help on E24 M6 wheel changeover - Page 2 - BMW M5 Forum and M6 Forums
E31 850 CSi and E24 M635 CSi M635 CSi (E24) 1983-89 and 850 CSi (E31) 1992-96. The Ultimate Grand Turismo by BMW M.
post #11 of 14 Old 4th February 2013, 08:40 AM
Revo
Revo's Avatar
Most information I have read about wheel clearance generally calls for about 5mm of clearance with respect to brake and suspension parts.
That said, you wouldn't expect a wheel to flex under normal driving but under spirited driving, I can see it happening, and with clearances that small, contact is possible. I personally would not feel comfortable with such little clearance.
I'm normally posting in the E60 section but I got a little bored and decided to venture around...figured I'd add my 2 cents. Good luck.
The M5 is my dad's - but I drive it more than he does!
Sold Sept '16. It was an amazing 7 years.
Revo is offline
post #12 of 14 Old 21st May 2014, 04:16 PM
wfwright2
Some E34 wheels do not work
I have attempted to usè E34 15 in type 5s on my 88, the caliper on the right side hit the spoke mid way, a raised boss was the interference. Type 32 from the E34 fit. Both wheels 15s with et20, just additional relief on the back side of the spokes
wfwright2 is offline
post #13 of 14 Old 27th May 2014, 10:39 PM
Feld1128
Feld1128's Avatar
My solution to fitting style 5 wheels on my E24 M6 was to use H&R spacers/ adaptors which gave me the correct center bore and pushed the wheel out for a nice flush look. Better setup than hub centric rings, and you can choose the thickness of the spacer. I used 15mm with my 17" style 5.
Feld1128 is offline
The Following User Says Thank You to Feld1128 For This Useful Post:
wfwright2 (27th May 2014)
post #14 of 14 Old 28th May 2014, 12:03 AM
wfwright2
I intend on using the 15in only until I get a set of BBS 221s powder coated that were installed by prior keeper of this black beauty. Requires centering rings, but no spacers to fill out the wheel wells.
E24 M6 Frits E28 M5 Discussion 103 12th February 2011 08:08 AM
E24 M6 in NH MMac Sightings / Spotted M5 around the world: was it you? 0 28th April 2009 06:29 PM
Better value? 1985 e24 B9 or 1986 e24 B10 jrcalvin ALPINABoard.com | BMW Alpina Discussion 8 1st January 2006 07:50 PM
Help wanted: E24 steering wheel swap Frits E31 850 CSi and E24 M635 CSi 0 29th December 2005 07:28 PM
E24 and E24/1 JetBoy ALPINABoard.com | BMW Alpina Discussion 4 11th July 2002 06:11 PM
