Adaptor plate for M5x transmissions! - BMW M5 Forum and M6 Forums
E28 M5 Discussion 1984-1988
 2Likes
  • 1 Post By Loupoz
  • 1 Post By Loupoz
post #1 of 10 Old 2nd July 2018, 02:20 PM Thread Starter
Loupoz
Thought i would share this in here as well, since my G280 has a completely shot 2nd gear synchro, and the third gear synchro is on its way to death as well. Ive been considering getting it rebuilt, which is expensive, and takes a lot of time where the car needs to stand without a transmission. Ive also been considering the "MM ultimate Getrag 265", which also is expensive as fuuk, especially when customs charges gets put on. Also been considering getting the 6 speed from an E35M5 3.8, but as we all know, those are also big bucks, and almost impossible to obtain now adays.
Enter the crazy swedes:
Växellåds Adaptrar : ZF Adapter Plate ZF to M10/M30/S14/S38
Ive just sent them a mail asking for further information.
So now the plentyfull, cheap and strong ZF boxes from everything from a E36 328i to a E90 335i is available for our old S38's.
Loupoz is offline
The Following 3 Users Say Thank You to Loupoz For This Useful Post:
de Witt (2nd July 2018), Ubersaloon (3rd July 2018)
post #2 of 10 Old 2nd July 2018, 11:47 PM
de Witt
de Witt's Avatar
Great find, price is pretty good about $520 USD plus shipping and duties it probably would be around $600.
Please post this in the E34 M5 forum as well, there is a lot more traffic and more demand for this solution there:
E34 M5 Discussion - BMW M5 Forum and M6 Forums
Now the decision is which ZF? Plenty of options.
de Witt is offline
post #3 of 10 Old 3rd July 2018, 08:45 AM Thread Starter
Loupoz
Just shared it in the E34 forum as well.
Ive been in contact with the owner since yesterday, and he stopped doing it with the longer input shaft, instead he is making custom billet flywheels, so you can change the gearbox without having to change the input shaft.
When talking with him on mail prices are different as well
I have diffrent solutions for it. Before I used to change in the inputshaft to a longer one. But nowdays I make custom flywheels that will move the pilotbearing into the flywheel so you're original ZF gearbox will fit drecly. Depending what clutch you want to use ?
We cnc regrind S38 camshaft and have alot of knowlegade for that engine too
Approx prices are:
~300usd for the adapter
~2-300usd for the billet flywheel
~300-900usd clutch depending if its sachs performance single disc or zf motorsport 7.25, 5.5 or 8.5"
Loupoz is offline
The Following User Says Thank You to Loupoz For This Useful Post:
Xaoc (5th July 2018)
post #4 of 10 Old 7th July 2018, 08:22 PM
johnnyjumps
really interested in this option. Which is the best ZF box for this option? aka What needs to be done downstream of a ZF box? any messing with the driveshaft ...
johnnyjumps is offline
post #5 of 10 Old 8th July 2018, 04:51 PM
de Witt
de Witt's Avatar
Good questions. @Loupoz did dynotech make any suggestions as to box and driveshaft? Mounts?
de Witt is offline
post #6 of 10 Old 8th July 2018, 08:38 PM Thread Starter
Loupoz
They did not. With driveshaft im sure something from the BMW model range will be compatible. This depends on the gearbox it self ofc.
If youre only going for the 5 speed ZF out of an 328i/528i/M3 (E36/E39) E28Goodies mentions in their S54 swap that a stock M30 or M21D24 driveshaft would work. Im pretty new to E28's, are they as easy swapable as an E30? Where you can take almost every drive shaft from almost every newer BMW?
Gearbox can be anything bolted to an M50 and everything later up until the N54, as long as it has 6 cylinders. A bunch of the 4 cyl gearboxes would work as well. 320d E46 six speed ZF for example. As long as the starter is the right place, so you can ofc not use a gearbox from a N47 engine.
Mounts would have to be custom, at least thats my guess, same with linkage. So if you cant weld yourself, i wouldn't begin this swap, or if youre to cheap to pay someone else to do it.
Loupoz is offline
The Following 2 Users Say Thank You to Loupoz For This Useful Post:
de Witt (8th July 2018)
post #7 of 10 Old 9th July 2018, 05:12 PM
de Witt
de Witt's Avatar
Ill have to check on what will swap into the E28, dunno how swappable they are but there likely is a stock solution from another chassis.
No problem on the welder, Ive got a miller sitting in the garage that can handle SS and aluminum, though my welding skills are so so.
de Witt is offline
post #8 of 10 Old 7th October 2018, 02:57 PM
Rikko
Hi Loupoz,
Did the Swedes ever get back to you?
I'm interested in this kit as well. I'm in a need of a gearbox for my S38 powered e28, and since it's much easier to source a ZF box from another beemer, than G280 or G265, at least in my country, I'm toying with an idea of going this route. My concern is this kit's compatibility though, with various boxes available to me.
Kudos for the find.
R
Rikko is offline
post #9 of 10 Old 16th October 2018, 09:40 PM Thread Starter
Loupoz
Originally Posted by Rikko View Post
Hi Loupoz,
Kudos for the find.
R
Yeah look at post #3
Loupoz is offline
post #10 of 10 Old 17th October 2018, 10:51 AM
Rikko
Hi Loupoz,
Ah, the forest and the tree conundrum... Thank you for being patient with me.
Cheers
Rikko is offline
How many SMG transmissions are dead? daviddavidw E60 M5 and E61 M5 Touring Discussion 1 8th September 2006 12:11 AM
Are M5 and 540/6 transmissions the same? AliM5 E39 M5 and E52 Z8 Discussion 10 1st August 2006 11:52 PM
Great article on auto transmissions frylord E60 M5 and E61 M5 Touring Discussion 0 16th April 2006 04:23 AM
Want to buy: Defective M5 and 540i Transmissions Lscman E39 M5 and E52 Z8 Discussion 17 19th November 2005 07:42 AM
B7 Turbo - ZF manual transmissions bendeco ALPINABoard.com | BMW Alpina Discussion 0 3rd December 2004 10:02 PM
