Differential Question - BMW M5 Forum and M6 Forums
E31 850 CSi and E24 M635 CSi M635 CSi (E24) 1983-89 and 850 CSi (E31) 1992-96. The Ultimate Grand Turismo by BMW M.
post #1 of 2 Old 26th September 2017, 03:22 PM Thread Starter
Feffman
Good Day All:
Does anyone know what size (188mm or 210mm) limited-slip differential a 1995 850 uses? Thanks in advance.
Feff
Feffman is offline
post #2 of 2 Old 26th January 2019, 05:23 PM
m6bigdog
m6bigdog's Avatar
Originally Posted by Feffman View Post
Good Day All:
Feff
210mm is the only option, this diff has 8 bolts on the diff output bearing.
A 1995 will most likely require swapping the diff input yoke from your diff and that is better done by a professional diff shop or someone that knows how to measure/set the pinon bearing preload while re-torquing the pinon nut.
m6bigdog is offline
Rear differential question Dieselfumes E39 M5 and E52 Z8 Discussion 2 21st March 2014 08:01 PM
Question about E60 Differential williamcky E60 M5 and E61 M5 Touring Discussion 15 12th June 2013 08:44 PM
Rear differential question Jfreak E39 M5 and E52 Z8 Discussion 36 24th December 2011 12:03 AM
Question on Dinan differential EBuyuk E60 M5 and E61 M5 Touring Discussion 4 19th November 2006 04:25 PM
Differential question. klunk E34 M5 Discussion 1 13th January 2002 02:18 PM
