Who 'built' the M635CSi - Page 3 - BMW M5 Forum and M6 Forums
E31 850 CSi and E24 M635 CSi M635 CSi (E24) 1983-89 and 850 CSi (E31) 1992-96. The Ultimate Grand Turismo by BMW M.
 7Likes
post #21 of 32 Old 21st February 2013, 06:43 PM
M3 Euro LTW
Sigh... memories...
Originally Posted by dhl93449 View Post
The Euro version ,,,,,,,,but at the expense of HP.
Excellent summary!
I'm jealous, the driving experience of the Euro version was significantly better than the US. Mine was an 87, so it had the even extra luxury stuff, in terms of full leather dash. Those had a tendency to lift in the corners, and not wear well....dumped for 88 when they also changed the bumper trim etc....
Ug... just remembering the TRX rims too.
Beautiful car, with absent B pillars, and classic good looks. The Euro M635CSI was so much more fun to drive with more power and less weight. I believe most people converted to dual timing chains, this doesn't rob that much power, and can save an expensive rebuild. By now I'm sure you upgraded to the S50B32 chain tensioner etc.. Did you go for the Fahey crank hub?
I sold my car very shortly after a test drive in a used E34 M5. The extra power was eye-opening, and I realized I'd want one of those eventually, or something similar, a bit more practical with 4 doors.
M3 Euro LTW is offline
post #22 of 32 Old 21st February 2013, 11:36 PM
dhl93449
dhl93449's Avatar
Originally Posted by M3 Euro LTW View Post
Excellent summary!
The TRX rims were a pox on all the BMWs of the mid-80's era. Remember they were on 5 series and 7 series as well. The Euro M635s were supplied with special 3 pc BBS TRX rims which were prone to cracking and were recalled by BMW/BBS. The replacements (I still have a set of these) were single pc forged BBS rims that took the 415 mm TRX tires. The tires are still available but are outrageously expensive.
You can see a summary of my car in the other post (M6's on the Board). Frank Fahey rebuilt my Dinan stroker a few years ago. The Dinan stroker motors were supplied with a special run custom SCAT crank, which provided even more stroke than the E34 M5 cranks did. Since it was custom for the Euro M635s, it fit a single row sprocket for the cam chain, and I did not have to convert all the cam gearing to dual row. We did replace all the tensioners/chain/sprockets during the re-build, and using the updated cam chain tensioner I have had no problems since. The stroker crank really transforms this motor, providing a large amount of mid-range torque that you really can use.
And of course, I have been using the Fahey crank hub for a many years. It was the first mod I did to the motor, even before Dinan stroked it.
I consider the Euro M635 the only real performance 6 series. At 3300 lbs (with a modded motor over 320 HP) it breaks (under) the 10:1 LBs/HP criteria which I think is essential to consider it a real performance car. The US model 6 series were nice cruisers, comfortable and capable of high velocity autobahn running. But at a stoplight, forget it. And nothing matches the sound of those Euro M635 tubular headers at full song.
The E34 M5s are a nice improvement but still don't have the power/weight ratio of my stroked Euro M635.
dhl93449 is offline
The Following User Says Thank You to dhl93449 For This Useful Post:
Fiftytwoeighty (22nd February 2013)
post #23 of 32 Old 21st February 2013, 11:47 PM
bmwmtechnike24
bmwmtechnike24's Avatar
yes you are right,the sounds and power of a m88 is very nice to drive.(high reving is a addiction)haha,the best thing I have did on my euro was placing a 3.91 diff from a us version m6.its transforms the car completly.the same with the tuning and 3.6l to 7200 max rpms.I can not waite until ist back good weather.cruising full powah,hoping to get a lot of traffic light,so I can launch the car full trottle.its strange,but fast accelleration is with my car very tricky,I have 275 tyres,but to much trottle and I lose grip,but when I got it right its is very nice,my friend have a z3m roadster,and every summer its the same,I can not take him and he can not take me.aah I miss summer time.
bmwmtechnike24 is offline
post #24 of 32 Old 22nd February 2013, 12:20 AM
Fiftytwoeighty
Fiftytwoeighty's Avatar
Well, the euro M635csi like the Euro M5 had a slightly different engine, 286 vs 256 HP.
The Euro's had the m88, while North America got the s38. Single v. dual chain as dhl93449 highlighted.
