Read this, very informativeAre the yellow Konis the exact same shocks you get in the dinan stage 1 suspension setup?
http://www.m5board.com/vbulletin/showthread.php?t=56864&highlight=Koni+yellow
I have 275's all around, but on a Dinan Stage 3 (Koni)setup. I definitely helps dial out the understeer compared to the 245's up front and adds just a hint of oversteer. I have adjusted tire pressures by lowering the rears a little to compensate, I have a 2 psi stagger instead of stock 4 psi.Not to try and kijack the thgread, and I'll start a new one if it is appropriate...
Just curious as to who is running 275's on OEM 9.5 rims up front on these setups, or if they are all running stock front OEM rims and just slightly wider than stock tires?
I'm looking for a setup for occasional track use that will allow me to run my 275's on 9.5" SSR Comps without rubbing. I've done searches, but as usual there is so much conflicting info...I have H&R's, uninstalled as of yet, but apparently they will not allow 275's on 9.5" rims...
Anone running a 275 setup on aftermarket coils...
Dinan springs drop the car .5"How much does the stage one setup actually drop the car? and does dropping the car mean i'll need the camber plates to keep the alignment in check?
This is fantastic information, thanks for your replies. I should have my Dinan Stage 1 suspension kit with Konis today. I'll have it installed this weekend. I am soooo excited. I am also going to get the 17mm rear sway bar. THANKS AGAIN everyone, I will post pics of before and after shots when I get the kit installed!![]()
