Odd water leak in my 93 - BMW M5 Forum and M6 Forums
LinkBack Thread Tools Rate Thread
Old 13th July 2017, 05:07 PM Thread Starter
Jbeinhor
Hi All --
I'm experiencing an odd water leak in my 93 M5 -- after a heavy rainstorm, I noticed water in the driver side footwell. I tested my sunroof drains -- all are completely fine. I poured water down the cowl and all over the windshield and could not replicate it. It appears to be comin down my clutch pedal! Definitely water though -- not coolant. Thoughts? I noticed some new very light surface rust in a very bizarre location -- under the hood by the firewall. Could it be related?
Thanks!
Jbeinhor is offline
Old 13th July 2017, 05:09 PM Thread Starter
Jbeinhor
Jbeinhor is offline
Old 13th July 2017, 07:47 PM
GregT53
GregT53's Avatar
Two thoughts: the access cover for the blower motor could have a deteriorated seal (although you would think that this could be replicated); a/c drains could be clogged. If you are not seeing much or any condensate hitting the ground when the a/c is running then it's likely backing up and trying to create a foot bath for your driving comfort.
GregT53 is offline
Old 13th July 2017, 08:22 PM
GregT53
GregT53's Avatar
On rereading your post I see it's a leak after a heavy rainstorm so nix those two thoughts.
Have you checked the roof drain attachment? They are a b**** to get at but it might be worth a look. Unlike newer BMWs, the E34 drain attachments are pretty robust, but after 25 years anything is possible. Also, your sunroof cassette could be cracked. So, even though your drain is clear water might be dribbling down the A pillar and finding a path over to your pedal. Pull the A pillar cover and check for dampness.
Remove your cowl trim strip and have a look at your windshield seal.
Instead of pouring water down the drains try fixing a hose on top and let water run over the sunroof for 30 minutes. I would think if the leak is coming from the top you should be able to replicate it with that test.
GregT53 is offline
Old 14th July 2017, 03:12 AM Thread Starter
Jbeinhor
Thanks, Gregg. Sunroof cassette is in great shape -- no leaks or cracks there -- and I used a hose for about five mins on the upper part of the windshield and got nothing. I think you're right about the cowl -- I should pop it out and check the condition of the bottom of the windshield seal.
Jbeinhor is offline
Old 14th July 2017, 08:16 PM
zuggerat89
zuggerat89's Avatar
I think looking at the base of the cowl is a good call, lots of crevasses for water to creep into.
Was your 93 an outside car or garaged when you found it?
zuggerat89 is offline
Old 14th July 2017, 08:29 PM Thread Starter
Jbeinhor
Outside, but covered. Rest of the car is immaculate. I'll report back after pulling off the cowl. I saw some leaves and other stuff down there I need to dig out anyhow.
Jbeinhor is offline
Old 5th August 2017, 04:46 AM
zuggerat89
zuggerat89's Avatar
When you pulled your cowl off did you have black silicone near the center under where the two halves meet?
Old 7th August 2017, 07:54 PM Thread Starter
Jbeinhor
I will report back when I get the car back -- it's at the shop having the accumulators replaced.
Jbeinhor is offline
Old 7th August 2017, 09:05 PM
zuggerat89
zuggerat89's Avatar
Gotcha, thanks.
Rate This Thread
FI / SC owners: Help with odd boost leak/vac hose blowing off Redshift E39 M5 and E52 Z8 Discussion 11 18th February 2016 06:05 AM
Water leak Gus E39 M5 and E52 Z8 Discussion 6 24th January 2015 11:28 PM
odd water leak under dash 4heid E34 M5 Discussion 4 24th September 2013 03:53 AM
Tranny leak - odd location 4heid E34 M5 Discussion 7 2nd September 2013 06:22 PM
Odd oil leak after cooler install SpeedAgent E60 M5 and E61 M5 Touring Discussion 7 12th April 2013 07:35 AM
