S38B42 Up and Running Stroker - Page 4 - BMW M5 Forum and M6 Forums
 48Likes
post #31 of 76 Old 21st December 2015, 01:16 AM
AseanAero
AseanAero's Avatar
Correct , the intake valve is now closing at around 94 deg ABDC compared to the stock cam at 70 deg ABDC causing less cylinder pressure.
Engine is going to be lumpy as hell and a bit of a pig at low rpm
Tony, Aussie expat in Jakarta Indonesia
1990 E34 M5 S38B36 GA25324
GA25324
1995 E34 540/5 Project
AseanAero is offline
post #32 of 76 Old 21st December 2015, 01:54 AM
bmwdirtracer
davidoli; your engine is magnificence. It's truly over -the-edge, in the very best way. Where others just blow in it, you've taken the S38 to its highest form, in the way we all love. Thank you, and please, forever know that you're the best!
And I'm fine with blowing in it, too. done by the right guy....with as much love as davidoli has!
Chris Powell
BMWCCA 274412
3x recertified Master Tech
Racing, skid, and HPDE instructor since 1978, for Brands Hatch, Skip, SCCA and BMWCCA
bmwdirtracer is offline
The Following User Says Thank You to bmwdirtracer For This Useful Post:
davidoli (23rd December 2015)
post #33 of 76 Old 21st December 2015, 04:01 AM
BlueBiturbo
BlueBiturbo's Avatar
So... If I want to make the same 4.2 stroker but with a normal 10:1 or 10.5:1 compression ratio, what cam shoud be enough ? I will use mainly 94 octane fuel. Thanks.
It is said that if you line up all the cars in the world end to end, someone would be stupid enough to try and pass them.
BlueBiturbo is offline
post #34 of 76 Old 21st December 2015, 10:39 AM
AseanAero
AseanAero's Avatar
I need to run the numbers but I suspect it will be 284 deg cams
GA25324
post #35 of 76 Old 21st December 2015, 03:43 PM
AseanAero
AseanAero's Avatar
Taffy , B42 stroker should be ok with stock cams and 10.5:1
If you wanted a bit more safety margin go with some Shrick 284 cams
GA25324
post #36 of 76 Old 22nd December 2015, 10:35 AM
gosch
gosch's Avatar
I do not understand how you come to 94 °. I calculate the 291 ° Cat Cam at 110 ° lobe angel with timing 75.5° / 35.5°
gosch is offline
The Following User Says Thank You to gosch For This Useful Post:
post #37 of 76 Old 23rd December 2015, 12:12 PM
AseanAero
AseanAero's Avatar
Me too , you are correct 75.5 deg ABDC
Putting the correct ABDC into the wallace racing DCR calculator means David's S38B42 will need 98 to 100 octane fuel (DCR approaching 9)
GA25324
The Following User Says Thank You to AseanAero For This Useful Post:
post #38 of 76 Old 23rd December 2015, 08:56 PM
thadoggfatha
thadoggfatha's Avatar
thadoggfatha is offline
post #39 of 76 Old 24th December 2015, 08:44 AM
THUNDER
THUNDER's Avatar
Just WOW !!!
Waiting impatiently for pics AND video ...
SOLD: 1991 E34 M5 3.6 (e38 M Parallel's + Chip + deCat + Iridium spark-plugs + Xenon)
THUNDER is offline
post #40 of 76 Old 26th December 2015, 10:13 PM
GazM3
Sounds orsome David. The 291cam will feed the high 12:1 comp nicely. The cam is still low in valve lift so it's not too crazy. I actually like the lopey idle.
Did I hear correct that you are using a remapped OEM computer?
This engine could be massively enhanced with a good off the shelf engine managment computer. Firstly sequential injection could tone down the idle significantly and with the high comp if you run it with the aid of a wideband exhaust sensor you could get better than factory cruise fuel economy out of it and still make well over 400bhp depending on how high u are prepared to rev the long stroke engine.
Orsome work for having the balls to build this.
I'm doing a s38 rebuild shortly. Have 13:1 ppm pistons, all new timing chain components haltech computer. Just deciding how big I want the cam and whether it will be e85 only or drop the comp to mid 12's and have the ability to run Ron98. It's going in my m635csi. I'm taking out the m88/3 and storing it as it's the original engine number.
GazM3 is offline
The Following User Says Thank You to GazM3 For This Useful Post:
CSBM5 (27th December 2015)
poor running / running rich throttle bodies? skeggy E39 M5 and E52 Z8 Discussion 0 20th September 2010 05:02 PM
Which Stroker Should i Go for? Boodzz E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 57 17th September 2010 12:27 PM
Video: Nooelle BMW M6 stroker (Dinan stroker) vs Evotech RS6 BiTurbo Evotech 700 HP vs Ferrari 575 Maranello Gustav E60 M5 and E61 M5 Touring Discussion 14 27th August 2009 10:34 AM
Video: Noolle BMW M6 stroker (Dinan stroker) vs Evotech RS6 BiTurbo Evotech 700 HP vs Ferrari 575 Maranello Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 3 19th August 2009 03:01 AM
45 minutes discussion with Dinan on the V10 stroker engine + news that there will be a stroker Dinan M3 V8! Gustav E60 M5 and E61 M5 Touring Discussion 24 30th December 2008 01:12 PM
