DIY: 91 M5: Removing oil pan - BMW M5 Forum and M6 Forums
post #1 of 6 Old 21st September 2018, 03:38 PM Thread Starter
jstokley
I have a 91 M5 with the 3.6 engine. Is it possible to remove the oil pan without removing the engine? If it is possible, what precautions do I need to do? There is no oil pressure and I want to check out the pump. Thanks for any thoughts.
jstokley is offline
post #2 of 6 Old 21st September 2018, 06:24 PM
davidl
davidl's Avatar
I recently did this one my 3.8 to replace the oil pan gasket. In this case I was working on a lift. I have done this on jack stands as well. The transmission was in place. We used an engine support bar that mounted to the front engine lift point. This bar runs from fender to fender. An engine hoist would work as well. I then removed the bolts from the subframe and let hang down to provide more room to remove the pan. I had to remove a bolt from a steering component as well to let the subframe drop. There was something else in the way by the sway bar that had to be moved as well. It did take some finagling to get it back in.
David
95 M5 Red on Red cloth/Alcantara
Former '91 M5 Silver on Grey
davidl is online now
The Following 2 Users Say Thank You to davidl For This Useful Post:
jstokley (22nd September 2018)
post #3 of 6 Old 22nd September 2018, 01:23 AM Thread Starter
jstokley
hi Davidl,
Wow, that was quick. Thanks so much for your response. I can see where dropping the subframe has advantages over pulling the engine. Now, I need to cobble-up an engine support bar. I'm assuming that the engine does not move vertically, so I ought to be able to leave connections such as coolant hoses in place. Also if the subframe is lowered, I should also be able to replace the engine mounts, one of which is pretty spongy due to oil.
Thank you again,
John
jstokley is offline
The Following 2 Users Say Thank You to jstokley For This Useful Post:
davidl (22nd September 2018)
post #4 of 6 Old 22nd September 2018, 01:29 AM
davidl
davidl's Avatar
I did lift the engine a bit but did not need to disconnect anything up top. I also replace engine mounts at that time. I second set of hands help when putting the subframe back in place. Also having the wheels removed.
David
post #5 of 6 Old 8th June 2019, 03:41 AM
alpinerunner
John (jstokley), I have to do this exact job due to no oil pressure. I just ordered an engine support bar. What did you find out about your oil pump?
1990 M3 - Weekend/HPDE
1991 M5 - Weekend
2003 M5 - DD
2012 X5 35D - Wife/family car
alpinerunner is offline
post #6 of 6 Old Today, 03:06 PM
Beerplease
Subframe
Just did mine as well, used a support bar, it's a must. Other than one of the subframe bolts snapping off it was relatively easy. Steering rods from both ends, sway bar needs removed and the horizontal bolt the hold the PS pump to the mount(kinda a pain to reach the nut, I removed everything and dropped the drivers side down an inch to gain access). There are guide tubes on both sides that locate it to the fram can be stubborn to get but a little tap with a wooden block/hammer on the corners of the subframe freed mine. Oh don't forget the oil level sensor wire, and there are a couple hidden bolts on the pan too. Also the smog pump adjusting bracket will need one bolt pulled that attaches it to the pan. Took maybe 45 minutes to get everything off and removed.
Beerplease is online now
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Beerplease
E39 For Sale: Belly pan and transmission pan tradin1 Parts / Other For Sale or Wanted 7 14th February 2018 06:41 AM
Opinions wanted on first oil change. (self) Removing Oil Pan for Inspection The Engineer E60 M5 and E61 M5 Touring Discussion 5 19th November 2014 03:07 PM
Took off my front skid plate to install a new oil pan (oil consumption or oil leak...?!) blks4 E39 M5 and E52 Z8 Discussion 7 19th August 2011 10:34 AM
F/S e39 M5 Brand New Front Fender Liners and Front protection pan, skid pan Nolift911 Parts / Other For Sale or Wanted 14 3rd December 2008 03:17 PM
OIL OIL OIL OIL OIL OIL sulaiman E60 M5 and E61 M5 Touring Discussion 9 13th March 2006 01:30 PM