The valve cover on the m88 also had a Rondel that we didn't get on the s38.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =162,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; MCS 2WNR motorsport coilover, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Nuke Performance fuel rail and pressure regulator, Carbon Fiber CSL intake; Lifeline Zero 360 FIA 3.0kg Novec fire suppression; Cool Shirt Pro Air/Water system; Euro RestoMod track car: caged, 6 point Schroth FIA harness, FIA Sparco Ergo & Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x9 BBS Style 42 w/Michelin Cup 2; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
Not-spec e30 racercar!!! Fully caged for wheel 2 wheel racing
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is offline
post #25 of 32 Old 22nd February 2013, 01:40 AM
dhl93449
dhl93449's Avatar
Tire slippage under accel is probably due to some decent HP plus the 3.91 diff. I am using 240/17s (so I can rotate tires) and I have a Quaiff LS diff and get a considerable amount of slip, esp in the rain or on dirty pavement.
BTW what top speed have attained in your car? I have suspected that the MTechnik skirt kits lower the top speed of the car, especially due to drag at the rear valence (its like a large parachute back there).
dhl93449 is offline
post #26 of 32 Old 22nd February 2013, 01:54 AM
bmwmtechnike24
I never drive faster then 200km,I hate the dead fly's on my front.hahaha
I only do fast accelleration.fast driving in belgium is not possible.to much traffic and to much crappy roads.
and the good places where you can drive fast there are the cops standing with there speedgun.
to much risk.my car's are a investment.fast driving is good,but on a track.I must check that in the gear ratio calculator.
I am building a turbo e24 on this moment,in csl mode.special build for accelleration.
I will post pics soon.
post #27 of 32 Old 22nd February 2013, 02:03 AM
dhl93449
dhl93449's Avatar
Originally Posted by Ficelle View Post
Hello,
like Ruben:
It is same car:
called M635csi in Europe and M6 elsewhere....
Well, no. There are a number of small but significant differences. Did you know that the quarter panels on the Euro will not fit the US car and vice versa? The hood is different, as are the bumpers/bumper mounts, air dams, rear trunk spoiler. The ECU and air flow meter are different. European cars came with options like manual Recaro sport seats, water buffalo hide and trim, a magnetic key central alarm systems (in the trunk) you will not find on any US or NA car. Even the valve clearance spacers are different for M88 vs the S38. The M88 can use convention VW pucks while the S38 uses special (meaning $$$$) BMW ones.
If you ever wreck a Euro M635 here in the US, you had better have a body shop that knows what they are doing. If they order parts for a US 635 they may not fit your Euro body!
dhl93449 is offline
post #28 of 32 Old 22nd February 2013, 02:05 AM
bmwmtechnike24
forgot to tell,after the tuning the accelleration was not possible on full throttle.
the m technic rear springs where too soft.when accelleration the rear wheels are jumping up and down very fast.
this was not fun.
I solved this with something very simple,I orderd in the uk some greystone spring rubbers.(towing a heavy load)
with that the rear suspension keeps original,but the becomes stiffer under load or heavy accelleration.(when pressed)
it was day and night.
post #29 of 32 Old 22nd February 2013, 02:11 AM
bmwmtechnike24
that is the first time I hear that,the the quarter panels and the hood is different.do you have a pic of the us hood and trunk spoiler?I only knew those other things.
what is different?
what do you mean with pucs,are those the plates under the cam lobs?
post #30 of 32 Old 22nd February 2013, 02:51 AM
dhl93449
dhl93449's Avatar
200 kM is about 120 mph, so I don't think the skirts are in effect yet. My car pulls like a train to 140-145 MpH, then "stalls" out very gradually increasing speed thereafter. Like in your country, these are "go to jail" speeds here in the US, so I have not run long enough to get to max speed. But given the HP in my car, it should be able to get to 165 just based on HP. I think even the US 256 HP M6 was measured by Road and Track at 156 mph (Road and Track, World's fastest cars 1988). But that car did not have MTechnik spoilers. I suspect that rear valence creates a lot of downforce, but at the expense of a large amount of drag.
Talk to Frank Fahey about your turbo. He built a 600 Hp turbo 635 (modded straight 6 3.5 L motor) with alcohol injection back in the eighties.
dhl93449 is offline
Status of my week 39 built Beast.. Angel E39 M5 and E52 Z8 Discussion 20 30th September 2001 03:11 AM
I'm built!!!! Ricmaz E39 M5 and E52 Z8 Discussion 5 6th September 2001 06:26 PM
Next gen. RR built on new 7 series frame and 760 eng. Fury E39 M5 and E52 Z8 Discussion 4 10th June 2001 03:22 AM
The BEAST is being built Graeme E39 M5 and E52 Z8 Discussion 0 1st May 2001 03:22 PM
Is this who built my car? John Robinson E34 M5 Discussion 3 30th April 2000 09:28 AM
