Alpina B10 Bi-Turbo: Starting Issue... - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 14 Old 11th March 2019, 01:22 PM
DaveW
DaveW's Avatar
Yes, don't get too hung up on the OBC - it's just me listing things to look at but by no means did I mean to laser in on this as the top priority.
The LED light I refer to is by the variable boost control knob in front of the gear stick. If it stays on and steady all is good. If it flashes it's displaying a fault code. If it doesn't light at all I suggest there is a fault.
Getting a spark and fuel to the plugs is important. Fuses, Relays, Crank Trigger?
I'm in Surrey too if you need photos of anything.
Dave.
DaveW is offline
post #12 of 14 Old 13th March 2019, 08:57 PM
M5sedan
M5sedan's Avatar
If you hold a flashlight up to the OBC screen, can you see any LCD numbers/letters? (normally the backlighting dies on the screens, not the complete display) If it is completely black and you do not see anything on the screen, I would recommend starting to check fuses in the fuse boxes(under hood and under rear seat). Perhaps one is corroded or dead. It is very possible the vehicle is immobilized due to the OBC being out of commission - DME thinks someone pulled it out/code is enabled. If its been sitting that long, could be some critters got to the wiring or just a relay or fuse or worst case, possible the General Module is wacked.
so much love to give.......so little time.......
'93 E34 M5 - Avus Blue/Dove Grey - 18" M-Parallels
Bent & Broken: '93 E34 M5 - Mauritius Blue/Dove Grey - 3.8 cam gears, Conforti chip, SLS-delete Ground Control/Koni suspension, Alpina Softline 18's, Rogue Engineering short shifter, Eisenmann Race exhaust
SOLD & Sorely missed: '02 E39 M5 - Carbon Black/Caramel - Rogue short shifter, Rogue Power Pullies, opened brake ducts, ellipsoid fogs, slide/tilt armrest
M5sedan is offline
post #13 of 14 Old 16th March 2019, 07:13 PM
DaveW
DaveW's Avatar
Some good info on the OBC can be found here: BMW E34 Website
Most of the E34 and E32 troubleshooting are the same.
E34 Wiring diagram here: http://shark.armchair.mb.ca/~dave/BMW/e34/e34_89.pdf Swap the last 2 numbers for your year of manufacture and remember its the base car year not the Alpina year.
DaveW is offline
post #14 of 14 Old 23rd June 2019, 06:59 PM Thread Starter
redzuki
Hi All,
Thanks for all the comments, tips, links and hints above. Very much appreciated indeed. Apologies for the radio silence; life has been a bit manic of late and not had time to work on the car until today (I've moved to Cornwall - car still in Surrey!).
Today I can add the following prognosis:
- All fuses are in very good condition (checked within engine bay and under rear bench fuse boxes); fuse wires themselves all look to be intact with only the larger amp rating ones having minor amounts of corrosion on fuse wires/strips themselves (nothing to worry about IMHO). Contacts into the fuse boxes all show almost no corrosion at all, on what looks to be the fuse side and car side contacts. Overall, I'm pleasantly surprised.
- Same statement as above for all the relays, but I have not evaluated the working order of each relay one by one. That said, there were signs that some of the connections/contacts/pins had got hotter than others.
- I've shone a torch (flashlight) on the OBC screen to see whether just the backlight has gone at various stages of ignition, but I cannot see any digital display whatsoever no matter how I hold the light source.
So...
I really do think I'm narrowing in on the OBC; managed to pop the radio out, but ran out of time today to get the OBC out itself in order to check the bulbs. Think I will buy some replacements either way (they are pretty cheap from what I understand?); that way will be a productive session when am next working on the car.
As always, would be good to hear your thoughts?
Thanks and regards,
Alex
redzuki is offline
Alpina B7 Review [Copied from the Alpina Forum] MEnthusiast E60 M5 and E61 M5 Touring Discussion 33 4th December 2008 06:10 PM
List: Sultan of Brunei's complete car collection, no M5 but an Alpina Gustav ALPINABoard.com | BMW Alpina Discussion 109 14th September 2007 06:16 PM
Z8 colors opinions? arm E39 M5 and E52 Z8 Discussion 3 23rd August 2006 03:24 PM
Report from Geneva, a lot of pics (Updated 13th March with 911 GT3 & Turbo pics/info) Gustav E60 M5 and E61 M5 Touring Discussion 71 1st April 2006 03:36 AM
Alpina B10 Bi turbo for sale - UK markuk Cars For Sale or Wanted 0 11th October 2000 06:19 PM
