1 - 20 of 25 Posts
Hey guys, I used to search but could only find threads regarding multiple codes. So today I took the beast out for about an hour and a half and as I was pulling into my drive way I got a yellow cog for 2-3 seconds and then it disappeared.. I read codes and the only one that came up was 510E.. after reading codes the car started right back up and I took it for another drive (about 20 mins) and the car was fine. I have had a cog 1 other time about 4 months ago that also went away. .. I think it was the red one that time. When I read the codes for that it was the 4f40 I think. But that one did not pop up this time. Only 510E popped up for me today.
my question is.. should I get it into a shop or keep driving until it actually causes me an issue?
If it reoccurs, you might start with investigating/running a test on your PLCD and/or slave cylinder.
Random / brief 4F40 is sign of a tired pump motor. This matches your symptoms IMO.
4FA0 by itself is PLCD
510E no comments.
No harm if you keep driving just be aware it will eventually break down.
Quoted from JColley ... "510d/510e. Those codes are caused by an interruption in the signals from/to the PLCD. Nothing else causes those."
From what I was reading there had to be a cominaton of codes not just 510E by itself.
So I took my car to the shop that did my rod bearings. He said that to do the PLCD he’s going to have to drop the tranny and said I might as well do the clutch and fly wheel if he’s going to drop it. He said he would only charge me $750 for labor, but all the parts I need would be like 3k so I’d rather just do the PLCD first, that is, if can find someone to do it without dropping the trans. I read somewhere on the forum that to do the PLCD you don’t have to drop the trans. What should I do? Car ran great for 100 miles there and back no yellow cog this time.
Show him the newtis instructions. No need to split trans/engine. If not... you need a new mechanic.
Honestly tho $750 sounds cheap for dropping the trans. I'd take that offer and replace/fix everything. SMG flywheel+clutch kit is more like $1500. Add an extra $500 for seals, fork, etc. Motor can be 'cleaned' and wiring on top must be fixed.
Discussion Starter #11
I’ve looked everywhere for cheaper parts, even the sites you gave me awhile back Flaco. The flywheel they are selling for like 1300-1600 by itself. Am I looking At the wrong one. Can you point me in the right direction? I’d like to get it all done and over with if I can do it for 2500-3k
What sites are those? This is my diy list:
Just checked and I see
Rockauto
820 flywheel
491 clutch kit
Discussion Starter #14
Do you guys think that $900 total (parts and labor) is an ok deal to get PLCD sensor job done?
Discussion Starter #15
Sorry to post again but I have an update. Took the car out for about 60 mile drive, car drive amazing. Was one of the most fun day’s I have had in it yet.
As soon as I get home just like the past couple weeks I get the yellow cog, and then tranny started to make this nasty grinding noise so I hit the stop button. Gave it a bit and read codes.. for 510E and 4FA0 I believe. When I tried to start the car again the Smg pump sounded like ****. It has failed and is not priming at all Glad it’s in the garage but it’s going to have to be towed to the shop..should I still do PLCD and obviously it needs an Smg pump. Do you have to drop tranny for Smg pump?
More from jColley from the thread 4FA0 SMG fault...
"4FA0 was caused by the 510d/510e.
No signal from PLCD -> no position information for clutch -> position deviation (4fa0)
Replace the PLCD and the 4fa0 will be gone."
Discussion Starter #18
Car Is in shops getting PLCD and Smg pump done. I am doing Smg pump as well because I heard it fail with my own ears. Thank you for the jcolley quotes
1 - 20 of 25 Posts
