Anyone using a Quickjack for their E34? - BMW M5 Forum and M6 Forums
 5Likes
post #1 of 14 Old 28th December 2017, 04:55 AM Thread Starter
MaxThrust
This one:
https://www.pelicanparts.com/catalog...ack%2520Models
I am planning on picking up a BL-5000SLX which will fit an air-cooled 911. Wondering if it will work dimensionally on an E34...?
Thanks!
MaxThrust is offline
post #2 of 14 Old 28th December 2017, 11:50 PM
6stang9
6stang9's Avatar
It says it is rated to 3,5000 lb. That is not enough for the M5. Sure do not want to chance a failure, no matter how unlikely if you plan to be under it...
I would go for the next one at 5,000lb.
Home of the Silver Bimmers: '91 M5,'99 E36, '98 E36, '84 Euro E24, E46 xiT
6stang9 is offline
post #3 of 14 Old 29th December 2017, 12:14 AM Thread Starter
MaxThrust
post #4 of 14 Old 29th December 2017, 01:10 AM
JohnAnthony
JohnAnthony's Avatar
have you checked the distance for the jackpads on the E34? For the E39 you need the EXT model to work.
If the EXT is too long for the Porsche, you can also use the system by orienting it perpendicularly:
https://www.youtube.com/watch?v=JyO7oSiqBSo
As for the product itself, it's okay; it's certainly not a substitute for a 2-post lift. Ranger/Quickjack is filling a niche for people with cars that don't have central jacking points for the front and/or rear. The setup is quicker than a 4 jack stand setup, but it's very tedious. The two biggest drawbacks are having to align the two units, and storing them. Quickjack suggests storing the units standing up, but if you don't have a way to tie them up, it gets risky in a tight garage space.
JohnAnthony is offline
post #5 of 14 Old 29th December 2017, 03:44 PM
6stang9
6stang9's Avatar
Just curious: where would you locate the rear pads on the M5?
6stang9 is offline
post #6 of 14 Old 29th December 2017, 04:50 PM
JohnAnthony
Doesn't the E34 have 4 jacking point along the rockers/sideskirts?
ref:
https://www.m5board.com/vbulletin/e34...-back-now.html
The only issue I see, is the rubber pads that come with the quickjack are too large to fit factory jacking points. I would NOT recommend cutting the rubber pads since they are already VERY soft.
post #7 of 14 Old 29th December 2017, 05:37 PM Thread Starter
MaxThrust
Iím going to check the measurements later on my car and see if they will work. Iím betting they will. The E34 is not a HUGE car.... and I donít want to do the sideways-jacking thing with these, Iíd rather go front-to-back.
ref:
There are other options for jack pads, even if they arenít sold by QuickJack. There are all kinds out there. Just a matter of looking for something of the right dimensions and material.
post #8 of 14 Old 1st February 2018, 01:17 AM Thread Starter
MaxThrust
Here’s a photo from a member here on M5Board who uses a Quickjack BL-5000SLX on his E34 M5 (jack points are ~51 inches apart) - looks like a quick, easy and safe way to get your car 21 inches off the ground:
post #9 of 14 Old 3rd February 2018, 08:12 PM
hchinaski
hchinaski's Avatar
That's my car, my garage, and my Quickjacks 5000slx. Works great! I place the rubber blocks directly underneath the jacking points. I was at first worried about damaging the plastic rocker covers but the car has been up on the jacks many, many, many times now and no issues. I feel really safe under there, much better than the car wobbling about on jack stands.
1991 E34 M5 black/gray
1989 E32 750iL nonemoreblack
hchinaski is offline
post #10 of 14 Old 4th February 2018, 07:20 AM Thread Starter
MaxThrust
Thank you for sharing. Much appreciated. I have done a lot of looking around and these seem like a very versatile option.
Cheers!
Opinions on the Quickjack Ferris E39 M5 and E52 Z8 Discussion 14 27th July 2016 12:22 AM
E32 740i , what parts fit the E34 M5 and E34 530i 5 speed manual ? AseanAero E34 M5 Discussion 4 5th April 2013 04:55 PM
Future BMWCar Mag feature E34 M5 vs B10 BiTurbo, stock E34 3.8 needed! GreatWhite E34 M5 Discussion 41 5th May 2008 04:51 PM
Ivan - 1990 E34 M5 3.6 & 1989 E34 535i Sport manual IvanDias Owners Gallery 0 26th January 2002 10:27 PM
