Hartig Ignition Sensor - Page 3 - BMW M5 Forum and M6 Forums
 2Likes
post #21 of 39 Old 14th August 2018, 08:31 AM
Redox
Redox's Avatar
So, I go back to this old topic. I repeated the same story as Mike. The crankshaft sensor is damaged. Is there a method for checking it? Maybe by resistance? And how to check the electronic control unit? Did someone understand the situation with the marks on the flywheel?
It seems that now the system sees a "0" point and gives the command to start the engine. But does not see the speed and don't give the command to ignition.
B7 turbo coupe
Redox is offline
post #22 of 39 Old 14th August 2018, 01:46 PM Thread Starter
Mike323i
Mike323i's Avatar
Only news I can add now is that the control unit seems to be easily checked and repaired. DJMink on this board had good success with a local electronics guy. The unit is pretty simple, so a good old time electronics guy should be able to check and repair diodes, capacitors, broken solder joints, etc.
As for the sensor, I do not know if anyone has determined replacements.
1979 B7 TurboCoupe #096
1979 B7 TurboCoupe #124
1980 635csi
1980 323i Baur
Mike323i is offline
post #23 of 39 Old 15th August 2018, 09:10 AM
Redox
Redox's Avatar
And what do you think about the flywheel? Are there any special marks on it besides the missing tooth? In fact, the sensor reads two parameters. One - to start the engine. The second determines the moment of ignition. Does this mean that there are 2 marks on the flywheel?
B7 turbo coupe
Redox is offline
post #24 of 39 Old 15th August 2018, 01:13 PM Thread Starter
Mike323i
Mike323i's Avatar
I understood there were magnets embedded in the flywheel that the sensor read (I thought two of them) not missing teeth.
1980 635csi
1980 323i Baur
Mike323i is offline
post #25 of 39 Old 31st January 2019, 10:28 AM
Redox
Redox's Avatar
I have not abandoned my attempts to solve the sensor problem. To do this, we first simulated the circuit of the control unit on paper and understood the principle of processing the input signal. Then made a simulator of the ignition system. Tday, the system works "on the table." The next stage is checking by car. Unfortunately, there is a lot of snow in Moscow this year. So I can't dig out my garage yet, so that I could transport Alpina to the workshop and continue my research. But the first results are encouraging.
https://www.youtube.com/watch?v=mb69vGB4mfM
B7 turbo coupe
Redox is offline
post #26 of 39 Old 31st January 2019, 09:23 PM Thread Starter
Mike323i
Mike323i's Avatar
Very interesting!
Do you have a magnet mounted in that toothed wheel? Or is it counting teeth?
On the car, the teeth are the starter ring gear, so there are no "missing teeth" to count as in most common systems.
I understood that there were magnets mounted in the flywheel that the sensor was reading instead.
What have you found out so far?
1980 635csi
1980 323i Baur
Mike323i is offline
post #27 of 39 Old 1st February 2019, 08:03 AM
Redox
Redox's Avatar
For a start, I found out that a similar system was used only on one car, namely, on a Porsche 924 turbo. And talked with the guys who repaired such systems. They told me that there is 1 magnet in the flywheel. Then I just took any gear and sawed off one tooth, and instead of it glued a piece of magnet. Made a mockup with electric drive. (The wiper motor performs this function well, plus it has 2 rotational speeds). After the defect of my original sensor (like you) in the control unit there was a short circuit. So the block diagram we drew helped to identify the faulty chip, and we replaced it. Finally, the most important problem was the selection of a sensor with similar parameters. As you know, until now no one could find anything similar. But I had the opportunity to experience a very large number of sensors. We still had to modify one of them, the closest in terms of the resistance of the coils. Now it no sense to talk about what kind of sensor is question. I'm not sure that it will work correctly at high revs. But we are not in a hurry. Our main task was to get a spark on the spark plug. The next stage is the installation on the car, the definition of the gap to the teeth of the flywheel, checking work in real conditions. I think it is necessary to adjust the sensor parameters with the help of additional resistors or capacitors.
B7 turbo coupe
Redox is offline
post #28 of 39 Old 1st February 2019, 08:07 AM
Redox
Redox's Avatar
Of course, our model looks a bit funny ... but it works!
B7 turbo coupe
Redox is offline
post #29 of 39 Old 5th February 2019, 07:40 PM Thread Starter
Mike323i
Mike323i's Avatar
Ah, how did I forget! I knew the early 924 turbo had a Siemens-Hartig ignition, but forgot!
The 924 sensor (93160602100) looks identical to the original Alpina "Rafi" branded sensor. It is also no longer available from Porsche. The 924 world thinks they are the only ones with this problem. You could try to find a 924 Turbo sensor, but the Porsche people are hoarding them now, too.
If you think the 924Turbo sensor would work, the Porsche community has much better resources, and could (should) start pushing Porsche Classic to re-release a replacement sensor. They are surprisingly responsive in supporting their older cars these days.
Also, have you looked at my threads on this board? A previous owner of one of my cars appears to have sourced a replacement at some point. Attached are pictures of the original Rafi sensor, and another Bosch looking one, with a part number take on it. Another clue?
You are well on the way though. Great work! Look forward to hearing if it works on the car.
1980 635csi
1980 323i Baur
Mike323i is offline
post #30 of 39 Old 6th February 2019, 03:34 PM
Redox
Redox's Avatar
I have already talked in Moscow with the director of the Porsche Center. He claims that the sensor problem is known. But while the factory does not help. The sensor number in the photo is not a Bosch number and is not related to the manufacturer number. On my sensor - the same. Such sensors were supplied by Alpina at the end of the 80s, when Rafi was unavailable. I have already probed manufacturers of such sensors in Germany. No one else wants to do this.
One of the best guys, who understands the electrician of the old Alpina very well, lives in Germany. I had a long conversation with him on this problem. He is now trying to create a similar sensor himself. And with improved features. But the price of such complex work will be high. I'm sure he will succeed. For my part, I am trying to find an inexpensive solution. If I'm not lucky, I'm sure Oliver will do it very, very well.
Of course, I began to study the problem with reading your threads. As a matter of fact, it was your thoughts that I based on my experiments. The easiest way is to remake the system into a modern control module. But I am Russian. And the Russians are not looking for easy ways.
B7 turbo coupe
Redox is offline
*Bong* 'Oil Pressure Sensor +' and 'Oil Level Sensor' gurman E34 M5 Discussion 16 30th March 2016 12:30 PM
Lock car without arming internal sensor / shock sensor? bugzy E39 M5 and E52 Z8 Discussion 12 15th September 2008 06:37 AM
Can broken cam sensor make lambda sensor before kat to show wrong values?? blitzkrieg E39 M5 and E52 Z8 Discussion 0 15th June 2005 02:04 PM
B7-Hartig Distributer Set-up-Pic's?... DV ALPINABoard.com | BMW Alpina Discussion 2 4th December 2003 03:35 PM
Disconnecting motion sensor & key in ignition beeps? PaulMarin E39 M5 and E52 Z8 Discussion 7 12th March 2001 04:20 AM
