Best pressure washer and foam gun for M6? - BMW M5 Forum and M6 Forums
post #1 of 7 Old 11th March 2018, 06:00 AM Thread Starter
LopeyDeath
LopeyDeath's Avatar
Iím considering purchasing a pressure washer and foam gun to start washing my car. I see a ton of options out there but was hoping someone here had some experience they could share. I think Iíd rather go electric than gas for simplicity sake.
As for the foam gun - I was looking at Chemical guys... thoughts?
Thank you,
~Pat
RD sway bars. Monoballs. H&R springs. white interior LED's. Custom headlights with Orion V4 rings. Gloss black stock wheels. RPI scoops.
Down-pipes. Vibrant high flow secondary cats. X-pipe. E-Race. Evolve Eventuri intake and Tune. CIC Retrofit.
LopeyDeath is offline
post #2 of 7 Old 27th April 2018, 02:39 PM
MGZ
MGZ's Avatar
Hi,
I use a Kšrcher K7 pressure washer and a PA Foam Lance for my M5.
Magnus
Modifications: Too many!
MGZ is offline
post #3 of 7 Old 24th May 2018, 11:34 AM
therealkennylee
therealkennylee is offline
post #4 of 7 Old 3rd August 2018, 09:11 AM
Ivan Ha
Ivan Ha is offline
post #5 of 7 Old 13th August 2018, 02:58 PM
A777
I'm considering a Kranzle 1050 TST after reading good reviews as my Karcher lost pressure.
A777 is offline
post #6 of 7 Old 14th August 2018, 12:18 AM Thread Starter
LopeyDeath
LopeyDeath's Avatar
I ended up with a foam cannon from Chemical Guys and I love it. Really fits the bill! I’ll see if I can’t post some pics of the car covered in foam.
post #7 of 7 Old 10th January 2019, 12:50 PM
Muckman83
Muckman83's Avatar
Be aware snow foam will not get everything thing off.
I use both methods snow foam and a sponge bucket to get the road grit off the lower parts of the body work.
If your so set on snow foam the. Your going to need a heated unit.
I used the unit at work that has a burner on it and it works so much better then my Karcher HD 7125
But if itís pressure washers for automotive and parts washing your interested in then you need a unit that gives out at least 11 litres per minute at no less then 1900psi
Also donít be fooled at the PSI rating. Most places sell there pressure washers off like how they sell subwoofers and giving out peek power rating. Itís not faults advertising but itís miss leading.
Also you want a adjustable output for when you wash your engine and other small areas yo donít want to blast away.
But if itís just a u it you want advice on I wouldnít go anything lower then a karcher HD 7125
Anything els are just Chinese toys that your going to throw away in a few years
Iv had mine for over 5 years now, never serviced it and still works like new. Still has the factory oil.
Oh and definitely get one that has a brass pump head. Completely stay away from alloy heads.
Sent from my iPad using Tapatalk
Muckman83 is offline
Had some fun with the pressure washer over the weekend jsaxophone Owners Gallery 5 22nd November 2013 09:17 PM
Looking for a recommendation for a Pressure Washer to clean the beast polar993 E60 M5 and E61 M5 Touring Discussion 5 14th January 2011 07:53 AM
Anyone Use a Pressure Washer? nlpamg Detailing Forum 7 25th October 2009 05:10 PM
Tire pressure question: Summer pressure vs. Winter pressure tripleD E39 M5 and E52 Z8 Discussion 3 13th June 2007 01:29 AM
M-mobility foam stever E39 M5 and E52 Z8 Discussion 0 12th December 2000 08:28 PM
HTML code is Off
