DIY - Blower Motor Replacement - BMW M5 Forum and M6 Forums
 5Likes
post #1 of 11 Old 12th July 2015, 04:37 PM Thread Starter
stilljester
Greetings,
Decided to finally tackle this project yesterday. My blower motor was working at all speeds but at certain settings had developed a squeaking noise (bearing failure) which my radio was working harder and harder to drown-out. Additionally, I still had a faint funky smell even after I removed the mouse nest I found in the cabin filter last month.
Overall the job took me 3.5 hours, but at least an hour of that time was spend cleaning.
Before proceeding I searched for other post and found a couple which I felt were helpful. I would suggest giving them a read in addition to this thread as I have tried not to duplicate directions.
Other Posts
Good overview of the steps, however removal of intake is not needed.
1- Piancu's Blower Motor Replacement
Good overview with pictures; not M5 specific
2- Gale's BMW Repair Page
My Process
1. Remove wiper arms, cowling plastic and engine bay rubber trim.
2. Remove the 10mm plastic nuts which secure the wiring harness tray and cut the zip / cable ties in order to free the harness
3. With the cable tray removed you next remove the bulkhead insert. This part is held with 5 screws (8mm?) I would suggest using a magnet to catch the screws on the bottom.
4. Remove the 10mm nut which secures the vacuum lines.
5. With the wiring harness pulled back and the bulk head insert removed you will now see this plastic cover with is lightly glued on, simply pull it off.
6. Release the white strap and two clips on the bottom to remove the access cover to the blower motor.
7. Voila! Your blower motor. [You can see clearly my two issues - bearing failure (left side) and mouse nest (right side)
8. Clean!!! Take the opportunity to hose everything down and remove the 20+ years of grim which has built up in the area. As you can see in the photo I also removed the cabin filter in order to have direct access to clean the coils.
9. Temporarily tape the straps up and out of the way.
10. To install I put the right wheel in first then pivoted the blower motor counter-clock wise to then push the left wheel in second. Be gentle, yet deliberate and the plastic will deform to allow for insertion.
11. Remaining steps are the reverse of removal. Enjoy!
stilljester is offline
The Following 2 Users Say Thank You to stilljester For This Useful Post:
de Witt (13th July 2015), Ubersaloon (14th July 2015)
post #2 of 11 Old 12th July 2015, 04:42 PM
Bumbaclut
Bumbaclut is offline
post #3 of 11 Old 12th July 2015, 04:54 PM Thread Starter
stilljester
Originally Posted by Bumbaclut View Post
Nice work, is that blower motor new it looks it? Where did you buy it from?
Brand new - I figured "replacement" would be a pleasure I'd only allow myself one time.
OEM part purchased from ECS Tuning - BMW Part number 64118390935.
post #4 of 11 Old 12th July 2015, 05:54 PM
bmwdirtracer
In case anyone has not heard last week's announcement, ECS Tuning has just purchased Turner Motorsport. (sorry to digress from this excellent DIY)
Chris Powell
BMWCCA 274412
3x recertified Master Tech
Racing, skid, and HPDE instructor since 1978, for Brands Hatch, Skip, SCCA and BMWCCA
bmwdirtracer is offline
post #5 of 11 Old 12th July 2015, 08:51 PM
Eero H
Eero H's Avatar
Just few days ago i replaced mine. It was Siemens type, little different than yours. I did not remove wipers or plastic under wipers.
Eero H is offline
post #6 of 11 Old 12th July 2015, 09:53 PM Thread Starter
stilljester
Nice job and thank you for posting the photo of the Siemens unit for comparison. I thought about not removing the plastic under the wipers but I was concerned that I could inadvertently break it off while working back there. Good to know its possible to make the swap with it in place.
post #7 of 11 Old 13th July 2015, 06:24 AM
Eero H
Eero H's Avatar
Maybe Siemens unit is slightly smaller.
Eero H is offline
post #8 of 11 Old 13th July 2015, 07:53 AM
de Witt
de Witt's Avatar
Is there any way to tell which one is installed in the chassis without cracking it open? Or can the siemens one be swapped with the other one?
de Witt is offline
post #9 of 11 Old 13th July 2015, 12:03 PM
Eero H
Eero H's Avatar
Yes, multiple clues.
-Remove radio and see inside. There might be ticker that says manufacturer, i have Siemens sicker.
-Siemens have fan resistor in right (passenger) side, Behr, Bosch or Valeo has left side in driver footwell. Or if "sword" type resistor then maybe Behr, Valeo or Bosch.
-Siemens heater core is horizontal and WITHOUT AC, Behr and Bosch vertical and with or without AC. Valeo horizontal without AC.
Driver side footwell Siemens
Driver side footwell Valeo
Driver side footwell Behr etc. resistor
Passenger side footwell Siemens resistor, blue hole
Siemens resistor
Bosch, Behr etc resistor
Sword type resistor
Eero H is offline
The Following 2 Users Say Thank You to Eero H For This Useful Post:
de Witt (14th July 2015), Spyder (14th July 2015)
post #10 of 11 Old 13th July 2015, 12:11 PM
Eero H
Eero H's Avatar
I think no. Siemens has different mounting, there is bolt hole and that rubber part that goes inside fan shroud.
Eero H is offline
The Following 3 Users Say Thank You to Eero H For This Useful Post:
Blower motor replacement piancu E34 M5 Discussion 12 18th January 2014 09:24 PM
DIY: Blower motor replacement (video) zed.inc E39 M5 and E52 Z8 Discussion 4 15th November 2013 01:31 PM
FSU/Blower motor GBPackerfan1963 E39 M5 and E52 Z8 Discussion 0 11th May 2013 07:25 PM
Tank n Blower Motor Q's tsm E34 M5 Discussion 4 11th October 2012 11:10 AM
Motor mount and transmission mount replacement DIY? HarvesterOfBeer E39 M5 and E52 Z8 Discussion 7 21st July 2009 09:18 PM
