How many E24 M6/M635CSi owners are in this forum ? - Page 7 - BMW M5 Forum and M6 Forums
E31 850 CSi and E24 M635 CSi M635 CSi (E24) 1983-89 and 850 CSi (E31) 1992-96. The Ultimate Grand Turismo by BMW M.
 34Likes
post #61 of 86 Old 20th February 2013, 08:22 AM
dhl93449
dhl93449's Avatar
Originally Posted by bmwmtechnike24 View Post
thank you for the info
maybey they have put to much boost on the engine or bad quality head gaskets.
I think with the new type geskets,and when not going higher then 1 bar the engine will last longer.
I will post pics soon of the build.
greatings
ruben
If you read that article, I believe that Dinan used a custom built copper head gasket and SS O-ringed the head. The cylinders are very close together so getting a good seal is very difficult. Compression was reduced to 7.8 from the stock 10.5. To get the low compression Steve Dinan had custom pistons built. They relocated the AFM to the right side so they could install an intercooler where the stock air filter is.
I actually took a ride in the turbo car in the article with Steve Dinan just after he finished the product. I was at Dinan Engineering asking about the stroker 3.8 L version he was also building. The turbo was EXTREMELY expensive at $20K OVER the base price of a car, and in the mid to late 80's this was really big money.
I'm sure some of the longevity problems where related to the low octane gas we have here in the US, as well as the problems getting 400 HP worth of fuel using that Bosch AFM. I know that with my car we are maxing out that AFM at 375 HP, so no matter how you tune the EPROM chips (or add larger flow injectors) you still cannot get linear airflow measurement if the AFM is mechanically maxed out against its stops. If you toss the Bosch fuel system and go to a Motec or similar system you can probably get around the fuel delivery problems. I have seen systems that use an E39 M5 style AFM with custom electronics to get higher airflow rates and higher HP.
Speaking with Frank Fahey about this (his shop has seen a number of blown Dinan turbo S38s) he suggested using a Mega Squirt or similar fuel injection/engine management system. Some do not even need a MAF as the use manifold pressure sensors, throttle position sensors, and RPM to determine fuel. He also suggests the use of an aux methanol system to quench detonation
dhl93449 is offline
post #62 of 86 Old 4th November 2013, 03:19 AM
slfan
slfan's Avatar
slfan is offline
post #63 of 86 Old 6th November 2013, 08:36 PM
Enoksen
Hi.One more M635CSI owner here.From Norway.My car is Hennared and has VIN nr 1050005 and are probably the oldest M635 that exist.
It`s produced nowember 3.in 1983 and owned by BMW AG from new to ca sept 1985.Imported to Norway 1995.In wey good condition.
Enoksen is offline
The Following User Says Thank You to Enoksen For This Useful Post:
Ferrari-Bmw (7th November 2013)
post #64 of 86 Old 6th November 2013, 09:25 PM
bmwmtechnike24
bmwmtechnike24's Avatar
bmw m635csi
Very Nice car
this car looks super good.red is a good colour to for the e24.especially with the chrome and the rs wheels and the full mtechnic bodykit.
greatings from Belgium.
Ruben
bmwmtechnike24 is offline
The Following User Says Thank You to bmwmtechnike24 For This Useful Post:
Enoksen (6th November 2013)
post #65 of 86 Old 7th November 2013, 05:28 AM
BMWWGN
I've never seen one in Hennarot before - looks like a very nice example.
Thanks for posting.
What is the current mileage?
Previous:
1987 E28 M5 (DC98) Delphin-metallic/Midsilver Nappa
1986 E23 745i/M88 (6928) Arctic-metallic/Oyster Nappa
BMWWGN is offline
The Following User Says Thank You to BMWWGN For This Useful Post:
Enoksen (3rd January 2014)
post #66 of 86 Old 9th December 2013, 02:54 AM
GregCT
I have a 1985 M635csi cosmos blue/anthracite buffalo. 92k miles. Located in Connecticut.
GregCT is offline
post #67 of 86 Old 9th December 2013, 05:33 PM
Feld1128
Feld1128's Avatar
Would like to see some pics of the cosmos blue/anthracite buffalo, I have alpine white with brown buffalo.
Feld1128 is offline
post #68 of 86 Old 10th December 2013, 01:35 AM
slfan
slfan's Avatar
Enoksen,
Beautiful car. Congratulations on the very early example. Can you tell us the mileage?
Slfan
1985 M635 CSI
1988 M3
1988 M5
slfan is offline
The Following User Says Thank You to slfan For This Useful Post:
post #69 of 86 Old 10th December 2013, 09:29 AM
slfan
slfan's Avatar
Fellows,
Here are some pictures of the M635CSI I recently purchased. With the exception of the wheels, radio and shifter, the remainder of the car is stock.
Car spent it's life in California and is now in Miami.
Slfan
1985 M635 CSI
1988 M3
1988 M5
slfan is offline
post #70 of 86 Old 3rd January 2014, 05:06 PM
Enoksen
Sorry for late response.My Hennared M635csi has 143000km on the meter.I have no garanties for that it is right,but i have no reason to doubt it either.
The only "negative ?" about the car,is that it was imported from Germany i 1995 with some small body damages.Some special Norwegian import rules made it possible to use an 635csi with Norwegian papers and splice(not sure if it is the right english word,but the norw back bodyparts was welded to th M.)to tis car.This had to be done by authorized garages and only with papers from the authoroties .They follow the process before,under and after and write the registration papers ONLY if they have the measuring papers from the aut.garage.So nothing else than the sidepanels,backplate and the thrunk are from the Norw.car.The garage also had to characterize the VIN nr from the norw car on to the firewall on the M.But it had to be done with their tools and one from the authoreties were watching. So the reg papers says:BMW 635csi VIN nr ..... approved spliced with BMW M635CSI with VIN 1050005.All this had to be done in agreement with norwegian car authorities and BMW.I dont know if this were special rules for Norway,but anyway.BTW If someone would import a M635csi to Norway in 1995,it would be approx 20-25000Euro only in taxes.Pluss the price of the car.
I would like to hear your opinions and questions about the car,about rules for splice,value for this vs original.Or anything thats on your mind.(both pos and negative).
Best regards
Enoksen is offline
Report: S38 M88 conference with E34 M5, E28 M5, E24 M635CSI and E30 320iS raymondw E34 M5 Discussion 3 9th May 2011 04:28 PM
Report: S38-M88 conference with E24 M635CSI, E28 M5, E34 M5 and E30 320iS raymondw E28 M5 Discussion 4 9th May 2011 09:50 AM
Auto Motor & Sport 12/1986 ///M-mission (E26 M1, E28 M5, E28 M535i, E30 M3 and E24 M635CSI) raymondw E28 M5 Discussion 4 8th December 2010 10:48 PM
I've Bought Colin's E24 UK RHD M635CSI davidoli E28 M5 Discussion 22 19th February 2009 05:13 PM
M5 E28 vs M635csi E24 svargas E28 M5 Discussion 2 6th June 2007 05:18 PM
