s85 with spun bearing - BMW M5 Forum and M6 Forums
Australian Forum For Australian owners and enthusiasts of m5board.com and gtboard.com
 3Likes
post #1 of 12 Old 9th September 2014, 10:47 AM Thread Starter
crazy_199
just a word of warning in-case someone on here is considering the below.
http://www.manheim.com.au/damaged-ve...=SearchResults
this is known as matter of fact
crazy_199 is offline
post #2 of 12 Old 10th August 2015, 03:54 PM
GCTM6
GCTM6's Avatar
Item Not Found
Link above no longer works.
Has anyone in Australia had their rod bearings replaced on their V10 M5 or M6 as preventative maintenance against the premature wear in these bearings? If so what did it cost and where was it done? Has anyone actually thrown a bearing and required an engine rebuild?
GCTM6 is offline
post #3 of 12 Old 17th August 2015, 07:21 AM
Matt C
Matt C's Avatar
I'm contemplating doing some preventative maintenance. It seems they grenade around 150k's if they're going too. So I've got another 80k until I reach that, admittedly anecdotal, threshold but will pull the trigger well before. I've been sending technical's and processes to my mechanic here in Sydney for a few weeks.
Cheers,
Matt
///M Fanboi
E60 2007 M5. Michi PSS's. Eibach. FAM. BE and ARP's. RPi. Hartge BB's. Eventuri.
E46 2004.5 M3. RIP 4th May 2015 my joyful toy.
Matt C is offline
post #4 of 12 Old 5th September 2017, 05:35 AM
t.wak
t.wak's Avatar
General consensus is to definitely get them replaced as preventative maintenance before the 150,000km mark if you're planning on owning the car long-term.
t.wak is offline
post #5 of 12 Old 5th November 2018, 07:12 AM
Muckman83
Muckman83's Avatar
Iím in the proses in doing mine at home. Using ACL bearings cost of $215 for the lot. I guess if your only interested in doing the bearings then I guess with bearings, new oil, new gaskets you be looking at around just over 300 bucks provided you do it your self saving over $1500 in just labor. Itís a petty straight forward job if you just doing the bearings.
Iím going a full engine upgrade including vanos gears, vanos like line, oil squirters, oil pump chain tensioner and a full 100km service. Parts in total $3000 AUD. Not so bad considering I payed Audi $1700 for a 50,0000 service that was just a oil change and filters.
Muckman83 is offline
post #6 of 12 Old 7th December 2018, 03:07 AM
Cardpro
Can anyone recommend me a good mechanics in NSW who can inspect my car and change all the fluids..? I have recently bought e64 m6 2006 but couldnt find good mechanic who specialises M6/M5 ..!
Hello,
Sorry for randomly messaging you..
I recently purchased a M6 (e64 2006) and I am located in Sydney..!
If you dont mind can you please recommend any good mechanics who can inspect my car ... and change all the fluids..?
Thank you for your time..!
Cardpro is offline
post #7 of 12 Old 7th December 2018, 03:09 AM
Cardpro
Hello,
Opps I was meant to delete the bottom bits
Cardpro is offline
post #8 of 12 Old 10th December 2018, 10:47 AM
Muckman83
Muckman83's Avatar
I live in act but Iím more then happy to help and guide you through everything
Sent from my iPad using Tapatalk
post #9 of 12 Old 10th December 2018, 11:45 PM
Cardpro
Good morning muckman83,
Thank you for your reply and kindness !!
I just dropped off my car this morning...
Apparently my battery, brake pads will need to be replaced &#x1f61e;
My car is on 81xxx kms now... if you could guide me how to change the fluids, that will be much appreciated! I might change them again at 100,000kms. (Will change engine oil more sooner)
I am still very new to the m6... (its been a week since I got the car haha) I am still learning what should be changed/maintained !
Thank you again for your time !
Cardpro is offline
post #10 of 12 Old 11th December 2018, 03:00 AM
Muckman83
Muckman83's Avatar
Keep an eye on super cheep oils
They just had a 40% sale on there Castrol edge 10w60
I picked up 6 bottles cause itís so cheep and saves you in the long run.
Change your fuel filter and o2 sensors at 100kms
Being that itís 2006 you gonna wana do all the engine updates and replace rod bearings
So vanos gears
Vanos line
Vanos pump chain tensioner
Oil squirters
I also went for a full service including fuel filter, new injectors, new charcoal canister, throttle body and idle actuator clean, new air filters, new spark plugs, new coil packs, new brake fluid. Maybe if your willing nee maf sensors.
Comprehensive S85 Rod Bearing Picture Thread jcolley E60 M5 and E61 M5 Touring Discussion 993 18th July 2019 09:05 PM
Bearing Rod Changed with Pictures ! S85 Duschanio E60 M5 and E61 M5 Touring Discussion 235 2nd September 2014 07:05 AM
S85 rod bearing help! paulwarrior E60 M5 and E61 M5 Touring Discussion 10 9th December 2013 10:26 AM
Bearing Rod Changed with Pictures #2 - S85 TomekW E60 M5 and E61 M5 Touring Discussion 14 24th August 2013 01:05 PM
m5 e60 S85 Bearing CHANGE ! Tips needed Duschanio E60 M5 and E61 M5 Touring Discussion 4 1st June 2012 10:10 AM
HTML code is Off
