Building an 'M540' out of an E34 530i 5 speed - Page 2 - BMW M5 Forum and M6 Forums
 36Likes
post #11 of 186 Old 15th August 2013, 03:14 PM Thread Starter
AseanAero
AseanAero's Avatar
I think the M60 is a great little V8 , it loves to rev, it has a typical BMW power band ok under 4,000rpm but the fun happens from 4,000rpm to redline.
The old pushod V8s I had I would normally drop down 1 gear for overtaking , in the 530 I drop down 2 gears or whatevers necessary to get 4,000rpm
When I bought the 530 I said to Taffy I'm going to keep it stock but the temptation is too great to make it better.
Tony, Aussie expat in Jakarta Indonesia
1990 E34 M5 S38B36 GA25324
GA25324
1995 E34 540/5 Project
AseanAero is offline
post #12 of 186 Old 16th August 2013, 10:09 AM Thread Starter
AseanAero
AseanAero's Avatar
Rear tyre size ?
Better to go for 255 or 265mm wide tyres on the rear ?
GA25324
post #13 of 186 Old 16th August 2013, 10:30 AM
BlueBiturbo
BlueBiturbo's Avatar
You have 18 inch right ?
Go for 255
It is said that if you line up all the cars in the world end to end, someone would be stupid enough to try and pass them.
BlueBiturbo is offline
post #14 of 186 Old 19th August 2013, 09:56 AM
Fordkoppie
Fordkoppie's Avatar
I am sure you will need both the 540 maf and ECU/chip.
The flywheel/clutch assy will bolt on directly without any issues. My friend had a normal auto 540 and transplanted the flywheel, clutch, gearbox, diff, propshaft from a 530 to make it a manual. For some weird reason, the 540i 6 speed uses a 265mm clutch whereas the 530 and almost all other BMWs use a 240mm item. My Friend's 540 with the 530 geartrain lasted quite good, until he took it on a track where after the clutch was not so good anymore. My point being, that if you can moderately behave, it will last just fine with the smaller 530 item.
I have also fitted a 3.15 LSD from an e32 750iL to my 540i 6 speed individual and it makes the car feel much better even though it makes NO difference whatsoever on all out acceleration
Fordkoppie is offline
The Following User Says Thank You to Fordkoppie For This Useful Post:
AseanAero (19th August 2013)
post #15 of 186 Old 20th August 2013, 10:17 AM Thread Starter
AseanAero
AseanAero's Avatar
What is the best candidate 6 speed gearbox to swap in other than an E34 6 speed as we didn't get them here ?
GA25324
post #16 of 186 Old 20th August 2013, 04:03 PM
Fordkoppie
Fordkoppie's Avatar
AseanAero (20th August 2013)
post #17 of 186 Old 23rd August 2013, 10:39 AM Thread Starter
AseanAero
AseanAero's Avatar
E34 m5 3.91 lsd ?
Has anyone tried using a 3.91:1 ratio diff in an E34 M60 ?
Current ratio is 3.07:1
GA25324
post #18 of 186 Old 23rd August 2013, 10:55 AM
BlueBiturbo
Too high...
Max is 3.45:1 IMHO... that is from E34 535i Diff
post #19 of 186 Old 23rd August 2013, 11:09 AM Thread Starter
AseanAero
AseanAero's Avatar
Not convinced.
Getrag 260/5 BMW E34 M60
1st 3.83
2nd 2.2
3rd 1.4
4th 1
5th 0.81
Final drive 3.07
Getrag 280/5 BMW E34 M5
1st 3.51
2nd 2.08
3rd 1.35
4th 1
5th 0.81
Final drive 3.91
The M5 has the same overdrive but 700rpm more redline (6,500 vs 7,200). I don't need a super high top speed on the 540i project. The current 3.07 rear gear ratio is too lazy even as a daily driver.
I agree a 3.45 would be a better compromise but there's a 3.91 sitting ready outside. Try it out for a few months.
GA25324
post #20 of 186 Old 23rd August 2013, 12:40 PM
Fordkoppie
Fordkoppie's Avatar
Your ratios are wrong for the M60 5 speed. 5th is 1:1 ratio.
I have driven a 540 6 speed with a 3.64 LSD from the manual 535 and to be honest, I didn't like it at all.
The B40 is an engine that can be driven in a very relaxed manner and wringing it's neck the whole time feels wrong. It feels as if you are constantly stirring the gears, since I am used to change up @ 2000 rpm in mine while driving in normal conditions.
I just dont think it suits the nature of the 540.
I think the optimal ratio for the 6 speed would have to be a 3.23
E32 740i , what parts fit the E34 M5 and E34 530i 5 speed manual ? AseanAero E34 M5 Discussion 4 5th April 2013 04:55 PM
S62B50 in an E34 530i ? AseanAero E34 M5 Discussion 24 4th March 2013 04:30 PM
Installing B8 4.6 engine in E34 530i? jimmy01 ALPINABoard.com | BMW Alpina Discussion 25 14th June 2007 03:51 PM
FS: 2002 530i 5-Speed (Santa Cruz, CA) jvrinc Cars For Sale or Wanted 0 2nd May 2005 11:30 PM
M540 kees E34 M5 Discussion 11 30th July 2004 12:48 AM
