B10 BT Front Shocks - BMW M5 Forum and M6 Forums
post #1 of 20 Old 11th March 2012, 09:28 PM Thread Starter
pulsapharer
B10 BT Front Shocks
Today i had a look at the front shocks and found that the top locknut (Shock to strut) was loose so cleaned and applied Threadlocker and retightened both sides.
But after dropping the car to the floor noticed that the n/s gap between top of the tyre to arch was smaller than that on the o/s wheel?
I understand that the height of the suspension is controlled by the shock as it limits the spring to the shocks total extension.
So when the shock has worn would it extend further than normal?
Any advise would be greatly appreciated.
Regards
Paul
92 Alpina B10 Bi Turbo #405 Alpina Blue: 02 BMW M5 Carbon Black metallic
pulsapharer is offline
post #2 of 20 Old 11th March 2012, 09:40 PM
Ferrari-Bmw
Ferrari-Bmw is offline
post #3 of 20 Old 11th March 2012, 10:18 PM Thread Starter
pulsapharer
Originally Posted by Ferrari-Bmw View Post
The only thing that I can think of is that the shock for some reason whether worn? Is extending further than it should be?
post #4 of 20 Old 11th March 2012, 10:25 PM
Ferrari-Bmw
Sometimes the car ................. needs time to get the optimal ,, oem height,, after been lifted
Sveinbjörn Hrafnsson
E30 CABRIO V12 M70B50 ///
ALPINA B10 BITURBO 346 @ 507
E34 550 V12 JML
http://alpina.123.is/pictures/
post #5 of 20 Old 11th March 2012, 10:27 PM Thread Starter
pulsapharer
I'll give a run tomorrow over some uneven roads and see if that sorts it out.
post #6 of 20 Old 12th March 2012, 10:30 AM
Chas C
Chas C's Avatar
I always understood it was the springs which set the ride height (on the standard set-up). Shocks are for rebound dampening only unless they are incorporated in an adjustable coilover setup.
Get someone to check the gap when you are sitting in the drivers seat. Anecdotal evidence suggests BMWs are set up this way!
Chas
E32 Alpina B11 (Alpina Green/Beige)
E34 Alpina B10 BiTurbo #290 (Diamondblack/black)
E36 Alpina B8 4.6 Coupe #015 (Alpina Blue/Blue)
E39 Alpina B10 V8 #003/1 (Scarab/Pearl Beige)
Honda CBR1100XX - something for the weekend, Sir
Chas C is offline
post #7 of 20 Old 12th March 2012, 10:37 AM Thread Starter
pulsapharer
Thanks chas the drivers side n/s suspension sits at the correct height where as the o/s sits about 1 inch higher
post #8 of 20 Old 12th March 2012, 09:37 PM
Chas C
Chas C's Avatar
Oops!
I've mostly been driving the B10 V8 recently - BT and B8 are summer use only - I wasn't considering that the BT was LHD when I responded!!
Are you sure there's no breakage in the spring near either of its extremeties..?
Chas
Chas C is offline
post #9 of 20 Old 12th March 2012, 09:42 PM Thread Starter
pulsapharer
Originally Posted by Chas C View Post
Oops!
I had the n/s drivers side strut assembly completely removed and the spring was in good condition other than the rust. I jacked the o/s up and tightened the top lock nut( between the strut and shock). Didn't notice any damage although I didn't remove the strut assembly, which I'll probably end up doing!
Surely if the spring had snapped the ride height would be lower not higher?
post #10 of 20 Old 13th March 2012, 09:53 AM
Chas C
Chas C's Avatar
That would be my expectation too. Perhaps one spring has been replaced in isolation rather than as a pair, so there's different levels of fatigue causing more sag in the older one?
Chas
Chas C is offline
DIY: B10 BT front shocks pulsapharer ALPINABoard.com | BMW Alpina Discussion 11 27th February 2012 12:28 PM
Front shocks on the way out, or something else ? stumbo E39 M5 and E52 Z8 Discussion 11 27th January 2009 04:11 PM
B10 rear shocks & springs maxm5 ALPINABoard.com | BMW Alpina Discussion 2 13th July 2007 08:54 AM
Front Shocks Geach E34 M5 Discussion 7 31st January 2007 07:13 PM
Front Shocks - Help Please Simon E34 M5 Discussion 20 19th October 2001 10:13 AM
