Inpa - which version to access 3.8 dme - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 14 Old 10th July 2019, 10:05 AM
Tomba
Originally Posted by DiegoR View Post
Thanks Tomba, yes we have here in the shop Fluke professional volt meters/scope meter (voltage) etc. So no issue there, but thanks for pointing it out.
Do you have links on where can I source these components? It's too confusing for me right now. I don't have a old laptop with serial port though and I think certain system won't work with a SERIAL-USB adaptors.
Thanks!
You will need some hardware (interface) to connect between your laptop and the diagnostic socket of your car.
These older cars also need some compatible interfaces to work with BMW software. I mainly use my ICOM A2 or and old ADS interface.
First we need to know which software and hardware you currently have. I can supply software and recommend an interface for you.
Tiny ADS interface
https://openlabs.co/store/Tiny-ADS-Interface
In case you don't have a serial port on your laptop/pc
Simple DIY ADS interface schmatic - BMW forum. Diagnostics, coding, programming, repair BMW vehicles.
With Teamviewer we can make it work.
To///Mba
Tomba is offline
post #12 of 14 Old 10th July 2019, 06:26 PM
DiegoR
DiegoR's Avatar
Tiny ADS interface
Thanks. I can't register ( disable by admin) so can't check the PDF or info attached in the second link provided. I do have a ISTA with round connector but it doesn't talk with the dino e34 at all. Nor my Autel Pro scanner.
You mean with ISTA can be possible?
Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
DiegoR is offline
post #13 of 14 Old 11th July 2019, 08:59 AM
Tomba
I doubt ISTA will work. Likely DIS or very early version ISTA.
Best thing for now would be to order the ADS interface. I can get you the documents.
With ADS interface you should be possible to enter airbag module with INPA. Otherwise a Virtual machine with DIS.
To///Mba
Tomba is offline
post #14 of 14 Old 11th July 2019, 03:44 PM
DiegoR
DiegoR's Avatar
Great, I will PM you. A friend gave me his DIS with virtual machine/laptop but it doesn't enter in the e34 either, I suspect something wrong set in the virtual DIS it's happening. I know a old Launch X431 or something like that (those with the LCD grey display) works with the e34 SRS system as I did it once.
DiegoR is offline
INPA Version 5.0.2 specialized2010 E60 M5 and E61 M5 Touring Discussion 0 28th December 2017 01:45 AM
Does anybody in the SF Bay Area have access to INPA....???? Sfbimmerman E60 M5 and E61 M5 Touring Discussion 3 23rd July 2015 11:35 PM
Need access to INPA, DIS, GT1, Autologic, etc... technician117 USA Northeast Forum 4 12th July 2015 03:03 AM
Latest DME software version and SMG software version.. 5soko E60 M5 and E61 M5 Touring Discussion 15 21st December 2013 05:31 AM
what is your INPA version? michael33 E60 M5 and E61 M5 Touring Discussion 0 29th October 2013 06:28 PM
