spent much time searching the Ferodo numbers.......no luck yet?
I emailed the contact DaveW posted in another thread , but haven't heard back.
post #15 of 169 Old 14th November 2006, 12:59 AM Thread Starter
Stevie
Stevie's Avatar
That size is correct for the Brembo 4-pots used on some regular e31 with 324x30 discs......
Will try to find a different Ferodo number for the fronts. Can I assume 857 for the rear is correct? 4 different manufacturers all state identical pads for 850CSi and regular e31.....
Stevie is offline
post #16 of 169 Old 14th November 2006, 02:38 AM
BigKriss
Sorry not high performance, starndard replacement.
Is this a high performance pad or just standard replacement?
BigKriss is offline
post #17 of 169 Old 14th November 2006, 11:42 AM
Chewbacca
Chewbacca's Avatar
FDS857 are listed with 123.00 x 54.80 x 17.00 mm, I'll have to look back home if I still got some old pads to cross-check.
Kind regards,
Tobias
post #18 of 169 Old 14th November 2006, 01:12 PM Thread Starter
Stevie
Stevie's Avatar
Pagid lists the same size for rear of 850CSi
Stevie is offline
post #19 of 169 Old 14th November 2006, 10:52 PM
GoneAgain
GoneAgain's Avatar
Had a couple of emails from Tim at http://circuitsupplies.com/.
The price for the DS2500 pads is £84.10 plus VAT, which seems pretty good to me. So I've ordered a set. He's checking availability wth the factory. But he hasn't given me the part number yet.
He also said that
part numbers starting "FDS" refers to Ferodo "DS
Performance" pads. These are a fast road pad only, and made within the confines
of a regulation called R90.This states that these pads are, amongst other
things, within plus/minus 15% performance of the OE pad for that particular
vehicle.
DS2500 on the other hand, is outside the scope of R90, and is approx 40% better
than OE pads. It is designed for "track day" use.
DS2500 should not be used on road cars, registered from 2000 onwards.
The exceptions to this, is where it is used in a brake upgrade,IE DS2500 is
supplied in all AP Racing "Formula" brake kits, as AP have found it to be the
best pad, for this application.
post #20 of 169 Old 21st November 2006, 06:31 PM
GoneAgain
GoneAgain's Avatar
Update lads.
Been talking to Tim at circuitsupplies.com, very helpful guy.
Ferodo DS2500 pad is part number FCP646H.
Price is £98.82 inc VAT and UK delivery.
he doesn't normally stock them but he does get a delivery from the factory almost every week.
Also he can get DS3000 compound for 92.50 + VAT and delivery. but these may take some time as they would be special order.
T
Stevie, do you think it's a reasonable idea to edit your first post to include all the correct part numbers?
