Oil thread with Lab Analyst - BMW M5 Forum and M6 Forums
 92Likes
LinkBack Thread Tools Rating: Thread Rating: 1 votes, 5.00 average.
Old 5th May 2012, 07:34 AM Thread Starter
First e28 M5
First e28 M5's Avatar
Hi,
I am sorry if this post is too long but I would like to share some real facts with those who are interest in Oil topic.
I decided to start doing some real oil testings from my daily driver E24 M6 S38-B35 and also my Race Track car E24 M6 S38-B36 powered.
Well, the oil I have selected to use is only 10W-60 grade. My choices for now will be Red Line 10W60, Luquil Moly GT1 10W-60 possible other Oil brand but for now this is enough.
So hear are some fact for my daily driver. 88' M6 200k+ on original engine, never opened ! Purchased my car like 8 years ago with 102k miles. since then I have been using only 10W-60 TWS but since the price jumped big and not worth to spend so much money on oil change since I changing my oil between 2,500-3k miles max. Since I quit using TWS because of its ridiculous price I switched to Liquil Moly 10W-60. "0"-(zero) oil consumption in between oil changes.
Driving conditions- I have put 100k+ miles with "0"-(zero) engine problems! On cold start the engine oil light goes off almost before all 6cyl fire up, idle at~1000rpms when cold. No timing chain noise on cold start etc..
Now, I decide to go 5,000 miles and start doing oil changes from 5k down in testings. So my next test will be at 4k miles, next will be at 3k miles. I will be using the same oil for the race track and do some testings as well to see how it does hold on abuse!
Now hear is the most interesting part.
I spoke with the rep. from the oil lab about 45mins and he was veery patient with me since I had tons of question about this about that...And he explained to me that the oils I chose to discus such as Mobile-1 15W50, 10W60 TWS, Red line 10W60 etc... all they are very good and quality oils! And if you hear this from somebody that does test oil all the long and you are kind of on a cross road...
He pointed that the most important is how the particular engine accept the chosen oil from above. I believe he is right because for example my buddy with E46 M3 S54 did use red line 10w60 and at 3k miles the S54 eat about ~450ml of oil then he switched to Motul 10w60 for motor cycles and he has less oil use...My S38 does not touch the oil vs S54
Also we spoke that if an existing engine is worn out such as Bearings, Head gasket antifreeze leak, other ware etc.. the oil will not help, possible to reduce some ware but not proven.
We discussed as well that ZDDP big booo hooo I know its important. He said the oil I have chosen to test/use they are above average on ZDDP. The Liquil Moly is about 960 at 5k miles and I will see next time Red Line 10w60 and compare because they are claiming High on ZDDP. Again the rep. said that even it enough 900+.
Liquil Moly has very high Flash point at 5k miles almost 400 ! that is actually very good.
The Rep and I discussed my oil test result shows that my "Lead" is a hair over average. The Lead stance for bearing ware, in our S38 world rod bearing and since they are the original I do expect that. He said that the MOST important is this number not go over 10! then for sure their is something going wrong !
The rep. wants to see at 4k miles how this number will be. he thinks this number will go down when do I do at 3k(will see on my next oil test)
Reference- S62-B50 with the same Oil Test with little less than 4k miles oil change and 50k on original engine miles the "Lead" is 8+ I was actually kind of shocked because 200k miles S38 at 5k oil change has 5 lead vs S62 with less than 50k miles.
Soon at 4k miles I will report more details.
I will keep doing oil analyze and continue to report.
Best
Anri
- E24 M6 1988. Shwartz/Tan (Daily driver).
- E24 M6 1988 Shwartz/Grey (Show car)
- E24 M6 1988 Royal Blue/Lotus. (Restoration)
- E24 M6 1988 Shwartz/Sparco S38-B36 3.6 (Track Toy).
- E28 M5 Black/Nature.
- E30 M3 1990. (Restoration)
- E31 840Ci 1997 Black/Black, all CSI futures daily driver soon S62-B50 6spd.
Need any model BMW work in So.Cal ?
https://www.instagram.com/euroclassicmotors/
https://www.youtube.com/watch?v=XTV4asC3Bp0
https://www.youtube.com/channel/UCyh..._as=subscriber
First e28 M5 is offline
The Following 2 Users Say Thank You to First e28 M5 For This Useful Post:
MattH (5th May 2012), raymondw (15th July 2012)
Old 5th May 2012, 07:48 AM Thread Starter
First e28 M5
Anyone with similar oil analyst result will be great to show.
Anri
Old 5th May 2012, 09:01 AM
davidoli
Great post , Anri .
I have a couple of samples that are due for a UOA and will post results in due course .
Thanks again for taking the time to share .
D
91 Sebring 3.6 | E28 UK RHD M5 | E34 UK RHD 3.8 | E34 M5 Touring | E24 M635CSi UK RHD
www.classicmdautos.co.uk
davidoli is offline
Old 5th May 2012, 03:33 PM Thread Starter
First e28 M5
Originally Posted by davidoli View Post
Great post , Anri .
