Bradan F355 paint correction - BMW M5 Forum and M6 Forums
 7Likes
post #1 of 37 Old 23rd June 2010, 03:58 AM Thread Starter
Bradan Group
Company Representative for the Bradan Group
Bradan Group's Avatar
Vehicle: Ferrari F355 Berlinetta
Project: The following is an extreme reconditioning process of the F355 Berlinetta exterior. This is a unique process that combines our service team and detailing department. We hope you enjoy following our project.
Stage 1: Dismantle and Inspection.
The paint had deep swirl marks, oxidation, compound burns, industrial fallout, and the typical road wear and tear. Upon full inspection under 3000 watts of fluorescent lights, 1000 watts of halogen work lamps, and a 3m sun gun, it was determined that a full wet sand would be necessary in order to correct the paints damage and achieve a perfect finish. The F355's hard angles and difficult to reach body lines make it imperative to take apart the exterior. The front and rear hood, lower door air intake grille, mirrors, locks, bumpers, wheels, and rear grill were removed. This is to ensure that each beautiful contour of this Ferrari is equally restored.
The Bradan Group
111C Trade Zone Ct
Ronkonkoma, NY 11779
Tel 631-585-8600
www.bradan.us
[email protected]
Bradan Group is offline
post #2 of 37 Old 23rd June 2010, 04:05 AM Thread Starter
Bradan Group
Dismantle.
The Bradan Group
111C Trade Zone Ct
Tel 631-585-8600
www.bradan.us
[email protected]
post #3 of 37 Old 23rd June 2010, 04:14 AM Thread Starter
Bradan Group
Stage 2: Surface cleaning
We started by removing all of the contaminants from the paint with Chemical Guys Citrus car wash/stripper, 2 microfiber towels, and an assortment of brushes.
Paint was then clayed with Clay Magic's Red aggressive clay, Then followed by 3m Perfect it 3 fine grade clay. We used a highly concentrated amount of Chemical Guys Citrus car wash solutions because it adds a very good barrier of lubricity, which is key when claying with an aggressive grade.
Paint was then wiped down with a 70% isopropyl alcohol to ensure all old wax, glazes, etc were fully removed.
The vehicle and all panels were then blown dry with an compressed air at 120 psi.
The Bradan Group
111C Trade Zone Ct
Tel 631-585-8600
www.bradan.us
[email protected]
post #4 of 37 Old 23rd June 2010, 04:17 AM Thread Starter
Bradan Group
Stage 3: Clean all fender liners
All fender liners were removed and brought to our wash area to clean. A 50% water and 50% Malco outrageous orange mixture was applied and left on for 20 minutes to loosen and remove all contamination. Next, all liners were washed with straight water. The process was then repeated, but followed by scrubbing with a stiff horsehair brush to remove stubborn spots.
The Bradan Group
111C Trade Zone Ct
Tel 631-585-8600
www.bradan.us
[email protected]
post #5 of 37 Old 23rd June 2010, 04:19 AM Thread Starter
Bradan Group
Stage 4: Wheel recondition.
Upon inspection, all four wheels showed paint chipping and it was determined that they were beyond saving. Tires were removed, then valves and caps. Last night all four wheels were soda blasted to strip the old finish. Soda blasting is a process by which baking soda is sprayed at a high pressure to remove all finish. Baking soda is a safe alternative to commonly used sand media.
The Bradan Group
111C Trade Zone Ct
Tel 631-585-8600
www.bradan.us
[email protected]
post #6 of 37 Old 23rd June 2010, 04:22 AM Thread Starter
Bradan Group
Stage 5: Bumpers
The front and rear bumpers followed the same fate as the wheels. Cracks, deep scratches that were poorly repaired, and paint removed behind the wheels from road debris makes them impossible to recondition without painting. Paint meter readings were inconsistent, meaning its likely they have been repaired earlier in their life.
The bumpers were soda blasted down to their orange gel coat. Being an early model Ferrari, these bumpers were made from hand laid fiberglass. They will be repaired, prepped, wet sanded, and then painted. These bumpers will join the car towards the end of the process.
The Bradan Group
111C Trade Zone Ct
Tel 631-585-8600
www.bradan.us
[email protected]
post #7 of 37 Old 23rd June 2010, 04:24 AM Thread Starter
Bradan Group
Stage 6: Body prep
With the body fully clean, wheels being painted, and bumpers off to the body shop, we will continue the detailing end of the process. The F355s sharp angles and deep intake scoops, it will be very important to tape all edges for protection against breaking through paint. A paint meter is a must when detailing this type of body.
The Bradan Group
111C Trade Zone Ct
Tel 631-585-8600
www.bradan.us
[email protected]
post #8 of 37 Old 23rd June 2010, 04:26 AM Thread Starter
Bradan Group
Stage 7: Wheel coating finished
Originally we planned on painting the wheels. With the cars sole purpose being performance, we decided that a powder coated finish would be better suited to handle the abuse. We went with a matte black finish for an aggressive look. With what we plan on doing to the car, it will fit its character well.
With magnesium wheels, we only recommend painting. However, with aluminum wheels; painting and powder coating is common. On this set of rims, we went with a low temperature baked powder coat. All surface flaws were sanded and filled before coating. We are very happy with the end result.
The Bradan Group
111C Trade Zone Ct
Tel 631-585-8600
www.bradan.us
[email protected]
post #9 of 37 Old 23rd June 2010, 04:30 AM Thread Starter
Bradan Group
Stage 8: Tire mounting and wheel protection
With the wheels back and coated, it was time to have the tires installed. Our hunter mounting machine does not have any contact with the wheels edging. This allows us to consistently mount tires without the risk of damage. Once mounted, the tires were filled with nitrogen. We prefer this gas in performance applications for a consistent tire pressure. Once filled, the tires were road forced balanced. The high quality of OEM wheels is evident in the balancing process. Only minor correction was needed.
A mixture of 50/50 alcohol and water was applied to a microfiber towel to remove any dust and overspray. Once cleaned and dried, Autoglyms' radiant wax was applied to seal and protect the surface. This is a great process for all rims. It makes brake dust easy to clean up. Finally, tires were treated with Malco prizm dressing. We recommend this dressing even to enthusiasts. It leaves a natural lasting finish compared to the greasy wet look most products leave.
The Bradan Group
111C Trade Zone Ct
Tel 631-585-8600
www.bradan.us
[email protected]
post #10 of 37 Old 23rd June 2010, 04:32 AM Thread Starter
Bradan Group
Stage 9: 2000 grit body wet sand
The actual paint correction process started today after all the prep work over the past two days was completed. Two 5 gallon buckets are filled 3/4 full of pure water. One bucket is a rinse bucket, the other is a fresh water supply. 3m 2000 grit paper is wrapped around a rubber sanding block. With florescent lighting all around and halogens as a spotter, the body is sanded 4" x 4" at a time. It is important to keep checking paint depth with a paint meter to make sure equal pressure is consistently being applied.
The Bradan Group
111C Trade Zone Ct
Tel 631-585-8600
www.bradan.us
[email protected]
Best Detail/Paint Correction I have ever seen 650kid E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 6th June 2010 03:46 AM
M6 paint correction and polishing M9 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 11 7th October 2009 08:28 PM
paint correction on R8 Pro Detail Middle East Forum 0 31st May 2009 12:01 AM
HTML code is Off
