Oil thread with Lab Analyst - Page 24 - BMW M5 Forum and M6 Forums
 92Likes
post #231 of 240 Old 1st May 2016, 05:32 PM
GregT53
GregT53's Avatar
I did have the same concern about the potential to cause seals to leak. I have not noticed an increase in leakage from the original pan seal. It is described as a semi-synthetic. Not sure exactly what this means concerning the formulation. I plan to use Brad Penn again on the next change and for continuity I will service at the same mileage and get another Blackstone report to help make the best comparison to Valvoline.
GregT53 is offline
post #232 of 240 Old 1st May 2016, 05:32 PM
GregT53
GregT53's Avatar
GregT53 is offline
post #233 of 240 Old 12th July 2016, 04:52 PM
Eero H
Eero H's Avatar
Originally Posted by Eero H View Post
Previously i use Teboil 10w-60, now NLA. Last summer i use Kendall 15w-40, also now NLA.
This years first drive outside temp was +0.5C. Last week i drove M5, max outside temp was +14C, average maybe +7C. I drive quite moderately, maybe once a year oil temp exceed +80C. This makes me wonder, should next oil be 5w-40/50? Maybe Mobil 5w-50, local M mechanics recommend that for S85.
I bought this
Eero H is online now
post #234 of 240 Old 28th January 2017, 04:15 AM
GregT53
GregT53's Avatar
Latest analysis.
This makes a comparison between Valvoline VR-1 non-synthetic 20W-50 and Brad Penn semi-synthetic 20W-50 oils.
Noted in the report is the increase in iron which is likely due to several hard runs at sustained 5,000-6,500 RPM to blow off carbon.
Between the two oils, a point of interest is the flash point with the Brad Penn being below the desired value of greater than 385 F. The magnesium level is also quite elevated for Brad Penn. Other than these two measurements, it appears the Brad Penn has more favorable numbers, especially in the ZDDP department.
Thoughts?
GregT53 is offline
post #235 of 240 Old 27th April 2017, 05:22 PM
raymondw
raymondw's Avatar
The last documented UOA of my E34S M5 was performed in September 2015 at 191568km. This UOA already demonstrated elevated wear levels of copper, iron and lead, which pointed towards bearing wear.
Originally, it was planned to replace the conrod bearings in the winter of 2015/2016, however two other car related projects came in between due to which this was postponed to the winter of 2016 and 2017. In the past few months, we took on this project and replaced not only the conrod bearings, but (purely as a preventive measure) the oil pump as well.
When performing the engine rebuild of the M88/3 engine of my E28S M5, I paid less than 10 Euro for a single bearing shell. However that was in 2009. Nowadays in 2017, their retail price has more than tripled.
After some time being out of stock, BMW supplies the ‘short-type’ oil pump again, however these retail at over 500 Euro ex VAT nowadays, but bear in mind that this is a mission-critical part and a single point of failure as well so from that point of view, it is imperative to replace the old pump.
After removing the sump, the oil pump and the crankshaft became visible to the full extent for the first time in twenty-seven years. As can be seen, the bottom end has that nice brown varnish colour; the engine is completely free of insoluble and/or sludge, which is a clear testimony if regular and short term oil changes with high quality engine oil, at least during my watch (since April 1999).
From the historical documentation, it appears as if BK02837 was not given frequent oil changes during its first four years. This is however unlikely as she was then in the inventory of a BMW main service agent in Switzerland and not registered for the first time until June 1994. Given this status, it is very unlikely that in between the first service by Roseg in Pontresina and the first delivery in 1994, no oil changes were performed.
Even though some wear was expected after 195655 kilometres, the extend of which cannot be determined (and documented) without performing a visual inspection. If one takes a closer look to some of them, spot wear down to the steel substrate can be seen
The journals for the conrod of cylinders #1 and #3 showed some scoring marks. Fortunately, the scoring could not be felt and a light polish made them disappear.
Upon disassembly of the original oil-pump, only mild level of wear to its moving parts was observed. Based on its condition, it was perfectly defendable to reuse the old pump, however (1) from a risk management perspective and (2) the current market developments for E34S M5’s in good to excellent condition maintaining the old pump would have been the wrong decision, so it had to be replaced.
