Hi ~ guys ~
Safe driving always ~
I would like to know what you guys think about engine oil additive from WURTH. Anyone who has tried this , I would like some feed back.
I am only asking this because I know S62 engines are so complicated and needs to be well taken care of.
There are two products , first one is an Engine oil additive . It suposs to reduce the damage caused by running the engine when it is not
properly warmed up. Also reduces oil consumption and restores engine performance on high mileage engines.
Second one is WURTH Oil leak stop . What this does is , it helps to stops the oil leakage aroung the oil seal area ( I dont know where this place is.)
and increases the oil seal lifespan. In addition it says it helps the engine oil to maintain its oil vesocity during extream use.
Damn its complicated..... Is it possible to use all three of these at once ?? Or shall I just not use it and do another oil change, even though
I replaced by oil about 1800ML ago.
