Cam timing pictures - is this okay? - BMW M5 Forum and M6 Forums
post #1 of 9 Old 19th May 2019, 06:08 PM Thread Starter
E30isKing
Hello everyone,
Want some help regarding cam timing. I put a thicker MLS gasket and timed the motor but one of the marks (intake) is slightly off, but as you know we are limited to changing a teeth in the sproket so I want to know if you consider this difference acceptable?
Actually, a little less overlap is not too bad for a turbo engine...
Here are the pictures - crank is at TDC, Exhaust cam is spot on and Intake cam is the one slighly off.
Slightly off intake
Spot on exhaust
Another picture of intake
Thanks for your help.
Paulo
E30isKing is offline
post #2 of 9 Old 21st May 2019, 10:12 AM Thread Starter
E30isKing
Anyone please?
Car doesn't start and I would like to rule out the cam timing if I can...
post #3 of 9 Old 22nd May 2019, 04:23 AM
MileHigh427
Hate to say it but this forum is a ghost town. I say ask your question on one of the Facebook pages. Lots of knowledge in the e34 m5 club, bimmerforums e34 crew pages. You’ll get a much quicker answer there.
MileHigh427 is offline
post #4 of 9 Old 22nd May 2019, 09:45 AM
Tomba
Your timing is slightly off (advanced) but not within a tooth of the cam sprocket.
Does it inject fuel and does the spark plug work while starting?
Advanced intake timing in general dis-improves idling and top end torque/power but improves mid range torque.
And indeed, not much people posting here last few years. Which (Facebook) pages are recommended for (E34) M5?
To///Mba
Tomba is offline
post #5 of 9 Old 22nd May 2019, 04:40 PM
MileHigh427
Bimmerfourms.com E34 Crew (USA mostly)
E34 Zone (Euro/ mostly)
Neither of these are M5 specific but a lot of active users with e34 knowledge
The BMW M5 E34 Club- World wide. A good source for questions like this and a lot of the M5 board forum members are on these pages.
Sadly the ads on this site make it boarder line un-useable. I wanted to start a "build" thread here but decided against it. Mainly because using this site is annoying and I'm a terrible writer.
post #6 of 9 Old 28th May 2019, 01:08 AM
6stang9
6stang9's Avatar
Send Bmwdirtracer a private message to respond to this thread also. He is on here but moved to the E39 forum with his new car.
Home of the Silver Bimmers: '91 M5,'99 E36, '98 E36, '84 Euro E24, E46 xiT
6stang9 is online now
post #7 of 9 Old 8th June 2019, 06:19 AM
Maguiver
Maguiver's Avatar
Totally normal when installing a MLS gasket. I have assembled 2 motors like this and they ran just fine. You could get slotted gears if you want it perfect.
Maguiver is offline
post #8 of 9 Old 8th June 2019, 03:25 PM
alpinerunner
I agree that that is definitely within reason.
1990 M3 - Weekend/HPDE
1991 M5 - Weekend
2003 M5 - DD
2012 X5 35D - Wife/family car
alpinerunner is offline
post #9 of 9 Old 19th June 2019, 04:40 PM Thread Starter
E30isKing
Thanks a lot! Its running again.
Problem was with the mapping in the ECU - crank and cam trigger settings.
Time to boost this bad boy!
DIY: Vanos spring plate renewal jamiepeers E39 M5 and E52 Z8 Discussion 143 17th October 2017 04:37 PM
Cam timing question D'Amorem5 E39 M5 and E52 Z8 Discussion 7 14th January 2017 04:24 AM
zed.inc's Hamann M5 zed.inc E39 M5 and E52 Z8 Discussion 66 28th April 2014 04:29 AM
Vanos noise or Timing Chain noise MYM05 E39 M5 and E52 Z8 Discussion 92 26th July 2011 04:27 PM