The outer rotor showed some scoring, which is normal for these (eaton) type of oil pumps because te pump is situated in between the sump and the filter and thus is subject to unfiltered oil from te sump and thus prone to elements of engine wear and dirt.
The short summary is that any well maintained S38B36 can suffer from conrod bearing wear. In my particular case, I think the engine would have lasted no more than 10k kilometres without dropping a rod. Granted, this particular engine saw some appropriate use during the 94016 kilometres that I have added since April 1999. Using a different type of oil would certainly not have delayed the bearing wear. On the contrary, using a low-weight oil would only have accelerated the bearing wear during the more stressful driving conditions (at least 50% of my kilometres).
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline
The Following 4 Users Say Thank You to raymondw For This Useful Post:
1day (5th May 2017), Eero H (29th April 2017), MattH (2nd May 2017), Monkey_Wrench (28th April 2017)
post #236 of 240 Old 29th April 2017, 07:27 AM
Eero H
Eero H's Avatar
post #237 of 240 Old 29th April 2017, 07:35 PM
raymondw
raymondw's Avatar
You got stock size bearings and did not measure?
I did actually, but demonstrating the process (how to) is not the intention of my contribution, which was merely aimed to scientifically proove the usefullness of Used Oil Analysis as an early detection method for critical bearing wear.
Raymond
raymondw is offline
The Following User Says Thank You to raymondw For This Useful Post:
post #238 of 240 Old 21st March 2018, 06:08 AM
inertia8
Hi All,
I've got my first sample being tested at the moment but had a phone call today citing that the flash point test had revealed >5% petrol dilution in my oil.
Ever since getting the car back from having the MAF replaced and vac lines replaced it has not run 100%, performance is down and I'm wondering whether the above is a result of over fueling. It certainly seems to have a small vac leak and small stumble at idle.
I'll post the full results when I get them for your advice.
Cheers
inertia8 is offline
post #239 of 240 Old 21st March 2018, 02:55 PM
inertia8
Ok, got the report:
Oil:
PENTRITE HPR10
[email protected]: 131
[email protected]: 19
TBN: 7.5
Report:
Wear Metals ppm
lead: 6
iron: 12
aluminium: 2
copper: 2
chromium 1
tin: 1
nickel: 0
Contaminents ppm
silicon: 13
sodium: 1
Oil Additives ppm
magnesium: 190
zinc: 920
molybdenum: 47
calcium: 2255
phosphorous: 789
boron: 17
Infra Red
TBN: 6.80
soot: 3
glycol%: 0
Fuel dilution: 3%
water: 0
oxidation: 13
nitration: 9
sulphation: 18
Physical Tests:
water%: 0
PQ-90 mg/ltr: 1
[email protected]: 15.85
[email protected] 97.48
Comments:
3% Fuel Dilution detected, please check fuel delivery system.
This 3000kms has seen significant idling in peak traffic as well as a number of short trips.
I am going to change the oil to Penrite HPR15-60, a full synthetic with full zinc additive package.
They are recommending an additive called Nanolub WS2. Anyone heard of this one?
Company that did the oil analysis is Techenomics
inertia8 is offline
post #240 of 240 Old 27th March 2018, 10:01 AM
inertia8
I found that I had another 6L bottle of the HPR10. Given all the wear metals looked good to me, I changed the oil and put in a new bmw filter and decided to change the air filter and spark plugs at the same time. I will dump it in 12 months or 2000kms.
Adding Report
inertia8 is offline
The Following 2 Users Say Thank You to inertia8 For This Useful Post:
Xaoc (4th April 2018)
The Oil Lab (UK) Report for my beast, your views? Leezamonkey E39 M5 and E52 Z8 Discussion 33 4th April 2012 11:04 PM
Another oil thread.... (trans oil) The_Hamster E39 M5 and E52 Z8 Discussion 30 31st January 2012 09:58 PM
Two Tire Comparison... Yes another Tire Thread BUT luckily not an Oil Thread ;-) IRISH M5 E39 M5 and E52 Z8 Discussion 12 16th April 2011 05:20 PM
Oil question. No it's not another oil thread...... essex boy E39 M5 and E52 Z8 Discussion 4 11th September 2009 11:32 PM
Dinan E39 M5 SC got to 700 HP in the lab NJ M5 E39 M5 and E52 Z8 Discussion 16 31st March 2003 01:43 PM
