S38B42 Up and Running Stroker - BMW M5 Forum and M6 Forums
 43Likes
post #1 of 71 Old 13th December 2015, 12:16 AM Thread Starter
davidoli
After much R&D and a few hurdles the 4.2 stroker build is up and running .
She just has to be mapped and a few little extras and she's good to go .
It's been along time coming , but on the few short drives that I've had so far she feels like a highly spirited E34 M5 .
More details to follow , basic spec ;
95mm bore
98mm stroke
12:1 CR Pistons
H beam rods (147.5mm iirc )
Raceware Head Stud Kit
Mls head gasket
Bespoke Exhaust Manifolds
Bespoke Stainless Decat exhaust with x pipe
4.5kg Chromoly Billet Flywheel
Uprated Sachs Clutch
Larger alloy rad .
6 speed brakes .
91 Sebring 3.6 | E28 UK RHD M5 | E34 UK RHD 3.8 | E34 M5 Touring | E24 M635CSi UK RHD
www.classicmdautos.co.uk
davidoli is offline
post #2 of 71 Old 13th December 2015, 01:11 AM
AseanAero
AseanAero's Avatar
Great to hear some news on this project David
Have you calculated the dynamic compression ratio and what fuel will you be using ?
Depending on cam timing the DCR will be high with 12:1 CR and a longer stroke
Any ping problems ?
This should be conservatively a 390 to 400hp motor by my calcs with more available with software changes, 315 to 320 RWHP
It Will be good to get some knowledgable comments on this stroker conversion from someone dong it and not theory
Mid range torque should be awesome
Tony, Aussie expat in Jakarta Indonesia
1990 E34 M5 S38B36 GA25324
GA25324
1995 E34 540/5 Project
AseanAero is offline
post #3 of 71 Old 13th December 2015, 08:34 AM
Ferrari-Bmw
David,,,, is this the OZ ppf stroker kit ??
Sveinbjörn Hrafnsson
E30 CABRIO V12 M70B50 ///
ALPINA B10 BITURBO 346 @ 507
E34 550 V12 JML
http://alpina.123.is/pictures/
Ferrari-Bmw is offline
post #4 of 71 Old 13th December 2015, 09:17 AM Thread Starter
davidoli
Hi guys .
Yes , this is the Aussie PPF Kit after a number of discoveries and alterations to get it up and running .
In the uk there are only a few petrol stations that sell >97 ron fuel .
Ideally we want to run on the highest octane available and at present it's got 99 ron fuel in the tank .
My man is currently looking at the fuelling and will be mapping her after a run on the rollers.
For now , I am simply overjoyed to have her up and running and getting her through a uk ministry of transport test , including emissions test .
See video of initial running ;
E34 M5 S38B42 Stroker:
http://youtu.be/xNfBPVQOpPg
davidoli is offline
The Following User Says Thank You to davidoli For This Useful Post:
CSBM5 (27th December 2015)
post #5 of 71 Old 13th December 2015, 01:33 PM
AseanAero
AseanAero's Avatar
David ,
Stock , Shrick or custom cams ?
Some calculations on water / methanol injection
http://www.aquamist.co.uk/vbulletin/...read.php?t=294
GA25324
post #6 of 71 Old 14th December 2015, 09:24 AM
MattH
MattH is offline
post #7 of 71 Old 14th December 2015, 10:04 AM
BlueBiturbo
BlueBiturbo's Avatar
Amazing project David. Keep us posted.
It is said that if you line up all the cars in the world end to end, someone would be stupid enough to try and pass them.
BlueBiturbo is offline
post #8 of 71 Old 14th December 2015, 10:14 AM
AseanAero
AseanAero's Avatar
Any more info on this David ?
This is not a plug and play stroker kit ?
GA25324
post #9 of 71 Old 14th December 2015, 07:46 PM
Ferrari-Bmw
Why not... new crank and rod+pistons... and the block rebored
E34 550 V12 JML
post #10 of 71 Old 15th December 2015, 12:46 AM
AseanAero
AseanAero's Avatar
David said "After much R&D and a few hurdles the 4.2 stroker build is up and running ."
"Much R+D and a few hurdles" doesn't sound like it was an easy bolt in
What I want to know is this crank , rod and piston related or other engine components
GA25324
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
gosch , sharkfan
poor running / running rich throttle bodies? skeggy E39 M5 and E52 Z8 Discussion 0 20th September 2010 05:02 PM
Which Stroker Should i Go for? Boodzz E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 57 17th September 2010 12:27 PM
Video: Nooelle BMW M6 stroker (Dinan stroker) vs Evotech RS6 BiTurbo Evotech 700 HP vs Ferrari 575 Maranello Gustav E60 M5 and E61 M5 Touring Discussion 14 27th August 2009 10:34 AM
Video: Noolle BMW M6 stroker (Dinan stroker) vs Evotech RS6 BiTurbo Evotech 700 HP vs Ferrari 575 Maranello Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 3 19th August 2009 03:01 AM
45 minutes discussion with Dinan on the V10 stroker engine + news that there will be a stroker Dinan M3 V8! Gustav E60 M5 and E61 M5 Touring Discussion 24 30th December 2008 01:12 PM