D
Dave,
Please post what ever you have and lets compare
Anri
Old 5th May 2012, 07:48 PM
mottati
mottati's Avatar
I'll have to search my old laptop or maybe at home. I know i have a couple of these for my car with TWS. I used tery dyson at dyson analysis.
94 M5 Touring Madeira Schwarz, Black 10/93 production
84 728i - M88 powered
mottati is offline
Old 14th May 2012, 03:27 AM
DiegoR
DiegoR's Avatar
My B38 has about 154k kms on it. When purchased the car I found it was being serviced the last oil changes with something thick, like 25/w-60 or so according to a shop that was responsible for service the car with previous owner. I was shocked they were using so thick oil where the manual states use something about 10w40 or 15w40. So I did two oil change to "clean up" the old thick oil with Magnatec 15W40 and thats what I have been using or used because my car has almost 155k kms and when I purchased the car had about 153k kms on the clock. I do see oil comsuption, last time I had to add like 1/4 and probably ran like less than 800k kms on it before refill and not only once the refill was done, but twice. I must say "race out" this B38 when driving in the city every time I can so the engine sees a lot of redline and hard pulls. I still thinking to switch to Liqui moly 10W60 race and see if that help with oil comsuption.
Your thoughts?
Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
DiegoR is offline
Old 14th May 2012, 04:56 AM Thread Starter
First e28 M5
Your thoughts?
Diego,
Statistic wise B38 engine are prone to eat more oil vs B36 engines. Sure when you drive it to red line its going to consume more oil no matter what engine is. This is the nature of M-engines. Also other race prep engine. Loose internal parts, less friction, hi rpms etc..
Also, the reason the previous shop who serviced the car and did oil change with 20W60 is the proper grade not (25w60). The reason they used such a thick oil is because the oil consumption on this particular B38 engine is not from yesterday.
You should have starting point: Do Compression, Leak down test so you can have little more information about this particular engine.
1/4 oil for 800km that is a lot I think. Thick oil will reduce the oil consumption in general know. For example my wife's E53 X5 3.0 consume ~350ml every 3.000 miles using 5w30 switched to 5w40 no more oil consumption in between oil changes what so ever.
Anri
Old 14th May 2012, 03:37 PM
DiegoR
DiegoR's Avatar
Anri, you are right probably about 20w-60 but I remember the guy told over the phone it was 25w-60 and I was surprised, didn't know that grade of oil "existed" if at all.
I did a leak down test cyl last year and this was what I got:
1) 15%
2) 12%
3) 11%
4) 20%
5) 18%
6) 14%
For the compression test, I can't remember exactly but there is number that comes to my head, 190 PSI per cyl (all).
My car doesn't smoke, but If I red line it, it will expulse a little chunk of smoke that you can see through the rear mirror if you have good eye, otherwise it won't be viewble, this smoke is a mix of black (rich condition) between skyblue color, most of the time is darker (rich) rather than skyblue color (this one is very little that average person won't see I guess).
-Diego
DiegoR is offline
Old 15th July 2012, 04:09 PM Thread Starter
First e28 M5
Raymond's Oil Test
Raymond,
I started this oil thread whit oil lab test comparing different BMW M Engines.
I am pulling few more Blackstone test in comparison I have found.
Hear is my BlackStone test and you can see my S38-B35 as results in comparison to your still breaking in period.
I am absolute positive that your numbers will come down a lot.
The viscosity on the TWS vs Lubro is little lower but I guess that is making the oil little more liquid. In my opinion I like the Lubro choice little better because it will allow the engine parts to move more free, but that is just on paper and theory...But Butt Dyno will never ever catch that.
Lubro Mouly Flash point is higher than TWS whit I think a lot 20F is not little bit.
I have found very interesting Lab testings I will share in comparison.
The Following User Says Thank You to First e28 M5 For This Useful Post:
raymondw (1st August 2012)
Old 15th July 2012, 04:15 PM Thread Starter
First e28 M5
M-Coupe S54 powered.
Hi,
S54 powered
Rate This Thread
The Oil Lab (UK) Report for my beast, your views? Leezamonkey E39 M5 and E52 Z8 Discussion 33 4th April 2012 11:04 PM
Another oil thread.... (trans oil) The_Hamster E39 M5 and E52 Z8 Discussion 30 31st January 2012 09:58 PM
Two Tire Comparison... Yes another Tire Thread BUT luckily not an Oil Thread ;-) IRISH M5 E39 M5 and E52 Z8 Discussion 12 16th April 2011 05:20 PM
Oil question. No it's not another oil thread...... essex boy E39 M5 and E52 Z8 Discussion 4 11th September 2009 11:32 PM
Dinan E39 M5 SC got to 700 HP in the lab NJ M5 E39 M5 and E52 Z8 Discussion 16 31st March 2003 01:43 PM
