New owner - 850CSi - Page 5 - BMW M5 Forum and M6 Forums
E31 850 CSi and E24 M635 CSi M635 CSi (E24) 1983-89 and 850 CSi (E31) 1992-96. The Ultimate Grand Turismo by BMW M.
 36Likes
post #41 of 83 Old 16th December 2013, 12:51 AM Thread Starter
BMWWGN
Headliner is complete
Here are pictures of the finished headliner.
We decided to do the C-pillar covers as well, as they weren't perfect and would've needed doing in the near future.
A complication of doing this was the plastic locating/securing tangs on these covers needed extending by plastic welding, as the originals were barely engaged in their mating slots.
We also replaced ten of the headliner clips around the sunroof opening (BMW part #51441938868) - some were broken while others looked like they would break soon.
Ideally, all 16 clips should be replaced but I only had 10 new ones on hand.
Original clips were cadmium plated (gold colour), while the new ones are zinc plated (silver).
Overall I'm very pleased with the final result, especially the fact that all the original headlining fabric (albeit with new closed-cell foam backing) remains in the car.
Previous:
1987 E28 M5 (DC98) Delphin-metallic/Midsilver Nappa
1986 E23 745i/M88 (6928) Arctic-metallic/Oyster Nappa
BMWWGN is offline
post #42 of 83 Old 16th December 2013, 01:31 AM
slfan
slfan's Avatar
BMWWGN,
1. Final result looks great. Congratulations.
2. As I am not familiar with the 850CSI I was wondering if he sunvisors were re-done or is that the original seam?
Slfan
1985 M635 CSI
1988 M3
1988 M5
slfan is offline
The Following User Says Thank You to slfan For This Useful Post:
BMWWGN (16th December 2013)
post #43 of 83 Old 16th December 2013, 04:30 AM Thread Starter
BMWWGN
Thanks slfan.
The sunvisors are original.
Previous:
BMWWGN is offline
post #44 of 83 Old 16th December 2013, 06:55 PM
rogbmw
rogbmw's Avatar
rogbmw is offline
The Following User Says Thank You to rogbmw For This Useful Post:
post #45 of 83 Old 24th December 2013, 08:33 AM
MAZI
Originally Posted by BMWWGN View Post
Correction - just noticed an error in this statement, which I'll correct here.
For your reference:
All US-spec CSi's and later Euro-spec cars had the M-colour stripe on the shift lever (not the M-logo).
Geek!
Sent from AutoGuide.com Free App
MAZI is offline
post #46 of 83 Old 24th December 2013, 04:07 PM
rogbmw
rogbmw's Avatar
Very pretty car. Congrats. I have a Silver B12 5.0 that I am totally going through - the only B12 5.0 made. We just redid the headliner - your pictures look familiar!!
rogbmw is offline
BMWWGN (25th December 2013)
post #47 of 83 Old 25th December 2013, 07:06 AM Thread Starter
BMWWGN
Thanks rogbmw
Your B12 is definitely worth the effort to restore.
Did you refurb or renew the headliner?
Previous:
BMWWGN is offline
post #48 of 83 Old 26th December 2013, 12:20 PM
thevintage
Hi Mate
Just bought a 840ci here in Oz,my question how easy was it to remove the material from the pillar.My car has a broken C pillar ( the tabs are snapped off ) am looking at getting a new black colour C pillar and transferring the material from the broken one onto the new after remoing its covering.
David
thevintage is offline
post #49 of 83 Old 27th December 2013, 09:10 AM Thread Starter
BMWWGN
Seasons Greetings David!
I've learned a bit about these pillar covers from having my own set done, so I'll try and offer the best advice I can, based on this.
If the C-pillar cover is the original, the material should come off easily, as the foam backing will most likely be knackered.
Be sure to clean off all foam and adhesive residue from the fabric and the cover, then launder the fabric (cold wash, delicate cycle with a mild detergent, dry in the shade).
Actually I'd recommend doing both covers, in order to have them looking the same.
Get a plastic welder to repair any broken tab(s) and extend them slightly so they engage properly upon installation.
A new cover will give you the same short-tab issue I had, possibly leading to more broken tabs, and will probably cost you more than the weld repair on the old ones.
You can either fix new closed cell foam (1/16 inch recommended) to your fabric sections, or opt to re-trim both pillar covers with just the (laundered) fabric and no foam backing - depends on the look you want.
Also, depending on the colour and type of fabric you have and the weave, etc, adhesive bleed-thru is a concern here. Fortunately this was not evident at all with the tightly-woven backing on my CSi's charcoal-coloured velour fabric.
Use a good quality spray adhesive - ask a reputable trim shop what they recommend.
In fact, if you want a first class result, just give the trim shop the entire job!
Hope this helps.
Previous:
BMWWGN is offline
post #50 of 83 Old 3rd January 2014, 08:39 PM
Bayerische
Bayerische's Avatar
Great job Peter,
The headliner looks perfect. I can see that that 850 CSi is in good hands.
Bayerische is offline
The Following User Says Thank You to Bayerische For This Useful Post:
BMWWGN (3rd January 2014)
How much would a 1 owner 850csi with 13,000 miles be worth? harraj128 E31 850 CSi and E24 M635 CSi 5 17th November 2012 09:10 PM
850csi fs redl1nerpm Cars For Sale or Wanted 0 26th February 2006 03:47 AM
If anyone wonder where 850CSI are ending up bayerischemotor GTBoard.com: General Sportscars 5 14th January 2005 05:49 PM
Finding an 850CSI bobafett E31 850 CSi and E24 M635 CSi 22 17th October 2002 01:31 AM
Is it an 850CSi or just an 850i ? BlueBiturbo E31 850 CSi and E24 M635 CSi 2 13th October 2002 05:38 AM
