M5 Coding done in Toronto - Page 2 - BMW M5 Forum and M6 Forums
Canadian Forum For Canadian BMW M and Alpina owners and enthusiasts of m5board.com and gtboard.com
 3Likes
post #11 of 16 Old 7th October 2013, 10:07 PM
SleeperE39
SleeperE39's Avatar
Originally Posted by DIMSUM View Post
Wrong, they are only good for diagnostics nothing else.
They are unreliable for flashing DMEs and sensitive modules.
Gotta be BMW branded or else it won't work?
It's gonna brick your DME and then you will be sorry?
It has special non standard CANbus timings that only BMW knows with special silver plated high speed wire?
Strange thing is I just re-flashed my DME with an Evolve cable that they most surely sourced from some Asian vendor.
Car started up just fine.
Guess I was lucky.
SleeperE39 is offline
post #12 of 16 Old 8th October 2013, 02:30 AM
DIMSUM
Maybe BMW should start using clone cables on their diagnostic bays instead of the ICOM. Cause they're just as good right?
Why does BMW spend loads of money on big companies like siemens to build their ECUs when they could just get it cloned in China?
Guess I was lucky.
You are not flashing the whole DME with the evolve cable at all. Try to load 240E on a M3 with a K+DCAN and report with me your findings.
Plus that stuff is simple, look up a software called WINOLS.
DIMSUM is offline
post #13 of 16 Old 8th October 2013, 02:44 AM
DIMSUM
I have been coding cars since the "BETA" software of NCS Expert. I have nearly all the interfaces, that could be used with the EDIABAS suite.
I was coding cars back in 2008 on e90post.com, I have more experience then most people. As I mentioned the K+DCAN is fine for diagnostics, but nothing more advanced.
You can't even get it running properly with the ISTA suite, it hangs and it is slow as hell. (don't even mention the ICOM Emulator to me).
On 2xx bit it always writes a hidden value cause of the way it communicates with the car, this causes a huge problem resulting in a bricked module.
Originally Posted by tdott View Post
^^Just another leech trying to profit.
Soon enough he'll be banned for not being a paid vendor.
I ain't trying to leech, I am just stating the truth.
There's countless amount of vehicles I've dealt with that needed some sort of "fix" due to wrong dataset (not from https://www.bmwtechinfo.com/) or poor equipment.
DIMSUM is offline
post #14 of 16 Old 8th September 2014, 01:58 PM
tdott
tdott's Avatar
FYI I loaded 240E + a Tune on my e92 m3 with a cable in less than 5 minutes. The software as much improved.
tdott is offline
post #15 of 16 Old 27th September 2014, 09:57 PM
M5Baron
Do any of you guys know anyone who does euro smg tunes or removing speed limiters? thanks
M5Baron is offline
post #16 of 16 Old 10th December 2014, 09:59 PM
shahin
Originally Posted by BADBOY'S M5 View Post
I had posted this on the main forum but its mainly for Toronto guys.
had my Coding done and this is my list.
1. Rolling up windows/sunroof with key by holding lock
2. Folding mirrors with key by unlock and lock
3. Enable Digital Speedometer (km/h or mph)
4. Remove i-Drive Legal Disclaimer
5. added pathway lighting for 30 seconds on my remote by hitting trunk button once
6. removed seatbelt gong for driver and passenger (yes the light is still on the dash for safety)
7. added 1 touch ventilation, if i hit the heated seats, the idrive display now shows both seats and i can adjust more quicker, b4 needed to go into idrive then ventilation then seats.
8. changed speed to accurate speed, b4 was 5kms less than actual.
Some M5's have different modules so 2006 maybe different than 2007 and up.
____________________________________
call Patrick, 647-886-2128 tell him Bobby with the silver M5 had his codes done. $20 per code. cant go wrong. He is in Markham,
Is this for the F10 M5?
shahin is offline
Coding for your BMW Finesta101 USA Northeast Forum 6 30th September 2010 07:03 PM
Sydneysiders need coding done? ChrisM E39 M5 and E52 Z8 Discussion 1 10th April 2009 03:50 AM
Key coding topper E39 M5 and E52 Z8 Discussion 3 20th November 2007 03:47 PM
M5 Coding minted_aye E39 M5 and E52 Z8 Discussion 19 3rd November 2006 06:09 PM
Coding Plug - Where to get one D_C_R E34 M5 Discussion 0 2nd November 2005 08:50 AM
HTML code is Off
